Don’t go the Weber, not worth the trouble!
If you have an auto choke it should work on initial start up. Try double pumping the throttle before turning the ignition on and starting. Don’t touch the throttle pedal.
If all is working well it’ll start and have high idle until you tap the throttle again, then it’ll drop the idle speed down and open the choke a bit more.
Cheers
Bennie
