Leaderboard
Popular Content
Showing content with the highest reputation on 06/18/24 in all areas
  1. I bought a set of the LED headlight bulbs that was deemed directly compatible with my OEM headlight bulbs. Big mistake. My digital dash went haywire and the engine began cutting out and otherwise ran poorly. Then the below dash relay switches were overheating and burning out. Finally, I realized that those LED's were screwing up my car big time, but only after I changed out my distributor, coil, cap and fusible links in a rain storm. Now I am back to the the OEM bulbs, have installed all new relay switches, and keep a handful of spare relay switches to pop in if I have any further problems. 524,000 miles on my 86 gl10 turbo.
    1 point
  2. I was just Premier again and saw the Brat and the rest. If anyone has the one you’re looking for I’d bet this guy does. I’ll ask next time but you know it won’t be for sale. Good luck. I hope I can spill some magic over to you my friend. After many decades it appears I may/will finally have the two or maybe three vintage Subarus I’ve wanted back in my life for decades. This coming month I should be making it all happen. Hope the same light shines on you !
    1 point
  3. First thing we did yesterday was swap out the long travel struts in the black Outback for some stock Outback/Legacy struts. We plan on revalving these shocks so we have a set ready to swap in the other cars for easier/faster shock tuning. It looks like a lowrider in person now. I'm pretty sure those are stock Legacy/Outback struts and springs but it does weigh significantly more than stock and the stock springs are pretty soft. White Outback has been shaking under moderate braking for months now. Light or heavy braking it's not too bad. Noticed a while back that the control arm bushings were shot so I replaced those. Have had this pair of Whiteline increased caster bushings for a while. Maybe easier to install than their normal bushings since they're not flanged. Only shifts the wheel about 1/4" which works out to about 1/2 a degree of caster. Also replaced the front rotors. Not sure if they were causing the shaking but we're going to need some used ones to turn down for rear use eventually anyhow. Replaced the air filter, it'd been 30k miles and it was super dusty. Still seemed to have good power though. Also replaced fuel filter and front diff fluid. B replaced the taillights on his blue Forester, they've been cracked and leaking for a while. He tried replacing the AC condenser since it had rubbed through on the radiator but apparently the 2001 Forester condenser is different than the good 2000 Forester condenser he had. Also replaced his trans fluid and some other things. Got the STI shift yoke from the dealer. In retrospect I should have just modified the one I'd welded and ground the holes on to clock it but this was easy. Replaced the bushings. Centered up, way less slop, can now fit the shift boot and trim on.
    1 point
