wounded brat
About wounded brat
- Birthday 06/15/1999
Location
northwest wi
Occupation
nunya
Vehicles
86 brat lifted ej'd
wounded brat's Achievements
Advanced Member (3/11)
10
Converting A 1985 EA81 Hatchback from manual to power steering
wounded brat replied to Hatched's topic in Subaru Retrofitting
don't know what the difference is if any but the holes are on the driver side to the front of the crossmember on a rather flat part originally was a manuel had to make a custom bracket for the pump to clear radiator hose -
gd I have a lot of respect for you and think that you are usually correct on most things but I have converted my 86 brat to ps and it bolted right up just had to drill some holes for the lines. -
does puttin 2.2 heads on a 2.5 block make it an interference motor.
not a direct fit but adapters are available
alternative fuel pump?
wounded brat replied to danzick's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I am using a ford pump on my 2.2 brat works great no surge tank:Flame: -
5MT D/R difficult to get out of 4hi
wounded brat replied to tractor pole's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have the same trans in my brat same issue only not as bad as you describe I find that if i shift from 4wd high to fwd while the clutch is engaged aswellas backing off the throttle it shifts smoothly -
Red hatch brat spotted superior wi.
wounded brat replied to wounded brat's topic in Meet n' Greet. Your USMB Welcome Center
brown one was rough rusty with exhaust leak looked like an older lady driving. the red one was lifted don't recall if the wheels were black or not looked like this only red -
I have a strange issue with my 98 outback running lights. They stay on all the time need to pull the fuse even with key off. I looked on all data at work for a location but there is none give for a relay only shows lighting module I assume its a relay that failed in the on position but need to find it to verify.
