Just pull the ABS fuse for now so the car is usable without battery dying and obsessive noise/brake activity. Pop the hood and open the main fuse/relay box by the strut tower. Fuse slot 1 there. Or fuse slot 33 in the cabin fuse panel down by your left knee.
On mid-90's Subaru's they had a common issue where the ABS relay would fail and cause the exact same issue - ABS activating nonstop even when the car was off. Just replace the relay. Not sure if you have one or where it's located.
Could also be a the controller.
I'd bet it's not mice but maybe, I have seen rodent damage.
Sounds like the same thing could be happening here. On those units the relay was actually attached the ABS unit you have pictured.
