2
Everything posted by edrach
Check out the WCSS6 link in the members meet/greet forum.
No power to blower with new switch
edrach replied to moscow67's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I was wrong about the a/c relay. I have an FSM for an '86 GL wagon (shouldn't be too different from your car). I looked into the wiring diagram for the blower for a 4WD carb'd model--again, shouldn't be too different if yours is a different version or model. Anyway the manual identifies the blower relay as being in series with TWO 15 fuses (#1 and #2) which would BOTH have to be open for your blower to not work. The relay is located "in the instrument cluster"; I think that means under the dash in the area of the instrument cluster; I couldn't find any relay on the inst. cluster itself. Any the blower relay is in a cluster of four relays and the connector to it is white and the four connections have the following wire(s): RY, 2GW, RW, 2LR. I couldn't find the color coding chart but I would think red-yellow, 2 green-white, red-white, and 2 ?-red. The two fuses get their power from fusible link #4 but if that were bad lots of other stuff would not work. 12V power originates from FL4, goes through 2 fuses (in parallel) to the blower relay to the resistor block and then through the blower switch to ground. This sounds like a lot but you seem to have the where-withall to figure this out. Good luck. -
There are usually four in a row; I know someone else can tell you which one handles the a/c. -
Given I can find the time I think it would be great! And I'd support it.
I'm stumped too; normally this is pretty straightforward. The only thing I can think of is that perhaps one of the wire terminals was pushed out while reconnecting the harness. You might pull on each wire--there should be 4 on each side--and see if one comes out or moves a lot within the plastic connector housing (I'd suspect the junkyard switch side). After that, I think you're right about it being something simple but easily overlooked. I wish you were closer because I've had pretty good luck with that area. I don't remember a separate ground wire; I think everything went through the connector. You might search the board a bit; this has been covered a lot and there are some good drawings I've seen that might help troubleshooting. Lastly, have you checked the blower fuse since you installed this; perhaps something shorted during the install and the fuse went. Good luck. You might try Hondasucks; I think he lives near you. Lastly, check the air conditioning circuit; I think the blower gets its power from the ac relay and the relay or a/c fuse might be the culprit. -
Steel or Alloy? 14" or 15"? I have 14" in steel and alloy available. I expect to have them with me for sale at WCSS6 if they aren't sold before then. Seems to me there are lots available in WA/OR area on the Board.
Oil filters
edrach replied to Bajaman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Just a personal opinion, use a quality non-synthetic oil (I prefer Castrol GTX) for the first 10K miles or so before you go synthetic. Let the rings wear in first before you switch over. I've been doing my own oil changes for years now and drive what most people consider "beaters" but I usually don't replace them until I have over 250K miles on them. And then, it's usually because it's getting hard to find parts for them or I'm bored with it and have found something slightly newer. I currently own a '91 Legacy with 128K on it and I plan to keep it to 300K or more. I was changing oil religously every 2500 miles with a filter change every other oil change (only genuine Subaru filters). I got tired of changing the oil every two or three weeks (I have four other cars that I also do my own oil changes) so I've switched to Amsoil synthetic and change the oil and filter every 5k or 6k. Car seems to be happy about that. I generally buy my oil and filters by the case and the quantity discount is sufficient to keep me away from the low price stuff. -
Sorry for the obtuse questions; I wanted to eliminate the possibility that you got the wrong resistor assembly. At this point I'd try a 2nd switch from the wrecking yard; hopefully it's a free replacement (it should be--most yards "warrantee" their product to at least work). If the 2nd switch yields the same results, I'm a bit mystified. It could be troubleshot with a multimeter but it would certainly take some time. Just to eliminate the possibility, was the resistor assembly intact? All the coils continuous and all of them soldered properly to their posts? There should have been no broken wires. Again a multimeter to do resistance checks might be in order since it's just possible you got a damaged resistor assembly. I'll get back to you later on this as soon as I have a chance to research it a bit. -
Did I understand you correctly? You've installed a new resistor assembly as well as a switch from the salvage yard. Just for comparison, what did you pay for the resistor assembly? -
Humble Nuto has the right idea. I used the original 5 speed mount and then extended it with multiple staps of stainless. It makes a world of difference....with the center just dangling the exhaust system has an annoying resonance at highway speeds. Wth the center supported it's okay and much better. I'd take a pic but my kid has my camera. By the way, Mick, the breather went off in the mail today. You might have it by Saturday if the P.O. is on the ball.
sorry, but....
edrach replied to Snowman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Some of the older GM cars required you to raise the engine 3" to get to the rear plugs!! A friend got rid of that V6 real fast after getting a whopping bill for a "routine" service. When he asked why so much the dealer told him "we need to hoist the engine to replace the 'plugs." -
I've been looking for a decent radiator shop since moving out here from Delaware. I might consider sending a used rad down to you for "re-conditioning/checkout." Thanks for the info.
