Leaderboard
Popular Content
Showing content with the highest reputation on 03/21/24 in all areas
  1. Ignition switch should be held in by two Phillips head screw/bolts opposite to the side that the key goes into. You should only need to remove the steering column cowling and maybe drop the steering column off it’s mount bolts to get more access. You don’t have to pull the ignition barrel out to replace the ignition switch! That has the funny looking bolts without a head on them. They’re designed to snap off once torqued up so the ignition barrel can’t be easily removed by thieves. I’m not sure that the starter relay mod will dive this issue since you mentioned it cranks over fine and will run in the start position but die in the ON position. You’d only need a 30a horn relay - same as what you hook driving lights up with. Cheers Bennie
    1 point
  2. B assembled the rear suspension on the Impreza. To make the Mustang rear calipers fit the Subaru front rotors I turned the rotors a little thinner, about a millimeter total. Second side I had to run a lot slower than the first. Since the opposite side of the rotor wasn't up against the jaws it was chattering at anything above about 100rpm. Also we only had one banjo bolt so I made another one. Will probably eventually get legit banjo bolts and better caliper mounting bolts but they all work well enough for now. Rear suspension and brakes assembled. ABS sensors and parking brake cables just zip tied up for now. Will eventually remove ABS cables and make brackets to connect parking brake cables. Black stuff running down exhaust is carbon washed out of the engine by excessively rich mixture when we first got the engine running. I cleaned up the wiring in the engine compartment, still some work to do there. Ditto the interior. Ready for the first test drive, just have to lower the car. Been on jackstands for way too long. For some reason the cam signal issue is back. Engine still runs but not as smooth as it has been, so I probably need to call Haltech again. On the plus side we drove the car around the block and everything important seems to work. All three pedals, shifter, and steering seem to do what they should. Didn't notice any tire rubbing or bad noises or vibrations. Didn't leak a drop either.
    1 point
