2
Everything posted by edrach
http://www.ultimatesubaru.org/forum/showthread.php?t=109567
Who's Got a 1982 FSM?
edrach replied to the sucker king's topic in Old Gen.: 80's GL/DL/XT/Loyales...
http://seattle.craigslist.org/sno/pts/2559021645.html -
I'll be looking to bring stuff also. Hoping to do inventory this weekend and publish it then.
Changed the steering wheel on my '97 Impreza with a newer one from an RS. Made sure to use the original airbag unit. I'm not sure that light wasn't on before the switch (scan gauge in the way so I didn't see this right away). Is there a reset on the airbag light since I had to remove the positive cable from the battery before I made the change?
With it vibrating at 65, does the vibration stop instantly when you let off the gas? If so, you might have a bad DOJ (inner) joint on one axle. Check the axle boots for a torn boot; if so, replace the axle with a known good used one or try one of the suggested rebuilders here on the Board. I prefer MWE myself.
I can only tell you that I have 205/55-16 tires on 16x7 (offset 55mm) RS rims on my '97 Impreza wagon. I have about a 1/4 inch of clearance on the rear between the tire and strut. Based onthat I think your 225/16 would rub; not sure what effect the offset would have. Only way to tell is to try a test fit; the rears would be the most critical.
Factory part # for '85 oil filter...??
edrach replied to starkiller's topic in Old Gen.: 80's GL/DL/XT/Loyales...
SOA5165100. Call Jason in Parts at 1-866-528-5282 for the best price on these. This number might have been dis-continued in favor of the newer version. Either one will work fine. I usually buy them 6 at a time to spread the cost of shipping among a group of them. -
1984 Brat GL axle questions, plz help!
edrach replied to c0r3f1ght3r's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Try the local junkyards. I've never had any problem with any of the used ones I've pulled off with the axles I've found at the local pull a part yard. For new you'd need to go to a dealer. I buy my new parts from Jason in Parts at 1-866-528-5282 (just tell him his internet 'site is too difficult to order with and he'll get you whatever you need at the internet discount). All he needs from you is a VIN#, address and credit card #. -
If you're working with the Haynes manual you're not getting the best source of information. Look on-line for a used copy of How to Keep your Subaru Alive (Volume 2 is the later edition, but Volume 1 covers your Brat). Should cost $5 to $20 from Amazon or a used book store. I know there's a pdf file floating around somewhere. Drop me a PM if you can't find it. -
Another old fart to the table. I'm currently on my 9th or 10th Subaru ( I have really lost count); however I still own a '97 Impreza wagon (215K), a '99 Forester which my wife drives (155K), and a couple of Brats (118K and 195K)---one for work and one for eventual re-sale. I normally buy my cars at 100K or so since the cost of the timing belt service usually persuades the average owner to sell at a lower price, have the work done by a mechanic I trust (I do a lot of my own work, but I leave the timing belt service to others), and keep them until I sell them (still running at around 250K or more). $20K will buy you any number of Subarus, even some new ones off the showroom floor. I'm partial to the Impreza model since it is a little sportier than the Legacy line. I'm not interested in a WRX or STi since I don't need the expense or bragging rights. I like the early '90s models since Subaru went to an interference engine in 1997 and prefer the 2.2 liter engine for reliability and the 2.5L (rebuilt--look around for other posts on why) for a little more power even if it is an interference engine. I'm not partial to the 6 cylinder since the cost of routine maintenance goes up and I don't need that much power. I prefer the earlier cars since the current crop of Subarus have become much larger than I like. Here's a pic of my daily driver and play impreza: http://www.ultimatesubaru.org/forum/album.php?albumid=17&pictureid=1182 Do some research here and decide what you like. Drive a lot of models to see what you would prefer. I think you'll find the transition from your Volvo experience to Subaru pretty easy. As to your question about rust, I couldn't tell you. I moved to the NW from northern NJ over 20 years ago and rust is not an issue out here. I'm sure there are others that post here that are local to you (nipper or moosens) that could give you an educated opinion on rust. A dealer certified used car will cost you much more with or without the dealer warranty. I've always bought private seller and check out the owner as well as the car to see that it's been treated well (lots of paperwork is very re-assuring). I'll also spend $120 or so to have the car inspected first by a quality mechanic; not that I don't trust myself or my instincts but I don't have a shop or lift to do a thorough inspection that a good shop will do. A warranty can always be purchased if you want one. Me, I'd rather save the $3 to $5K up front than give it to a dealership for work that might never need to be done; if I'm unlucky, I'll have the $3k or $5K still in the bank.
Help me hack my ignition switch.
edrach replied to fattie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Our locksmith swears by tri-flow. -
Results are posted: http://www.oregonrally.com/
Certainly sounds like a bearing whine. Too high pitched for me to think it's the front differential. And since the wheels are off the ground, I don't think it's the center diff. Since the wheels are off the ground, I take it you don't hear the whine while in neutral (or Park) with the engine revving up and the wheels on the ground not turning.
Replacing the speedometer with the LCD version.
edrach replied to edrach's topic in Subaru Retrofitting
My '97 Impreza does have a split cable about 8" from the transmission end. I suspect it's just there to make it easier to swap out; i.e. if the break is at the lower portion, replacing just that portion is easy. If the break is the longer upper portion, just slipping the cable out of the sheath might make it easy to fix. Somewhere here on the USMB someone posted a link to the speedo cable and part numbers. Darned if I can remember where. In any event, the junction of the cables on my Impreza is just that with nothing between them. My VSS is generated by reed switches in the speedo portion of the cluster. It would be nice if earlier models had a sensor there because it would likely fit and be usable for my rally computer. Here's the URL, posted by you (thanks). Found that on the companion thread I started when this forum didn't get much response. http://opposedforces.com/parts/impreza/us_g10/type_99/manipulation/speedometer_cable/ -
Great news.
When I figure out how to install the sender in the two piece cable, the car's electronics won't even know it's there since it will only be wired to the rally computer. I was hoping swapping the speedo for the LCD version would work more easily, but I'm not into re-wiring the car. Too complicated for a simple guy like me. However, thanks very much for your information.