I would like to get a FSM, where?
edrach replied to Alex C's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Two more options for you: www.books4cars.com. Also, Bentley has a manual (a re-write of the FSM which is actually better than the FSM) which covers models up to 1984. The Bentley manual can occasionally be found on ebay. Books4cars had one a while back for $50 plus shipping. If you're really desparate and investigate the Bentley manual and decide it will work for you, I have a copy I would let go for $40 plus shipping. Also, don't forget Amazon.com, they have a complete listing of used book dealers and can sometimes come up with amazing deals. Best of luck. -
The low temp thermostat won't make a signifcant difference. With the engine overheating both thermostats are wide open anyway; with the 180 degree version it just takes a little longer to start overheating since it opens earlier. Depending on the age of the car and radiator you have, if the temp guage climbs higher as you go faster or up longer hills, the only way to dissipate the heat is with a more efficient radiator (i.e. new, although double row is best). Don't waste your money on a radiator flush....they don't help a twenty year old radiator. Put that money to a new radiator instead, you'll be glad you did.
Cool, good of you to post this. I was thinking of changing to a cone type K&N filter from the low profile weber air filter since I think there's a bit of air flow restriction if I'm not using the full height filter. I guess I might go with the chrome round one that you selected. I wonder if K&N makes filters for it?
14" pug alloys at lynwood PAP
edrach replied to SuperRallyRoo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Actually, they're not as evil as I've been lead to believe. My oldest son won Truck/SUV class last year with his '82 Brat. When I was running it with him on the first rallycross of this year, the idle was a bit low so I went to adjust the idle and found his car still had a carter/weber carb! He won that event in class too and was third overall for the day. Not too shabby for a single barrel carb! -
which clutch disk do I need?
edrach replied to subiemech85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
A valid assumption; but in 20 years people put weird things into their cars when they should know better (sometimes they don't because their mechanic doesn't tell them). I learned this the hard way when I found an engine from a 2WD hatch in our '84 4WD wagon and found I ordered the wrong clutch for my car. -
That's certainly true providing you originally had the 8-7/8" diameter clutch disk. I can't tell you if the turbo clutch would work. Get a good quality clutch (LUK, Sachs, original Subaru) and you should be okay. In my conversion, I went with changing the flywheel to the EA82 version so all the parts are from an EA82. Only a slight modification needed to the casting to have the EA82 flywheel clear. -
Attn: McBrat and others who can help???
edrach replied to biffanyus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Tommy, you have one of two problems. Most likely a bad ground connection somewhere; if it worked before, a bad ground could make this happen now with all the strange symptoms that you now have. How to fix it? Re-wire the original headlamp connector to a set of relays....one relay for low beam and one for high beam. Wire the coil side of each relay to activate on high or low beam accordingly. Use the current carrying contacts on the relay to carry battery voltage directly from the battery to the high or low beam lights that you have now. Make sure there's a fuse in line with that powerline. If you search the board a bit I'm sure someone has posted a wiring diagram. I could mail you what you need but I'm not clever enough to put it into the computer and send it to you that way. Also, change the title of your original post to something more specific....like Headlamp problems with '82 Brat. You might get more looks and responses that way. -
Brat runs with some issues....
edrach replied to Caboobaroo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm not the expert here, but the stock fuel pump on my '84 Brat only generates 3 PSI of pressure. I think you need to go to the fuel injected engines to get more fuel pressure. Since you have looked at the fuel pump, I assume you replaced the filter there as well as the separator (looks like a filter) in the engine compartment. I'm guessing here since I'm not sure what a '79 Brat has in the way of fuel delivery. With the age of the car, I'd make sure the electrical connection at the fuel pump is good. Lastly, if your car has a vent for the gas tank make sure it is not clogged somehow....as you use fuel, a vacuum builds up in the tank making it harder for the fuel pump to deliver fuel. A quick test is to take a short drive with the gas cap off and see if the problem goes away.
