A 93 22 intake manifold won’t plug into the EJ25.
It could work if you bolt a 1995-1998 EJ22 intake manifold on it and figure out all the minor pvc and vacuum and other bits. 93 EJ22 block bolts to EJ25 trans and exhaust. Bolt 95-98 intake manifold onto 93 engine and it’ll plug into the EJ25.
1995 EJ22 from an automatic is the direct bolt in option. Manual 95 works too but just won’t have EGR which you can easily work around.
1996-1998 EJ22 are all bolt in and plug and play if you also get a single port EJ22 exhaust manifold. It bolts right in place. The EJ25 exhaust is dual port and won’t bolt to the 96+ EJ22. (95 EJ22 has dual port exhaust heads so it bolts right up to the ej25 exhaust
