wounded brat
Everything posted by wounded brat
Converting A 1985 EA81 Hatchback from manual to power steering
wounded brat replied to Hatched's topic in Subaru Retrofitting
don't know what the difference is if any but the holes are on the driver side to the front of the crossmember on a rather flat part originally was a manuel had to make a custom bracket for the pump to clear radiator hose -
gd I have a lot of respect for you and think that you are usually correct on most things but I have converted my 86 brat to ps and it bolted right up just had to drill some holes for the lines. -
does puttin 2.2 heads on a 2.5 block make it an interference motor.
not a direct fit but adapters are available
alternative fuel pump?
wounded brat replied to danzick's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I am using a ford pump on my 2.2 brat works great no surge tank:Flame: -
5MT D/R difficult to get out of 4hi
wounded brat replied to tractor pole's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have the same trans in my brat same issue only not as bad as you describe I find that if i shift from 4wd high to fwd while the clutch is engaged aswellas backing off the throttle it shifts smoothly -
Red hatch brat spotted superior wi.
wounded brat replied to wounded brat's topic in Meet n' Greet. Your USMB Welcome Center
brown one was rough rusty with exhaust leak looked like an older lady driving. the red one was lifted don't recall if the wheels were black or not looked like this only red -
I have a strange issue with my 98 outback running lights. They stay on all the time need to pull the fuse even with key off. I looked on all data at work for a location but there is none give for a relay only shows lighting module I assume its a relay that failed in the on position but need to find it to verify.
Contemplating a move...
wounded brat replied to Scoobywagon's topic in Meet n' Greet. Your USMB Welcome Center
bring some rust free hatches with you if you do. -
It will be dark by the time I get home but I could try!
I put the radiator from the ej donor car into my brat. 94 leg welded two bolts to the top of the radiator so it aligned with the original top mount holes and added tabs to the bottom only one fan (the smaller one) on the front side of radiator.
found it
JUst did this swap took a 98 outback with a bad motor put in a ej22 that was manufactured in sept 94(car was a 95 legacy wagon that I heard run). everything went well untill I attempted to start it. the ignition timing seems to be off the motor has no egr is there some issue that I am missing. any Ideas would be helpful
just swapped a 2.2 into my 98 outback and I can't remember where the computer is located? is ti under the rear passenger seat? any help would be greatly appreciated:-\
I am currently trying to pull the engine on a 95 legacy all wheel drive automatic transmission. In the past when removing a automatic transmission I have had to remave the torque converter from the flex plate before removing the engine. is this the case with the ej22 and if so how do you get at the bolts. the access in the bottom of the bell housing is blocked by teh power steering rack
I have an opportunity to get a 95 legacy with major engine issues. I need to know if these wheel hubs will work for a conversion on my 86 brat and if so what do i need from the donor car. I have already done the 5 spd d/r turbo tranny conversion so i have the right axles but since I just replaced the wheel bearings and struts on the front of the brat i was hoping to still use those and replace just the hubs and calipers. same goes for the back the suspension is way different so the only way it would work is if you could use just the hubs and some how mount the calipers on the bearing housing. If anyone has done this or can think of any suggestions please feel free to chime in.
