Leaderboard
Popular Content
Showing content with the highest reputation on 07/05/24 in all areas
  1. When I went to take out this upper left bolt it was feeling really tight, then "rubbery", then the head broke off ... I tried "liquid Wrench" with a nut on the end taping it a bunch with a hammer to "induce vibration" gripping it real tight with needle nose vice grips, etc. and letting it baste for a couple of days.. SO I thought maybe I could use it as a stud with a sleeve nut and it torqued down good. https://www.ultimatesubaru.org/forum/gallery/album/897-ea82-water-pump-broken-bolt-fix/
    1 point
  2. Chux is right - they’re the same phase so it’ll install fine but will require one extra step: the legacy and Imp final drive won’t match. The simplest solution is to swap the rear diff to match the trans 4.44 final drive ratio. legacy should be 4.44 so you’ll need a 4.44 rear diff that accepts your Impreza axles. 02 Impreza rear axles May not slide into a 2001 legacy rear diff. I could be wrong I don’t follow Impreza closely I’m unsure if the rear axles swap but Impreza and legacy rear axles aren’t always interchangeable in the same year. Legacys went to newer axle style before Imprezas. Not sure when that happened and Imprezas had a few changes through the early 00’s. so you’ll have to research which axles the 02 Impreza uses and get a matching 4.44 rear diff That being said there’s no way losing fluid in a radiator swap was enough to trash the transmission. losing that amount would not bring the fluid level from between the low/high marks on the dipstick, to not registering on the dipstick, which it would need to in order to damage anything. Also if the trans were that unforgiving to losing a pint of fluid or less they’d be blowing up left and right with steep mountains and spirited driving sloshing the fluid around.
    1 point
  3. Thank you very much for your comment !
    1 point
