2
Everything posted by edrach
I consider myself pretty knowledgeable when it comes to buying a car, but I always take the car to Smart Service in Shoreline for a "pre-buy inspection." It's a $100 bill but well worth it. It's no guarantee that the car will be entirely trouble free but they can rule out the most expensive possibilities for you including torque-bind. You're in Redmond so Smart Service is only a short drive for you and I've never found a seller refuse to have the car inspected on the promise that the sale is done if it passes muster. http://www.smart-service.com/
If you're talking 13" alloys, the enkie spoked alloy wheels come in 5, 5.5, and 6 inch widths. Most common seem to be the 5.5s.
gemery10 has the right idea; then head for Pull a Part and get replacement cable (get a 2nd for a spare); they aren't too difficult to replace.
With all the cheap axles available at the local Pull a Part yards, you really should replace the one with the metal dust. It takes less than an hour to replace an axle once you've done a few (pulling them at PAP is just practice). You're welcome to keep running as is but you know that an axle might just break when you really need to use the car....Murphy's law will dictate it'll run fine until you really need it.
If you're near Bothell, WA stop on by. Safe trip.
1984 Brat Won't Start (non-turbo) Help?
edrach replied to rpape's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If you have the hitachi distributor and need the ignition module (common failure item), I have a used good one for $25 if you need it. -
No timing belt in your Brat if you still have the EA81 engine installed. -
WCSS8 - Gentlemen/Ladies, Start Your Graphics
edrach replied to P K's topic in Meet n' Greet. Your USMB Welcome Center
Brian, How about replacing the "O" in Coast and Show And Oregon with the Subaru oval emblem? Just a thought. -
I am very tired of changing front axel shafts
edrach replied to gonehuntn's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sucker king is right; the right boot fails more often since it gets a lot of heat from the catalytic converter. If you're running too lean it gets even hotter and causes the boots to fail pre-maturely. I once made an "air scoop" to deflect the heat away from the boot and run some cooling air between the scoop and catalytic converter. Worked pretty well. -
splines on wheel hub stripped ?
edrach replied to wounded brat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It also happens when the axle nut is not tightened to the 145 ft-lbs of torque. Get a new hub from the local wrecking yard; that's the easiest and cheapest fix. -
Marysville Everett Need a Roomate?
edrach replied to NoahDL88's topic in Meet n' Greet. Your USMB Welcome Center
I believe there are rural portions of King and Snohomish counties that don't require emissions testing; I'd check with WA state on that. -
You might also try reaching richierich in Portland. He runs an independent Subaru only repair shop. I'm sure he can do better for you than the dealer in Bend. Does the car drive at all? I know Bend is quite a distance from Portland. Good luck. Something isn't right that you should be having that trouble with a Legacy with only 88K on it. Who's the last one who had the crank pulley off and why?
