2
Everything posted by edrach
Hard to do since he lives in Bolivia now. But it's a good thought. There's certainly lots of space available on my Impreza. http://www.youtube.com/pdxrallynw#p/u/6/TbnYDCxWO4I http://www.youtube.com/pdxrallynw#p/u/5/YajXjJEVCJ8 http://www.youtube.com/pdxrallynw#p/u/4/4HoBVlQw1W8
Yep, fan switch. Read all about it here: http://www.ultimatesubaru.org/forum/showthread.php?t=118301
center diff?
edrach replied to Suba9792's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Yes, you have a center diff in your 5MT transmission. It's a viscous type in the rear third of your gearbox. It wouldn't show up as slippage while driving since it's only function is to allow you to travel around corners without the inside wheels and outside wheels binding up. Typical symptom for a bad center diff is "lockup" going around corners in either direction. -
Rear Disc Brakes 4wdvs2wd?
edrach replied to aaronxs400's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My experience has been that the 2wd and 4wd rear brakes for the same model are the same for all parts except the backing plate. -
Tell me about EA81 weber conversions.
I don't want to rain on your parade, but you have to have at least two dyno runs (one before and one after) to make any quantitative comparison. And then more runs if you wind up re-jetting the weber for optimum performance. -
I have some of the pug lugs for steelies.
Not going to happen because of cost and time considerations. Ask a shop that has a dyno what they charge to put your Brat (or early GL) on there. Then take the time to change over the carb and then pay again to put it on a dyno again. Two dyno sessions will cost almost as much as a weber conversion all by itself. That being said, I've done three weber conversions to our Brats over the years and have never been unhappy with the result. The weber is less problamatic than the Hitachi and it's such a joy when that secondary opens. I've never felt a dyno run was required to appreciate the improvement with the conversion. -
Glad to see you found another one so quickly. Best of luck with it.
Broken Key in Ignition
edrach replied to soobenthusiast's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That part is easy. Some dealers still can make you an original key from the VIN number (bring your ID and proof of ownership). If that doesn't work, remove the door card from the passenger side front door and gain access to the door lock cylinder. Using a flashlight and mirror copy the key number off the cylinder (something like W334) and take it to a quality locksmith who can make a master key from that number. -
General Mechanic Questions??
edrach replied to SnowRat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Weber works well (much better than the original) and is a significant improvement. I think a full write up can be found in the old USRM forum. A torque cam would also help in getting more "dig" out of your motor. http://www.deltacam.com/tech.php?p=3 would be your best bet. Just a comment, If I remember correctly the '84 GL wagon in a 4WD version was only a 4 speed. If you truly have a 5 speed, either someone before you made the conversion :banana:or you actually have a FWD transmission:eek: which did come in a 5 speed version. -
Better hurry; today's the last day until mid January.
I found some of the cached pdf files here: http://www.google.com/#q=site:endwrench.com+endwrench&hl=en&prmd=iv&ei=7SoETejrHcKmnAeIu_nlDQ&start=90&sa=N&fp=c9f200e8d6433b2a I printed out all that I could so I now have hard copies of them. I couldn't figure out how to save them to a directory on my computer. Sorry.
Thanks for saying that GD. If it were still $70 if might be worth one's time to make your own. But being able to get a new one for under $40 makes a lot of sense. And it will probably last you for 10 years before one of the new coils burns out. A do it yourself one might need replacing every two or three years.
I knew there was more. Found this in the OLD USMB Repair Manual. http://www.indysworld.com/80s/general/USRM/mick-usrm/resistor-pack/resistorpack.html
Replacing Muffler, got questions
edrach replied to NV Zeno's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Dave, As always, which car are we talking about? Anyway, the front portion of most stock Subaru mufflers are terminated in a flange with two bolt holes and sealed with a gasket. Only problem might be the bolts are usually rusted together so be sure to have replacement hardware as well as the gasket. If you have a really good rust penetrant (Yield is the best, Kroil is okay), soak the bolts the night before you plan on working on it. If you have an impact tool, it might make removing the old hardware easier. When you re-assemble it, put some "never-seeze" grease on the new hardware. This will make it easier to do the job next time. You should be able to do this yourself. Drive the rear of the car up on ramps and firmly chock the front wheels so the car can't roll off the ramps. You should be able to do that (if I can---and I have, many times---so can you). -
This thread actually has some resistance and wattage readings: http://www.ultimatesubaru.org/forum/showthread.php?t=92990&highlight=blower+resistor+block
I did a quick search and found this interesting item in one of the threads: I received a reply from 1stSubaruParts.com (1-866-528-5282): Quote: Here is the part number you need to order 72083GA070. Thanks Jason 1-866-528-5282 begin_of_the_skype_highlighting 1-866-528-5282 end_of_the_skype_highlighting Sincerly, 1stVWParts.com Go to https://www.parts.com/partlocator/in...?siteid=213799 then in the section "Search by OEM Part Number:" type (or Paste) 72083GA070, from the "Select Make" listbox, choose Subaru, then click on Search. It comes back with: Air conditioner and heater - Blower - Resistor, 1990 - 1994, $37.46 . I think I'll order one come payday.
If you're building your own controller, you need to understand you have to dissipate a fair amount of wattage to reduce the speed of the blower. The reason Fuji is using coil resistors is that they are quite low resistance and in the neighborhood of 50 Watts. That's also why the resistor block is in the air stream of the blower....to cool the resistors while they are working.
Do a search on this; it's been written up numerous times. Trying to duplicate the coils is pretty difficult. Don't limit your search for the part to EA81 cars; it's the same resistor block in the EA82 cars and the chances of finding a good resistor block is much better. I'm not sure since I never tried it, but early EJ cars might have the same resistor block.
