JBRIII
Everything posted by JBRIII
Have a big snowstorm here. A lot of spining trying to get out where the snow's piled in the medians. Check Engine Light, ABS Light on, Cruise Flashing. R 55 where trip meter is. Car seems to run ok although rough idle a little. Checked with my code reader and nothing. Drivetrain covered in ice. Any ideas? Is it safe to drive? John
I used it last year. I really like the AIO Polish. The SG Sealant works better if you leave it on over night and buff off the next day. I don't have a grage so I used the wipe on, wipe off method. Did ok. Lasted at least 4 months, but didn't make may car truck pop, like a good carnuba such as #16, #26, or P21S. I still use the AIO as a base Polish before wax on occassion if the swirls are not too bad. If they are I step up to the #83 first, then top with #16. I order from properautocare all the time. Great company with outstanding customer service. John
Please do some research on www.autopia.org You owe it to your vehicle!! Dawn???? You are joking right? Your $30 Zymol is made by Turlewax btw. You can't go wrong with the Meg's Professional Line, 3M Bodyshop line, Klasse, P21S, Zaino, and many others. Read the review section. I'm not putting anything from WalMart or Autozone on our new 05 OBW. It's Meg's Professional and Bodyshop line all the way. #7 Show Care Glaze, topped with #16 Professional Paste Wax gives it a great shine and beads for months. All of this by hand. It is a new finish I use the #83 Dual Action Cleaner Polish on my 97 F150, as it is abrassive enough to remove cobweb's and swirls without damaging the paint, then topped with the #16. I use a Porter Cable 7424 DA Random Orbital Polisher to apply the #83 and hand apply and buff the #16. John
96 OBW Price
JBRIII replied to JBRIII's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Thanks............ Just wanted to know if we were in the ballpark. John -
96 OBW Price
Anyone have any thoughts? Too high, too Low? Would like to get it in the paper this weekend. Thanks for any help. John -
Guys, Selling my wife's 96 OBW. Dealer was offering next to nothing on trade in for her new 05 OBW. Car has had everything done. New Headgasket's (Heads Decked and New Vave Seals), Water Pump, Timing Belt, Cam & Oil Pump Seals, and new brakes. Less than 500 miles ago. Car has 115K and is in great shape. Any idea what we should ask for it? I was thinking the $4,500 - $5,000 range. John
2005 Obw
Coolant Loss
Looks like it's either the HG or a cracked head. The mechanic drove it home and it did fine, but when he drove it in this am it did the same thing. So they're removing the heads. Going to have them pressure checked. Replace the HG's and Machine the heads. If they're cracked we'll have to get new ones. Anybody have any idea what a new set of complete heads costs? John -
Coolant Loss
So far the guys at the shop have been unable to get it to repeat itself. One of the mechanics lives about 40 minutes away and he's going to be driving it back and forth. They did another leakdown and sniffer test in the radiator and they were both negative. They are thinking it's the thermostat possibly. Going to replace it and the hoses while they're at it. I'm wondering if the block heater may have some corrosion on it and it's blocking a coolant passage? -
Coolant Loss
so do you just live with them until they go? or would you replace it now? -
Coolant Loss
Thanks for the reply. She said she was going fast when this happened. 85+, keeping up with the flow. No letoff on the engine at all. The shop is doing another hot and cold compression test as well as hydrocarbon test. John -
My wife was driving her 96 OBW on the interstate the other day. Coolant was leaking, blowing all over and the car overheated. Couldn't find any splits in any hoses. Top radiator hose was colapsed. Coolant resovoir was overflowing. When I got there, big puddle under the car. Very little coolant in radiator. Had it towed to shop. They put some coolant in it to drive it to the bay. So far they can't find a leak. Was concerend a month or so ago about a HG leak. They did a leakdown and hydrocarbon test. Negative. I did an oil analysis, also negative. Any ideas what pushed the coolant out or how it got out?
Got the car back from the shop and they said they hear a slight knock at the front of the engine after it reaches operating temp. Is this anything to be concerned about? I use 10W30 oil. Do you think a 15W40 may be the way to go to help out. They recommened just watching it to see if it gets worse. John
