Everything posted by jamal
the two sides of the suspension are sprung together with a swaybar. A swaybar acts to reduce body roll, and is attached to the control arms with an endlink. In this picture the vertical silver bar is the endlink, attached on the top to the swaybar and on the bottom to the control arm. The upright/knuckle/spindle is the thing the strut, balljoint, and steering arm attach to that holds the axle and hub/brake/wheel. So, if the endlink is attached and only one wheel is off the ground, the swaybar is going to hold everything up and prevent the strut from fitting in. Also, rear struts are longer so make sure he's not trying to fit them in the front. Are the strut/spring/top assemblies all put together? Edit: forgot the picture.
If he's jacking up one corner at a time he's not going to get the upright on that side to drop down far enough unless he disconnects the endlink because the swaybar will hold it up. The only way the tops won't fit is if he has rear 95+ Legacy or rear 02+ Impreza tops. All the front ones are the same for pretty much every subaru.
I've replaced my struts and springs and taken an assembly apart so maybe I can help. Yes, it will be a pain in the rump roast to get some of the bolts off. A nice piece of pipe fitted over a flex handle is useful at removing those strut to spindle bolts. The top one up front is cammed to adjust camber so make a note of where it was rotated, although you'll want to get the car aligned right away afterward. Since the parts are from a 95, your best bet would probably be to find a set of used suspension for a 94 wagon, and buy new struts. Then you'll have all the spring perches and top hats and little rubber boots and whatnot, so you can transfer all that to the new struts. Post a wanted here or at bbs.legacycentral.org (it's a legacy right?). Also try PMing Blackbart, he might have a set laying around. Next up is installation. The only thing I can think of is to make sure not to over-tighten the strut top bolts because they're prone to snapping off. Torque spec on them is 14lb-ft. Well, that probably covers most of it, do you have any more specific questions? Here are some scoobymods writeups: http://www.scoobymods.com/forums/showthread.php?t=36 http://www.scoobymods.com/forums/showthread.php?t=346 and here's what I did: http://bbs.legacycentral.org/viewtopic.php?t=21883
02-03 WRX springs will fit without a problem, but will lower the car at least an inch. There's a company called scorpion that does lift kits, but I'm not sure if they sell springs or just blocks. Also, King Springs is an Australian company that sells what you're looking for, but I don't know of any distributors in the US. One more option would be ground control coil-overs. You modify the strut with a threaded collar to fit a 2.5" spring, which you can get in any length and spring rate you want. A set goes for $300-400 I think.
rear struts
jamal replied to pamike's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
yeah that'll happen sometimes. When I changed my lateral links I had to cut one bolt off and destroyed a few more bushings. You might have to order new hardware and have him take a sawzall/cutoff wheel/torch to some things. -
Opinion, plz...
jamal replied to Kilroy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
looks kind of like 06+ WRX wheels. You could get a used set for around $400 without tires and be sure you have the right offset and center bore. -
you mean the drive gear ratio? VDC autos and the STi use a reduction gear and a different rear end ratio to put more power rearward. If you don't have one of those it's 50:50. And yes, understeer is inherent of the drive system. After all, you're asking the front tires to do more than the rear, and they're the same size and there is more weight on them. More front negative camber will optimize the front contact in a corner, providing more front grip. A bigger rear swaybar will reduce rear grip. These two things together are a fairly simple way to reduce understeer, but it's really only a small part of the whole picture. You can also mess with tire pressures, and what you'd be shooting for is the optimum pressure for grip up front, and then something else in the rear. Less than ideal if you ask me.
I know the brakes are pretty small, but you probably only need good pads/shoes and fluid. I have only cooked my brakes once, and that was after a pretty good session of unsafe driving to catch up in a road rally with generic pads. Now I have hawk hps pads and will soon be flushing my lines with RBF 600. Although I'll probably bump up to wrx or rs brakes once they wear out since I have most of the parts sitting in boxes. Really you should probably slow it down on public roads and go to an auto/khana/rally cross. You did just stuff a TT Legacy in a ditch, and at 17 you're not as good of a driver as you think. As for the other stuff, only Legacy rear swaybars will fit because of the spare tire well. Also the lateral links will be a pain to remove. I know because I've done pretty much the same swap. While you're at it you may want to look into solid endlinks and urethane swaybar bushings. Whiteline comes to mind as as a supplier. They also make springs for your car. As far as stock used springs, 04+ Impreza stuff will work and lower the car about an inch. I wouldn't recommend Impreza aftermarket springs because that would be way too low.
no, don't put used struts on your car. GR2s are only about 15% stiffer than stock and your old springs are fine. New sets on e-bay go for around $200. The only way I know of to lift the car is with a scorpion kit. They sell lift block kits. King Springs of Australia also sells lift springs for Subarus but I don't think they have a distributor in the US.
The benefit of yakima (who, last I checked, makes the Subaru stuff) is that they have round bars. The square thule bars will look wierd on a rounded roof and cause your ski holders to be slanted, unless thule has a specific kit for your car. Not a problem for my old legacy but I think you'd be better off with Yakima. My roof rack:
Wheel adapters
jamal replied to fubar's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
04 STi is 5x100, 05+ is 5x114.3 -
Wheel adapters
check the nasioc regional classifieds. Expect to pay between $200-300 for 16" WRX wheels with tires.
