2
Everything posted by edrach
I'm second owner of my '91 Legacy wagon and the previous owner was anal about service and record keeping (he even logged each and every fill-up with gas!!). Anyway, my wagon is still on the original clutch. It started slipping about 2k miles ago but is still working acceptably at 157K miles. I'm planning on replacing it this weekend.
Alternators put out less volts at idle; so that's normal. However, it can also be an indication that the alternator is not charging the battery enough or the battery is not taking a full charge. Most autoparts stores will offer a free check of your car's electrics. Of course they are biased to sell you the parts, but a check at two or three shops should allow you to decide what you need.
As to the economy, WA state claims to be "in good shape". WA is like two states really, the populous western corridor from Bellingham south to Vancouver and the sparsley settled area east of the Cascade mountains. Rents around Seattle seem high to me but there are areas where it's more reasonable. Check the local chambers of commerce for more detailed information.
Ratio of running vs. non-running subarus
edrach replied to Snowman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have 5 and they all are running. -
I had a set of the 14" WRs on my Legacy and I'm over 50K miles on them but they are in dire need of replacement now. I've been fond of them. You might check the Nokian website for alternate dealers in your area; around here Tire Factory is the authorized distributor and Discount doesn't handle them as far as I know. I bought this set of WRs in Canada since they were just across the border and much cheaper. Maybe you can do the same in Mexico. Another thought...why are you going with 225 width; that's overly wide for the rims as well as narrower is better with a snow tire?
Sounds like a DOJ problem (okay when coasting, vibration (or worse) when accelerating). Usually okay to run on a noisy axle for quite a while. Any torn boots yet. If you have a "lifetime" warranty on the axle, it will go away once the boot is torn so get it off before that happens. Among rebuilt axles, I've had the best success with www.cvaxles.com.
Stolen Car alert, Bothell, WA area--Recovered
edrach replied to edrach's topic in Meet n' Greet. Your USMB Welcome Center
The car didn't look too bad but the auto body repair/repaint is going to be around $2500. As to any remnants/residue, I will have the interior detailed. I might take it to the local police and have their drug doggie take a whiff before I try to go to Canada with it. Thanks for the suggestion. I should have the car back by the middle of the week. -
Help on purchasing/price of Brat
edrach replied to coylethebarbarian's topic in Meet n' Greet. Your USMB Welcome Center
I bought my first '84 Brat four years ago with less on it than yours but in similar condition for $1300 and was glad to get it. I just bought a second pristine '84 Brat in excellent condition and absolutely rust free for $2500. If you have this guy down to $800, you'd be foolish not to jump on it for $800 IMHO. There are people in the northeast who would kill for the buy you're getting. Best of luck with it. -
Turbo axles have 25 splines and non-turbo 23. A turbo axle on a non-turbo transmission will shear the roll pin every time. Looks like your dealer sold you the wrong axles; not an unusual mistake with some rebuilt axles. I've had very bad luck with ARI rebuilds in the past. I'd suggest you get your axles from ShawnW or www.cvaxles.com. Also, Pull a Part has them very inexpensively is you inspect the donor axle carefully. For now take that axle back to the shop you bought it. Good luck getting the right size roll pin (dealer item); I have a few in my hardware bin if you want a pair (I'm in Bothell); drop me a PM for a 'phone #.
Anyone Know how to fix this? [PROB-SOLVED]
edrach replied to minip's topic in Old Gen.: 80's GL/DL/XT/Loyales...
So what fixed the problem? -
Tranny mounts are plentiful at the local Pull a Part yard. Probably cost you less than $5 and 30 minutes of your time.
