edrach
    2
Everything posted by edrach
  1. Used the body of the O2 sensor; this sensor is only a single wire; gets it's ground from the body of the cat. Funky reading uninstalled is really a better reading. From what I read on another thread, O2 sensor should read between 500 and 700 mv.
  2. You might have the same alternator problem: http://www.ultimatesubaru.org/forum/showthread.php?t=38211
  3. Well, get cracking so you can turn on the lights!
  4. I haven't bought a new car since 1988, but at that time I walked out at least 10 times. By the time I got home, the phone rang and the salesman said he had a better offer. I went back and it still wasn't where I needed to be. Walked out again. Ignore all the financing bull, it's just there to confuse you. I had financing arranged through my credit union and knew what my price had to be. After about three weeks performing this back and forth dance, the dealer finally met my offer. Of course my timing was better, it was in November and the dealer had to make room for incoming next year's inventory and nobody else was offering any money on the truck I was interested in. Take your time and keep working it; as long as you show you aren't desperate you have the advantage. If your offered price is too unreasonable, he won't call you back and that tells you that you might be out of a reasonable range. When I picked up the truck at that time, the salesman introduced me to their accountant who showed me the printout on my truck and indicated I had purchased it at $50 under their cost. I think he was just joshing me to make me feel good. Whether or not that was true, I got the truck for the price I could afford and I was happy. Just remember that every month that car sits on their floor, it's another interest payment to their bank. Eventually, that comes into play and they come out ahead if they can get it off their books. If no one else buys it, you might get it at your price. Good luck.
  5. Having been rear ended twice in my Legacy wagon in the last year, I could use one of those!
  6. Starkiller was over here today and we tried to make some headway on his car's pinging problem. Car is an '89 SPFI wagon with manual tranny if that helps any. The obvious things such as timing and advance have been checked and are as they belong. He's running hi-test and it pings and gives a code 32 for the O2 sensor. I put my DVM on the output of the existing O2 sensor and I got a very low reading...around 10 mvdc. I unplugged that O2 sensor and plugged in another (used O2 sensor) without installing it in the cat and got a reading of 375 mv. I installed the second O2 sensor into the cat and got a reading of about 75 to 80 mv. I noticed that the original O2 sensor was quite white (too lean I thought) and pulled the number one sparkplug and it too indicated a very lean burn. After re-installing the #1 sparkplug, I unplugged the MAF and noticed no change in the reading of the O2 sensor or of the idle. Now I think I may have a bad MAF making the ECU think there's too little air and causing the lean condition, or whatever controls the mixture is ignoring the O2 sensor reading, and lastly maybe a restricted port in the throttle body. Qman suggested that maybe the temp sender is giving a false reading to the ECU of engine temp; temp guage was at a 1/4 for a partially warmed up engine and the sender measured 62 ohms. Any other thoughts or other suggestions out there?
  7. Paul, I lived 35 years in north Jersey and I still take a double take on the Brooklyn RallyX in Washington. Old instincts die hard.
  8. So when is the House....err, garage warming party? Nice job!
  9. I'm with Skip on that one; if you have the hitachi distributor, I'd replace the ignition amplifier module if you have no spark with the engine turning over. Best to get one from a wrecking yard since new ones run $100 to $200 depending on where you buy it. There's a similar item in the ND distributor, but I have no experience as to the reliability of those. On my Brat I have tested, used spares in my glovebox for the eventual failure. I don't know what's the problem with the Accel coils; I put a yellow Accel on my Brat three years ago and it's never given me any problems.
  10. The two alternators just quick putting out any voltage. Battery looked entirely normal until I had a meter on it and was wiggling the one terminal and noticed the meter reading drop to zero. I had a devil of a time convincing the parts shop that the battery was bad (only two weeks old also) since it didn't always fail when I wanted it to.
  11. It's not likely that the alternator failed while you were testing/checking. Take it back for a refund or exhange. The only thing I know that will wipe an alternator is an open circuit in the battery while the engine is running. I had an intermittant open in a new battery that took out two alternators on me before I found the cause.
  12. I'd just settle for foolish! Go Austin. Somebody buy his brat already; it really is the best deal going. I don't quite understand why he hasn't put it on ebay....too much grief and hassle I suspect. He should try to bring it to MN; bringing it into the rustbelt should improve it's chances of selling tenfold.
  13. That's for sure; especially Woodinville which has turned into Yuppieville.
  14. 4 turns out indicates you need to replace the primary air jet (likely two sizes); I wish I could remember which way. --ed--
  15. The golf course is still around, but I think Bob's is gone. This area must have been farm country when you were here. You'd likely not recognize it anymore.
  16. The rallycross school will be June 24th (evening), all day on the 25, and a rallycross on the 26th. It will be at the Red Lion Inn, Hillsboro, OR. Contact Paul Eklund at Primitive Racing. I think the fee is $150 or the weekend and includes the entry fee for the rallycross. I'll get you a better address as soon as I find it. Here's the link to the previous RallyCross school last March. Except for the date changes, the info is pretty much the same as the last one. It should be better since I think there will be a lower turnout since it's rather poorly publicized this time. http://bbs.subiesport.com/forums/calendar.php?do=getinfo&e=10&day=2005-3-20&c=1 Here's some pics I found from the last one (I hope you have broadband; a 56K modem will drive you crazy): http://forums.evolutionm.net/showthread.php?t=128896
  17. If you happen to see bratcrazy at this event, ask him to drop me a PM. Thanks.
  18. Glen, you absolutely deserve a medal for perseverance on this problem! Nice work.
  19. It went together that easily! Maybe I should have charged you more! (Just kidding). Anyway, I think you got it right; maybe someone else can find Cameron's write up on the installation for the details. If you're two turns out on the mixture screw it's pretty close to correct for the idle jet; my understanding is 1-1/2 to 2 turns out for the mixture.
  20. Fake mud; I heard about this on the radio today. Yuppies buying fake mud so they can look like they've been off road. Weird. http://techdirt.com/articles/20050610/0750239.shtml http://weldon.neogenesis.com.au/?q=node/view/133 http://weblog.herald.com/column/davebarry/archives/015823.html
  21. If the wheels started with the standard '85 and up wagon wheels before they were chromed your problem is the wagon wheels themselves. These later model wagon wheels were prone to bending from day one....even when new; my understanding is that FHI even issued a service memo on the wheels years ago. I stopped using the wagon wheels when I had twelve of them checked at the local tire place and found 8 of them were no longer true! I switched to alloy wheels on my daily driver ('86 wagon) at that time and was never bothered by shimmy again.
