Leaderboard
Popular Content
Showing content with the highest reputation on 05/31/24 in all areas
  1. Installed V band clamps on the headers. Turned some aluminum slugs to align the various pieces. Mockup assembly, I had to cut the Y pipe back beyond those grooves. Siliconed some pieces of silicone under the C shaped pads I'd welded on the crossmember to keep the top of the exhaust from denting. Meant to do this a while ago, hoping it minimizes the noise of the exhaust banging against things. V bands welded and exhaust assembled. Exhaust is much quieter now on the throttle, seems to have eliminated the raspy exhaust leak noise. Still sounds good under load though. At about 60mph the exhaust is so quiet you can barely hear it, at least over the tire/bearing noise. At about 80mph you can definitely hear the exhaust but it's not obnoxious. I did get a slightly longer muffler I want to try out sometime too.
    1 point
  2. I replaced the front shock hose on the Impreza. Seems like that spring perch just rotated out of place, hopefully won't be a problem in the future. We took it and the blue Forester to our friend's little jumps. Forester seemed to jump a little better than Impreza. Impreza seemed to nose over more and was probably bottoming out the front suspension on landing when hitting the jump fairly hard. Also got video driving over parking barrier as a baseline for shock tuning. Did all that with 40psi in the Impreza's front tires though. When we got home I put softer springs on the rear of the Impreza. Only sits about 1/4" lower initially but will probably settle down a bit after some use. Replaced one of the rear CV boots that had a little rip while I was at it. Didn't get back out to test jumping for various reasons, curious to see if the softer rear springs help. The gas pedal in the Impreza seemed too far to the left so I tried to just bend the rod to the right. Was working for a while until the plastic barrel it rides in exploded. So don't do that. Got it super glued and safety wired back together and seems to work. Surprisingly open design. Gasket on the black plastic part probably seals against the sheet metal. Bought a used replacement off ebay, guess I'll have a spare. Meanwhile B's main project on the blue Forester was removing and replacing the stud for the lateral links out of his knuckle. Welded a 14mm nut to an acme nut and used my hollow hydraulic cylinder to pull it out. I'm working on replacing the two bolt flange connections in the Impreza exhaust with V band clamps. Will post pictures when that's finished.
    1 point