Severe front end shaking
edrach replied to myfinalcoffinx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Right and left side are identical, but I'd suspect that they wear differently. If you're replacing a left side, a left one would match; but a right side would have less wear. In either event, I've never found it made much difference. I look for a high mileage car which likely had axles replaced already; check for labels from a re-man still present to indicate age; lastly, and most importantly, check the rubber boots for micro cracks (no good) and thickness (the thicker the better). The better rebuilders use a thicker rubber boot that will last longer. Also see that the rubber is still flexible and smooth (good). Check for obvious play in both joints and avoid that. Good part is that PAP warrantees the axles for 30 days so if you get a back one you can return it for exhange for your money back (save your receipt and make sure it is marked before you leave). Once you decide the axle is bad, you can order a new rebuild if you like and return the "donor" axle from PAP (I've never done that since I've always managed to pick good axles). Also, make sure that you get the proper version EA81 versus EA82 cars; also FWD and 4WD drive axles are slightly different but I've found it doesn't make much difference in actual use on the EA81 cars. -
I'm with everyone here who thinks axle; except it's not the CV joint but the DOJ (inboard) joint. Typical of DOJ failure to shake badly under load and run okay as soon as you let off on the gas. Especially if the torn boot is the inboard joint, replace the axle. You can get pretty good ones cheap at the local PAP yard if you carefully inspect the axle you expect to pull. Plus it gives you practice in pulling the axle on your car. -
Correction to my previous posts; it's the ECS light that comes on after about 6 min. of running. I think it's related to the EGR.
Welcome to the Board. Your dealer is wrong; either you're leaving your foot on the accelerator pedal when shifting or the return springs on the throttle body aren't doing their job; somehow the symptoms you describe are indicative of a major problem with the throttle control. It's also a significant safety issue. Go back to the dealer and insist that one of the mechanics drive the car with you and duplicate the problem. If they can't duplicate the problem, insist on getting your complaint in writing so you and they have a written record since this will become a warranty issue. In case it becomes a liability issue (heaven forbid) and you have an accident, you really need some proof that you tried to get this fixed.
ea81 4spd D/R tranny question
edrach replied to Mr. Carb's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I can address the leaking oil coming out of the speedo cable; no it's not normal. There's a rubber seal just inside of the fitting where the speedo cable enters the transmission....that seal is leaking badly. Unfortunately, it can't be replaced without taking the gearbox apart (or so I've been told). Replacing the cable with a "dry" one will allow you to use the speedo until it starts leaking. However, you have to address this problem soon. If you don't, some of that grease will get into the speedometer and make it unusable (symptom is it will read a rediculously high speed even when you're driving slowly in first gear). Been there, done that. -
Interesting; on my weberized '84 Brat, the EGR light comes on after about 5 minutes of driving and then stays on. But it always is off whenever I start the car for the first time.
Is the O2 sensor disconnected? Or did you add a weber? When I replaced the carb on mine with the weber, the O2 sensor doesn't change anything so after about 5 minutes of running the EGR light comes on. One of these days I'll put some black tape over it.
Roo-Builders is asking for HELP!!!
edrach replied to rubuild's topic in Old Gen.: 80's GL/DL/XT/Loyales...
PM sent. Thanks. -
Just a comment for the east coasters (I was one until 1988....I grew up in northern NJ), what the pictures don't typically show is that sections of these roads are less than 10 feet from a significant drop off of 500 to 1000 feet straight down.....and there is no armco barrier anywhere; you go too close to the edge and there's nothing to stop you. I'm not sure of the exact elevation but I know from past trips that we're typically 5500 feet above sea level.
I didn't use the camera much; too much fun driving around in the snow. But managed this shot just as we were leaving with our two trees.
It was a great time. Interesting snow this year. We had a heavy snowfall about two weeks ago and then a warm spell. Then more snow the day before. It resulted a layer of soft ice underneath 4 to 8 inches of wet snow on top. The wet snow would compact real easily and some of the lower cars got high centered very easily just plowing though the deep stuff. We finally got our trees near the end of a long day.
The annual Hatch Patrol Christmas tree run
edrach replied to Qman's topic in Meet n' Greet. Your USMB Welcome Center
It's raining today here in the lowlands; should be snowing where we're going. Tomorrow's weather should be the same as today. :)
