2
Everything posted by edrach
Help! My brat is dead on the side of the road.
edrach replied to Wirebrush's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yipes. Under $10 at pull a part for the module. Last time I considered buying a new module it was $90, 125, and 190 depending on how long the "lifetime" warranty was. I bought the $90 version; still ticking after 8 years! By the way, don't buy it at Schucks.....old wives' tale that says their module fails within a week of jump-starting someone else's car with yours. That's what the guy at B&B told me when I bought that $90 module when he saw my old one. After that I collected a bunch from Pull a Part and there was one in the glove box of every EA81 car in our family (four at that time). B&B would test my "old" module for me. Just make sure he hooks up the ground clamp solidly, otherwise they "fail" every time@. -
If you have spark, I'd bet on the fuel filter (the one next to your fuel pump); replace the fuel separator in the engine compartment while you're at it. If you don't have spark AND have a Hitachi distributor my money is on the ignition module inside it. Expensive to buy from the autoparts store ($100 or more) and very cheap from a u-pullit wrecking yard. Easy to replace also. -
All warning lights on all the time
edrach replied to quicsam's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Which car; I likely have a working alternator for you. -
Typical symptom of diode trio failure in the alternator. Replace it with a wrecking yard one or have it rebuilt by someone local. -
I don't want to rub your nose in it, but this just showed up on CL locally (to me). Paint job is weird and price is funny (I suspect with an airbag deployment it has a salvage title). http://seattle.craigslist.org/see/cto/926302360.html Dont give up on Autotrader; I know most of the ads are overpriced or high miles, but I got ours there after many months of looking. 120K miles and at the time $3950 was a steal; and to boot, it was at a small roadside dealership 4 miles from our house. It has 155K on it now and is my DD as well as rallycross car. Sounds like you might have a deal with Dave. We bought our Forester with a similar arrangement with a USMB member. Good luck in your search. By the way the EJ18 is a killer engine along with getting some of the best gas mileage for an early Impreza.
Good luck. There's one out there for you; it'll just take time to find it. I got ours four years ago and it took 5 months of ACTIVE searching. I'm sure you've tried craigslist. You might try autotrader if you haven't already. The good news is that the price and availability have improved a lot since four years ago. Good luck. I just rechecked your post for a location. If it's practical, you might search on the west coast. Once you find it, fly out and drive it home. I'm sure we have more rust free Imprezas out here than in Pittsburgh.
This problem has been beaten to death pretty often. The final conclusion is that the wattage is pretty significant; that's why Fuji uses the blower to run air over the resistor block to dissipate some of the heat. Best bet is to hit the pull a part yards and pull one of these until you find a good one (been there, done that). Good luck.
Welcome to the Board and congrats on getting a real fine Brat. First thing is make sure it is insured for full replacement value. You might try Hagerty's insurance (google them) to supplement what your liability insurance carrier will not cover. Also, check the current posts on the other new Brat that showed up last week and learn from the advice he's gotten. Lastly, get a copy of How to Keep your Subaru Alive; it'll give you minimal but important information to get you started. Buy the 2nd edition; it's usually found on ebay or amazon for around $20 plus shipping. Good luck with your new baby!
Speaking of t-tops, clever design. The outer edge acts as a moat to catch any rain water and the water then drains off through the drain hole in the corner of the t-top channel. The rubber seals actually do very little to keep from leaking; it's all done by draining off the excess. It pays to take a long skinny rod (or straight coat hanger wire) and gently poke down the drain hole to make sure the drainage is not blocked.
I notice from this picture that the muffler's exhaust pipe doesn't stick out from under the rear bumper. Get an extension on the muffler as soon as you can. I've seen Brats where the extension fell out of the muffer and it was never replaced or a new muffler installed. What happens is that exhaust gases mix with moisture in the air and it forms an acid (I don't remember which one) and causes the underside of that corner to rust out prematurely. Considering that the rear bumper attaches to the body at that point, rust here is pretty critical. The sooner you prevent it the happier you'll be.
pics of the new(*to me) brat
edrach replied to roadtojoy123's topic in Old Gen.: 80's GL/DL/XT/Loyales...
