desperate
Location
roanoke
Occupation
business owner
desperate's Achievements
Advanced Member (3/11)
10
its an 5 psd push button 4wd. Itss goin up for sale I don;t have the time to deal with it any more. thanks for all the help guys!!
subyrally nailed it. I could have sworn i had them right... yeach me to be sure of something like that. new problem, MASS amounts of white smoke. doesn't smell sweet like antifreeze burning, doesn't smell like oil at all. just ALOT of white smoke. Any idea? last time the car was driven enough to get to full boost is spooled fine, havn't drove the car yet, I don't want to risk messing anything up. no smoke anywhere else but out the exhaust.
got 12 volts on the red wire. got power to the injectors. I checked ALL fuses and link with a test light, they are all good. tried unplugging the maf and had no effect. was a shot in the dark but I thought I'd try it. I'm stumped. the gas has been in ther around a year, so i want to try running a hose from a gas can with fresh gas from the fuel pump and see what happens then. Doesn't really make sense if the gas is stale why it would run for a couple seconds then die, but i guess anything is possible. Sound like it might be worth triyin or am I barking up the wrong tree?
Its got a half a tank of gas in it, I replaced the fuel filter last summer. gas does spue out when you take the line off, at the intake manifold and the filter. I'm gonna get over there today and check the relay and amke sure its getting voltage like its supposed to
Can easily hear the pump for a second or 2 when you turn the key over to on. Is ther a relay or the injectors i'm not aware of?
Not entirely sure what the deal was with the spark, only thing I changed was tighten up the screw on the back of the rotor button and I had spark at the plugs again. I guess it was just a hair to loose. now for problem number 2. No fuel. spray carb cleaner down the intake, and she fires right up and runs as long as you spray carb cleaner. Anyone have any helpful hints on quarks with the MPFI fuel injection that I don't know? Thanks for all your help so far guys. sometimes I guess I need some one to point out the obvious:-\
After a few months of sitting and a few attempts at getting the car to start. i put new plugs and wires on the car(all other tune up items had previously been done, and yes by me). Hooked the battery back up, turned the key and what do ya know the car finally turned over and ran, for about 2 seconds. then it died. Did no spit and sputter miss or anything, it just turned off like you would turn the key off. would not do anything more han crank over which was wat it was doing before, i had spark and fuel before today. after the car died, it cranks but I have no spark and no fuel. I checked my fusible links and the ignition and fuel fuses under the dash and they are both still fine. I'm kinda thinking bad ECM. but before I jump to conclusions, any one else have any ideas?
theres a injector test I didn't remember. I'll try that as soon as I can get back to the car. hot blue spark, tried the fusible link thing, even moved a few around with no effect. I'll do the screwdriver test on the injector and if I can confirm fuel with that I'll try unplugging and replugging everything then flipping the disty around 180
the distributor wasn't taken off when I pulled the passenger side head off. and it ran fine before that. I tried losing the bolt up and turning it while I had some one crank it over, and it made no difference at all. Head was torqued down correctly, and it never rained or anything while I had the head off, no rust, even surface rust on the cylinder walls when I put the head back on it. on the distributor there are 2 "ears" for bolts to go through, with those sitting on top of the bolts corresponding holes, can the disty still be 180 out? disty hasn't been touched since it last ran. I did check the rotor button to make sure it was tight and it was.
motor was rotated so the timing marks on the cam gears were 180 from each other. Made that mistake the first subaru I had. Also already thought about the rocker arms, dropped the valve cover hoping to see that one had come off, but all rocker arms are in place as they should be.
Car ran 2 months ago. pulled the passenger side head off to fixed a stripped oil line hole. Timing is set perfectly, I've got spark, I've got fuel. All vacuum lines are hooked up. The distributor is set according to the haynes manual. My firing order is hooked up according to the haynes manual as well. The knock sensor is broken, but it was broken the last time the car ran. This one has my stumped. It will crank over no problem, just won't fire up. doesn't even sound like it is trying to turn over. thanks guys anthony
gl-10 wagon won't start....
desperate replied to desperate's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Curt managed to point out my stupidity for me. I guess i had been up to long or something, never gottent hat mixed up on anything else before. the squeak was a melted timing belt cover. was rubbing on the drivers side right on top of the cam sproket. Got my delta cams put in, most everything hooked back up. We will find out tomorrow if we got everything right. I try'd to get it to start tonight, but after a few tries it wouldn't do anything but turn over, never would fire or run at all. I'm pretty sure the timing is set correctly, i think ther is something really obvious I'm over looking at the time. Hopefully it will run tomorrow after work. -
EA82T 87 GL-10 wagon. push button 4wd \Started and ran fine last night. belt was slipping a little bit nothing major. Went out this afternoon, tighten'd the belt up, put new plug wires on it. Went to start it, It will turn over, but seems like its onlt going through all of the cylinders once, then it will act like it died, and start trying to crank itself again.... I'm lost on this one, i need some help.. PLEASE??? Has gas in it, plug wires are all connected, no loose connections(other than what was taken off with the AC,. but it ran fine right after that) Any help you guys can ovver would be beyong aprciated. My loyale got tboned 2 weeks ago, and gettin this fixed, and an inspection and I'll finally be back on the road again:) thanks
I must say your wagon looks much better in mud than it does filled with bricks! that looks to much like work. its not new and doesn't have an aux for the ipod, but you can pull the radio and thing out of the loyale along with whatever else doesn't get pulled for my wagon. It'll last until you can get something better
my digi work flawlessly, thats why I'm looking for a busted one to use the plugs and things off of, so if I screw up the swap I have a working one to put in. Gary: thatd be cool. definatly worth a shot.
