Leaderboard
Popular Content
Showing content with the highest reputation on 03/05/24 in all areas
  1. I bought a set of the LED headlight bulbs that was deemed directly compatible with my OEM headlight bulbs. Big mistake. My digital dash went haywire and the engine began cutting out and otherwise ran poorly. Then the below dash relay switches were overheating and burning out. Finally, I realized that those LED's were screwing up my car big time, but only after I changed out my distributor, coil, cap and fusible links in a rain storm. Now I am back to the the OEM bulbs, have installed all new relay switches, and keep a handful of spare relay switches to pop in if I have any further problems. 524,000 miles on my 86 gl10 turbo.
    1 point
  2. The good news is that I can’t see it being a bolt from a major component like a ball joint or hub retainer bolt as they have captive threads, rendering that nut useless. And it’s too short for a suspension arm bolt. I’ve had this many times without issue. Keep the left over bits aside in a labelled container incase you find a missing bolt. While they’re off the vehicle consider the effort as weight reduction. Cheers Bennie
    1 point