T-top locker hardware will clean up with WD-40. T-tops show up on ebay all the time (I have a spare in my garage). You can likely fix the oil pan leak by snugging up on the bolts with a phillips screwdriver. Do not over-tighten; that'll just make it worse. There's a trick to replacing the gasket by removing the oil pan without pulling or raising the engine. Check the USRM or do a search. I've done it but I've forgotten the trick. I think the oil pan and valve cover gaskets are still a dealer item. Check with Jason in Parts at the former Auburn Subaru (Toll free: 1-866-528-5282). Good discounted prices and reasonable shipping. The dash from an EA81 wagon will fit your Brat. Don't take that job on lightly. I've done it with Turbone's help on our Brat and it took the two of us close to 10 hours to do it. If you have a cracked windshield and you're planning on having it replaced, remove it, replace the dash and then install the new windshield. It'll save you some time. Once you replace the dash, give it a coat of armoral every now and then to keep it from cracking again. -
It looks like it's been well cared for but I'd suggest: Oil and filter change. Change transmission and rear diff oils. Flush and replace antifreeze mixture. New sparkplugs (use only NGK) and air filter. Replace fuel filter (the one down by the fuel pump) and the fuel separator (looks like a fuel filter in the engine compartment). I know this is all pretty routine, but if you don't know the history of past work, this pretty well starts you off without missing the obvious. Find a copy of How to Keep your Subaru Alive so you can enjoy working on your new treasure. -
Really nice. Best of luck with it. -
That's probably correct for a Legacy Outback wagon since that's what the tranny chart shows. However, Fuji was notorious for installing whatever transmission was available at the time. Only way to tell is to check the TY number on the bell housing or engine compartment VIN plate. From the USRM: Too bad I couldn't print out the form for convenience. http://www.northursalia.com/techdocs/trannychart/trannychart.pdf[url=http://www.northursalia.com/techdocs/trannychart/trannychart.pdf][/url] To identify your transmission look for a label on the bell housing near the starter motor. My '97 Impreza has one reading 6Y-TY752VA5AA. I don't know what the 6Y means, but the TY etc. is what's important to identify your gearbox.
let me introduce myself
edrach replied to chwyroo's topic in Meet n' Greet. Your USMB Welcome Center
Welcome to the Board. You'll find lots of people here to help you with your Brat. -
Just got the weather report on the tube, and Hillsboro got .41 inch so far with continuing rain scheduled for Saturday. It should stop raining on Sunday morning.
That makes much more sense.
Using the miata tire calculator, I get a ~ 9% difference using 205/50-13 tires. Tire Size Comparison Specification: Sidewall__Radius__Diameter__Circumference__Revs/Mile__Difference 185/70-13:__5.1in__11.6in__23.2in__72.9in__869__0.0% 205/50-13:__4.0in__10.5in__21.1in__66.2in__957__-9.2% Back to the Calculator
Brake bias valve
edrach replied to ()__1337_CRAYOLA__()>'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've done a dozen or more conversions on Brats and early EA81 wagons. I never worried about the proportioning valve. Just attached the brakelines at the caliper and bled the system and done. It was never an issue. -
Make sure that the water cooling holes are in the same place; I think they might be different between the EA81 and EA82 manifolds. Send a PM to bratsrus1; Jerry has adapted an EA 82 manifold to the EA81 heads and could answer your question better than I. He might even have a manifold for you that was already machined to work on your engine.
215's are definitly too wide for the rim unless you find some 7" rims in a 13" diameter. A 175/70-13 or a 185/70-13 should do you fine. You could get away with a 195/70-13 on a "normal" sized rim for your brat, but no wider. Check the miata tire size converter to see what kind of error you would introduce with a 50 series tire. Somehow you might be missing a point with your choice of tires. The 50 (or 70) refers to the aspect ratio of height to width; a 50 series tire would be 50% as high as the tire is wide. You certainly wouldn't save anything on weight since the added width would make up for whatever you saved on height.
90 legacy L AWD
edrach replied to Uberoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
That's probably why the early models that had a limited slip rear were VLSD (viscous) diffs rather than LSD (clutch). Only people who could tell you are the ones who added a VLSD or LSD to an early AWD Legacy or Impreza for competition improvements.
