About 1Subaru1
- Birthday 10/31/1950
Location
Muskoka, Canada
Occupation
security
Vehicles
1999 Brighton Wagon
1Subaru1's Achievements
Advanced Member (3/11)
12
I just did plugs, wires, and coil on mine, which showed the same acceleration issue and it is now fixed. Used all Subaru parts per advice on this forum. Do plugs and wires first and see how that goes before doing the coil as mine was $225.00. Good luck.
Just arrived home. He did plugs, wires, coil(had to use it as it was ordered yesterday), all Subaru parts,cleared the codes. 1hr. labour. CEL is still out, and car runs well now (knock on wood). Good suggestion on vacuum testing, hopefully the CEL stays off for a while, but we'll look at that later. Thanks for your help. We had a foot of blowing snow today, people in town had problems getting around, people on the hwy went slow; this old Subaru goes through snow as if it wasn' t even there. I love this car! I call it the Pack Mule - pack it up, point it, and go.
1999 Brighton Wagon 2.2L auto, 257,000 kms: Just spent 2hrs typing up descripition, then lost it somehow , so I'll be brief. Car runs rough under acceleration, either from a stop ,or trying to pass a car. Ease into it gently and it is fine. Stomp on the gas and it runs rough. CEL is on , has been for years, but the car has run really well up until now. Took it to mechanic, a Subaru fanatic, and we checked the diff. fluids - both are clear and clean and full; same with transmission fluid. Car seems to shift normally. Put the car on the hoist and I drove it up to 100 kph on the speedo as mechanic looked at the car from various angles. It ran rough when I gave a good dose of gas. The right front wheel seemed to rotate a bit faster than the left front at slow speed Stored codes off the ECU scan are: P0170, P0304 - cyl 4 missfire, P0440 evap. Cleared the stored codes and put a new fuel filter on it. Mechanic suggests that the next step is to change plugs, wires and coil tomorrow. Headed out,drove slowly and easy, even on the hwy, cruised 115 kph easily. Tried to get it to act up by accelerating hard up a hill; car acts up and CEL flashes 5 times then goes out and engine smooths out. 5 minutes later the car acts up, smooths out as I let up on the gas then CEL comes on and stays on. The car is in really good shape for its age, and I would like to keep it, but this is getting expensive. Any ideas on WTF is going on? Thanks. Yours, Steve
I have a 1999 Legacy Brighton Wagon, 2.2l, auto. A neighbour has a 1996, or 7 Outback (2.5l I think) auto which he is going to have towed to a wrecker. He said I could take whatever I want off of his car for spare parts. Any suggestions on what I should harvest? I'd be limited to smaller things I can carry like power window motors, starter, alternator, etc, not larger items like transmission, motor etc. Thanks.
Good news...I finally had a chance to look at the switch. The panel cover part just pops off with a screwdriver, and the whole switch assembly unscrews from the door frame; but I didn't have to do all of that, just popped the panel cover. Upon looking at the "switch" I noticed that the plastic toggle that clips on to the actual "switch" (up/down controller) was snaped off on one side on the inside and was loosely attached, so removed the toggle and tried the controller with just my finger - the window goes up & down as it should. I just need a new toggle clip or whatever it is called. . Thanks for everyone's good suggestions and help. Yours, Steve
1999 Legacy Brighton Wagon, 2.2L, auto , power windows/locks/mirrors. My wife has the car a few hundred miles away, so I can't look at it now. She'll be home in a few hours. Problem: the drivers side window is stuck in the fully down position and it won't go up at all. The other windows work OK. Could it be a fuse for this window only? Any suggestions on what to look for before I have to take it in to get it fixed? It's raining like hell now and for the next few days so I'd like to get at it soon, and no I don't have a garage to park it in. I'm no mechanic , but I'm mechanically inclined. I'd apreciate any suggestions. Thanks. 1S1
I called the dealer and they did not have a rad cap for my car in stock ($18.99 and a 4 day wait) so I had to get a cap at CTC for $8., installed it and then I drove it around most of the day yesterday, with some highway and in town driving, stopping along the way 5 or 6 times to check - no bubbles yet. I still have to check the level after it has cooled down to see where it's at, wish me luck.
I bought it used. I took it to Subaru dealer for a total inspection before I bought it. It passed with flying colours. The mechanics were impressed with it. I researched it for a year on this and other boards before I decided on the model. Just my luck I guess. I'll get a replacement cap for it tomorrow. Should I get a Subaru cap; is it necessary? I love the car but geez they're expensive to maintain.
1999 Legacy Brighton Wagon, auto 2.2 L engine : The head gaskets were done about 10,000 km/ 2 years ago, by a Subaru mechanic at his own private shop. I can only assume it was done right as the car has run fine since, and the temp gauge always reads just below the half-way mark (as normal). After a 200 mile trip last week, I parked in the driveway and left the car running , opened the hood and checked the overflow tank for bubbles (as I always do since prior head gasket problem) and see small bubbles rising to the top of the coolant in the overflow tank. It was about 24C/75F out. After the car cooled down I can see no evidence that the coolant level in the overflow tank is down at all. The next day I take the car into town to do a couple of errands. 25miles into the first town at 80km/hr,stop for a minute check coolant tank with engine running-no bubbles, then drive through town, connect with highway and drive for 12 minutes @ 110km/hr, do the same check-no bubbles. Temp gauge is always normal. I'm trying to diagnose the problem before I have to go in and pay for a head gasket repair. There seems to be no leaking of coolant under the engine as far as I can tell, but I don't have a hoist. I grabbed the top rad hose and gave it a squeeze, listening for the sloshing sound of coolant in the engine that I heard before when the head gasket was going last time- no sound and the pressure seemed good. Then I gave it a hard squeeze so that I forced the coolant past the rad cap and into the coolant overflow tank-I saw a few bubbles,probably in the overflow hose and then the coolant flowed into the tank. Then I let off the pressure on the top rad hose and heard a chirping sound as if air was being sucked into the coolant at the rad cap as the coolant was sucked back into the rad. So I logged on here,did a search for "bubbles" and found a suggestion that it may be the coolant overflow hose that has a leak in it. I went back to the car and took the rad cap off, slowly squeezed the upper rad hose to bring the coolant level with where the rad cap attaches and firmly placed my palm on it to create a seal. Then I gave the upper rad hose a good squeeze. The coolant flowed into the overflow tank easily and when I release pressure on the upper rad hose, the coolant sucks back into the rad with no problem and no sound. Could it be that when the engine warms and the coolant expands into the overflow tank and then later cools, it draws air into the rad through the rad cap, which then bubbles into the overflow tank the next time it warms up and expands? Any suggestions on what else to check? Thanks.
1999 Brighton Wagon, EJ 22, Auto, Air, 175,000 kms. : I posted earlier with the car's symptoms, and by everyone's opinon it looks like I need the head gasket replaced. I'm going to have this done next weekend. What else should I get done while this procedure is performed? The timing belt, alternator belt and oil seals were done at 169000 kms when I bought it earlier this year. I'd hate to be saying "I should have..." after it's been done. Thanks for your input.
