I got a SOHC EJ20 a couple years ago for an '01 Forester. The donor engine was much newer than that.
SOP is to swap the intake manifold, and all wiring/sensors/injectors/throttle body/coil/etc from your old engine. Oil pan will likely be different, leaving more room for the larger cat, swap it for more capacity, or don't. Good idea to do plugs, valve cover gaskets, oil separator and timing while it's out. It will almost certainly have a 7mm oil pump, so I would swap to a 9 or 10. BUT, read the fine print from the seller, as removal of anything sometimes can void the warranty.
I bought through eBay, as that would have some standardized way to look at seller history and feedback. And as a result, there is some incentive for them to make things right if things went sideways.
I also paid with a credit card through paypal, so I would have 2 ways to dispute the charge.
I've heard so many horror stories over the years about importers that send out junk, leave customers out to dry, and then change their name after a couple years and some bad publicity.
