About Subarunation 713
- Birthday 07/13/1964
Contact Methods
Website URL
http://
Gender
Male
Location
Bridgman (SW Mich)
Interests
1990-1997 Miatas
Ezboard Name
only 5 speeds
Vehicles
1996 OBW and 1996 OBW
Subarunation 713's Achievements
Eat, Live, Breath Subaru (5/11)
10
Well here is the wrap up. Changed the water pump, idlers, tensioner and timing belt. Set the timing marks per the manual. Got all the sensors, plugs and wires back where they needed to be. Verified all of the connections I had already verified (nervous that way). Turned the key and it fired right up. After I knew it would run I double checked all the torqued bolts (nervous that way) and buttoned everything back up. Replaced accessory belts, cleaned out the radiator again (nervous that way.... can you see a pattern? ) and filled it with new coolant. Seemed like it took FOREVER to get all the air bubbles out of the radiator but I tried the tricks I learned from USMB over the years and sure enough got the air out and the coolant circulating. In retrospect if my other Outback -after driving 45 miles today- was to die tomorrow after running for 30-45 seconds I would probably trouble shoot the same way. I would do fuel delivery first then check for spark. If I had fuel and spark on 1-2 but not 3-4 I would probably go in the same order: coil if ok > igniter if ok > continuity if ok > sensors if ok > ECU. If you hear hoof beats look for horses. This was the very RARE situation when I heard hoof beats and looked for horses but it turned out to be a zebra. THANK YOU to everybody who gave suggestions and technical information. I truly and genuinely appreciate it.
Brief update. When I took the covers off and tried to see where the timing was the crank sensor and cam sensor were not even in the same ZIP code. The upper idler pulley on the passenger side of the engine was completely apart, ball bearings everywhere and it was so hot the seals had melted into little puddles. It provides no tension for the crank sprocket so the sprocket moves and randomly "pulls" the timing belt along. The water pump is indeed shot. Turns hard and grinds. The back of the timing belt has a continuous burn mark the entire way around the smooth side of the belt. Conclusion. Subarus are awesome! Any car that starts and runs for 30-45 seconds, in the condition the timing components were in on this car, is a VERY durable machine! I am glad we are a two driver family with four cars and a motorcycle so I don't feel any pressure to get this done RIGHT NOW!!! But I will keep you in the loop as I make progress. Right now I am cleaning up two decades of gunk..... well right now I am playing on the computer so I don't have to clean. :-)
I have continuity between the igniter and the coil and between the igniter and the ECU. Here in lies problem #1. My car is from 9-95 and my wife's is from 5-96 so our ECUs are different. Problem #2, the crank sensor would not come out of my car. I wasn't going to wreck a working sensor to see if another sensor was good or bad. If it ever has to come out it will be by breaking it apart. Since I had time and I had another task to do anyway I buttoned my car up and focused on my wife's. I took the timing cover off and all of the reluctor teeth are on the crank sprocket but the timing belt was SCREWED UP! The idler below the power steering pump (passenger side) was coming apart. I could see ball bearings in several places. I think the reason for the ignition issues was the cam sensor and the crank sensor thought each was speaking a different language the timing was so far off!! I am going to proceed with the water pump, tensioners, idlers, and timing belt and God willing I think it will run with no issues. I won't be back to it until Friday. I will report with the process. Thanks to everybody for their help and suggestions. I am grateful two things #1, wherever the car was last time my wife went anywhere that it got home. #2, that it broke down in the driveway and didn't go any further.
You and Fairtax4me both mentioned the teeth on the crank sprocket. Is this a high percentage option? I would think broken teeth on a running car would be a 0.0000001% chance. Has this become a higher risk thing on the EJ22? Please understand, I am not being argumentative, just curious. A broken trigger on a gear sprocket or an ECU where would you place your bet? I will see the sprocket soon enough. I do appreciate everybody's input.
Checked the plugs and wires. Continuity between the igniter and the coil and it isn't the igniter. I haven't been in there in a long time. Went from Greek Islands to Sammy's and I think it is Lydia's now?? Help me understand what you mean by reluctor teeth? and is this done without pulling the TB cover? I am thinking ECU after having checked the wiring between the igniter and the coil. Maybe tomorrow I will pull the ECU out of my OBW and put it in her OBW. It is nice we have two identical cars to swap things between. When I replace the water pump/seals/timing belt/idlers/tensioner I will have access to the belt and can see the gears. Still, the timing would not mean spark on half the coil and not the other. If it had jumped timing there would still be spark, just at the wrong time.
No Idea, I bought it used. The new one is in a box on the floor next to me. Don't suppose that helps :-) The water pump developed a wee drip so I got all the goodies including a new belt. Currently sitting with about 135K miles. ocei77, I found a good coil I had on the shelf and tried it. Same outcome. No spark on 3-4. :-(
Additional items tended to. Took off both battery connectors, cleaned connectors and posts. While battery was disconnected cleaned ground from battery to engine. While battery was disconnected (and brake pedal pushed for 30 seconds to rid any residual current) disconnected and inspected ECU connection. Visually no corroded or white powdery connections or pins. Again, only visual. While battery was disconnected I took of the ignitor, cleaned any corrosion off of mating surfaces and put di-electric grease of plug. While battery was disconnected I took off the coil pack and cleaned all surfaces and put di-electric grease on plug. Reattached plug leads but before doing so slightly spread all bullet connectors going into the coil and made sure they were clean and not burned. Reatttached battery connections. Spark on cylinders one and two but no spark on cylinders three and four. Remember it started normally and ran normally for 30-45 seconds before dying out. Background, this was a CO car for a large portion of it's 20 years. Things are clean and moderately rust free compared to my pile of rust that has been driven in northern IN and southwest MI nearly it's entire life.
Been a long time since I kicked around USMB. Tried searching but didn't come up with this one. We have two 96 OBW with 5 speeds and 2.2 engines. Here is what happened. My wife started up her car this morning and began to back out of the driveway. After running for about 30-45 seconds the car died and would not restart. Here is what was done (in order). Fuel before filter when key turned on? Yes, plenty. Fuel after filter when key turned on? Yes, plenty. Pulled spark plugs they were wet with gas. Checked spark, present is cylinders one and two but NOT in three or four. Took coil off of my car and put it on here car and her coil on my car. My car still ran, her car still no spark on the back cylinders. Took the ignitor off of my car and put it on her car and put her ignitor on my car. My car still ran, her car still no spark on the back cylinders. So I am wondering what causes the front two cylinders to have spark but not the back two cylinders? Open to suggestions! Thanks in advance.
Looking for "long ago" ej22/ej25 swap Web page
Subarunation 713 replied to Subarunation 713's topic in Subaru Retrofitting
Thank you! Too bad the photo link is dead but the discussion is the one I remember. Thanks a ton! As you can see from my post count I don't comment often even though this has been an EXCELLENT reference for nearly a decade. -
A long time ago on an USMB forum much different than today was a link for a 22/25 swap. I had it bookmarked but that was two computers ago. If I remember it was a dark green Outback. It had pictures and a real good writeup. I did a search but there are so many threads with "ej22 to ej25 swap" that it was nearly impossible to find. Do any of you "oldtimers" (or "newtimers with better search skills than me) remember what I am talking about and could point me in the right direction? Thanks!
