2
Everything posted by edrach
Lets not confuse the issue with new variables like rear end ratios, gear ratios in 4th and 5th, and load or no load, etc. We're talking the same car (whatever it is) at a steady cruising speed of 55 mph on a level stretch of road. Whether you are in 4th or 5th gear, the same amount of work needs to be done to push the car through the air and overcome frictional aspects. That being said, the same amount of energy will be required to do that work. Now the question becomes, is the engine more efficient in 4th or 5th gear and can the car squeeze more energy out of the gasoline/air mixture. The simple way to tell that is to look at the torque developed by the engine at a given rpm. Most cars have the torque peak at around 3000 rpm; above that the torque drops off and the horsepower continues to increase. Forget horsepower, think torque. An engine is most efficient at the torque peak; so the answer to the 4th or 5th gear question is "what's the engine rpm of the car at 55 mph?" The engine rpm at 55 mph closest to the torque peak rpm will prove to be the more efficient and squeeze the greater amount of energy out of the fuel mixture and will determine whether 4th or 5th gear will use the lesser amount of fuel.
FOUND: Laptop Computer from WCSS7
edrach replied to NorthWet's topic in Meet n' Greet. Your USMB Welcome Center
His was the only laptop I saw at WCSS7 and he's not online much lately. -
How To Recognise a WEBER 32/36 DFV CARB??
edrach replied to nzdusty's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have done two conversions on the EA81. The first on my Brat with a DGAV and the second on my son's Brat with the DFV. Both work just fine. I actually like the DFV conversion better since part of the DGAV is very close to the distributor ignition wires (on the DFV, that part is on the other side and doesn't interfere); also, the DFV seems to hook up with the existing throttle cable better. Neither of our Brats have power steering so I couldn't tell you how they compare in that regard. -
Starter problems. '84 wagon
edrach replied to krankitup's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'd like to take credit for being a genius, but I've seen that blackened connector on at least 5 different cars in the last 6 years (since I've owned Subarus). It's just a matter of their engineers trying to pass too much current through a connector and ultimately they fail in exactly that way on the exact same connection. Krankitup, I'm glad your car is back on the road. -
I know I'll get flack for this, but moving a car down the road at 55mph requires energy; the same speed requires the same amount of energy; so it doesn't matter which gear you use since you have to expend the same amount of energy.
No lie....lots of food and friends and conversation. I did help deplete the tarp offerings someone altho my better half was keeping me honest. I'm looking forward to the next one.
One place you might look is the first connector off the ignition switch. If you remove the plastic cowling above and below the ignition switch you'll see the ignition switch and the cable as it runs along the steering column. About 6 inches along there will be a plastic connector, either pink in color or white. Current for the starting the car runs through that connector and with age, the connections can go bad and the bad connection can make starting intermittant. Examine the plastic connector carefully, if the connection is bad it will get hot and the plastic will turn brown or black from the heat (I've even seen one actually melt). The fix is easy, find a newer ignition switch and cable at a wrecking yard or hardwire a splice around the bad connection using the correct guage wire or larger (I think it's AWG12 but it might be AWG10). You've already replaced the starter and solenoid so I think you'll find the problem there. There's also a possibilty the the switch itself is intermittant; replacing the entire cable and switch with one from a wreck should solve that problem also. I have seen this on three of the older EA81s that have passed through our family and it's a pretty common problem from what I can tell. Good luck. -
Removing engine without hoist
edrach replied to erikvr's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Easier said than done. -
Carfax please; JF2AT53B9EE500661
edrach replied to edrach's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks. -
No this is not Eric's Brat. This is the '84 that showed up on craigslist here in seattle recently; someone had posted the listing on the USMB and I went to look at it last Monday. I was a little miffed since the guy didn't take my money (I was willing to pay his asking price); he's fishing for a better offer. I'm on the fence now waiting to see if this guy gets a better offer or not and whether I'll still want Eric's Brat regardless. I'm still vacillating. Check out the post on this Brat: http://www.ultimatesubaru.org/forum/showthread.php?t=40984&highlight=FS%3A+%2784+Brat -
I hate to ask, but I will anyway; I'm considering buying this Brat and would really like a history and can't justify the cost of a month's service and the exorbitant rate for one. Please send to me at edrach@spamcop.net. Thanks in advance. JF2AT53B9EE500661
The model and size designation are stamped into the side of the base of the carb; e.g. DGAV 32/36. However, the DFV is a mirror image of the DGAV and that's the best way to tell the difference. If standing in front of the car and looking at the carb you'll see the choke module (either electric or water choke) at the very front. If the throttle plate is on your left of the carb, it's a DGAV; if the throttle plate is on the right of the carb, it's a DFV version. Did you say the webers are common in your area or was that someone else's post? If they are that common, can you consider pulling them and shipping them to the USA? It seems that new webers are becoming scarce here for some reason. -
RallyCross Update with pics link
edrach replied to edrach's topic in Meet n' Greet. Your USMB Welcome Center
Nice picture Matt. Sounds like a good day. -
Fat city in good EA81 parts at Lynnwood PAP
Vancouver is certainly too far away. But you have 7 Pick a Part yards in the Portland area, a regular yard at milepost 71 off I-5, and another pull a part yard just south of Olympia. -
There seems to be a flood of EA81 cars that recently went into Lynnwood PAP. Gold EA81 wagon ('82) with 104K on odo! Might have hydraulic lifter engine but the labels are not on the valve covers, but the color indicates hydraulic. 4WD d/r tranny. Gold EA81 wagon ('84?) with 203K on odo. Another 4WD d/r tranny on this one. Blue two door EA81 hatch with round headlights and cool paint trim on door and 129K on odo. Again a 4WD d/r tranny and clean center exhaust pipe. Engine is gone...sorry, Dr. RX and I pulled it this afternoon; but tranny would be a piece of cake to pull now. Red Loyale wagon went into yard today; I didn't pay much attention to it since we were busy pulling the engine. Best to bring cash today; their bank's computers are down and they can't charge anything on a credit card and they don't take checks. Seems that virus going around is still wrecking havoc.
The Super Pro bushings have arrived!
edrach replied to WJM's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks for the effort; I can wait until you find my order. Drop me a PM when you're ready and I can give you a UPS shipping address or US Mail whichever is easier for you. -
I kept coming into the tight spots too fast; on my third run I was completely sideways at the bridge and took out one side of it....that's more cones than I've hit all year! -
Jeanne is coming with me; anything we need to bring?
It was fierce out there this weekend; and hot too. -
Spalding Auto Parts is first class; and they are right across the street from the local Pull a Part yard. Baccaruda could give you an address or directions; I know how to get there but don't remember any of the street names.
LSD ratio conversion vs. gear lash adjustment?
edrach replied to baccaruda's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Andy, the point is you are putting the LSD kernal into a diff housing with the correct ratio, gears, and LASH. As long as that is the case you are not changing anything other than adding the kernal. Frankly, if the guy doesn't know enough how to change that, he shouldn't bid on it and not hassle you. -
Traffic coming home was the pits yesterday. I usually leave the event around 6pm and get home at 10:30 or so. Yesterday, I left at 2pm and got home at 9pm!! Stop and go traffic on 26E; a fatal accident on I-5 caused a tremendous slowdown; stop and go from Chehalis north; stop and go from Olympia to Ft. Lewis; finally from there on, traffic was able to move at the speed limit.
