I had a similar issue on my 35th anniversary car (2004).
Critters had gotten into the left rear quarter panel and chewed the wiring harness. Shorting the turn signal circuit to the LR light, and damaging the wiring to the antenna (I think your 2000 will have a conventional antenna on the roof over the driver's door). Every time I used the Left turn signal, the gauge cluster would go dead. As long as I remembered not to use that signal, things were cool.
If you can't think of a more specific correlation between using a function like that and the failure, I'd buy a breaker for that fuse so it could be reset and continue on.
Hope that helps!
