Leaderboard
Popular Content
Showing content with the highest reputation on 01/15/25 in all areas
  1. Car is done! Kept it two tone for the win. Purchased new sheet metal including radiator support, center hood stay, and right/left hand radiator panels for about $160. These come painted (black) from Subaru. Or just cut them out of a donor. I counted just over 20 spot welds for the total weld job. Didn't have to completely remove the fenders to access the weld points for the radiator support, just moved them aside. Removing the bent metal wasn't hard using a 3/8" spot welder hole saw removal tool and a drill motor to punch through the spot welds. For the rebuild, these welds are beyond the harbor freight 240V "pinch" spot welder in my opinion due to the lower section essentially welding to a tube. My neighbor has a HF MIG welder that did an excellent job welding the new metal in place. Just cover the whole engine first with fiberglass cloth to avoid hot slag melting the harness. Before removing any metal I marked the outline of the pieces to help line things up. Having the headlights in place helped line up the two radiator panels (actually they should be called condenser panels) prior to welding. The hood latch was aligned with the hood and clamped prior to welding. After welding, put the condenser/radiator/headlights/bumper/bumper cover back on.
    1 point
