2
Everything posted by rverdoold
On the impreza: Put the steering wheel in the lowest position Undo the two philips screws in the top and remove the plastic rim (the bottom is held by two square things that 'click' in the dash these have to be pulled horizontally forward towards the steering wheel). Undo the 3 philips screws (each corner and 1 on top) and tilt the gauge cluster. Remove the three connectors (unique so don't bother labelling as I did with the first two I removed). Take the cluster out and replace the broken bulbs. Putting back in reversed order flip the 'virgin-switch' back to off otherwise no lights will work anymore after a day or so. put key in 'on' position and check the lighting and adjust the clock Really should not take longer then 30 minutes On the OBW it might be similar, check if there are two screws in the top of the plastic detailing.
Happy new year all members, driving back from holiday I noticed my oil pressure light in the gauge cluster does not show up when turning the key to ON. It used to work before because I usually notice 4 red lamps (battery, oil, CEL and handbrake) but one was missing. I checked the oil and was all fine, car runs fine and no CEL codes. At home I took the gauge cluster out to see if the bulb was burned but also that is not the case, all bulbs are fine. The car is a 1999 impreza MT (1.6). What could this be, the send not making contact properly? where is the sender located? Thanks for your replies.
Subaru just launched the new XV in Holland with the new 1.6 (not even direct injection) and for a relative high standing small SUV it has a fuel milage of almost 43 MPG for the CVT. The diesel CVT even gets 47 MPG. Those are the numbers we would like the see!!. The 2.0 has the same MPG as the 1.6 only more power http://subaru.gillz.nl/files/spec-sheet-en-colors.pdf
Yes the 1.6 is not fast at all. It only really wakes up way after 3500 rpm. But I became a slow driver with fuel prices over here and shift at 2400 rpm to the next gear. Speedlimits are 20 and 30 MP/H inside the city, then we have a lot of 37 zones (farm and country roads often loads of wildlife and clay on the road from agriculture AWD helps a lot on these surfaces). And the main out of city roads are 50 MPH. Highway as in interstate like highways vary between 50 and 75 depending on area and traffic density. I generally cruise at 58 to 64. With the flow of the main traffic. Additionally holland is flat!!!! I think 40% of the cars here are sold in US as small car (golf, opel astra, i30) and maybe an other 50% is smaller than that!!! There are not so many big cars over here. Due to CO2 rules, road taxing and emission based tax system. USA like pick-up trucks you hardly see, only ford ranger and nissan navaras. WHY? go and fill it up at the gas station!! The main reason why I drive propane is because it costs about (all in euros) 60 cents per liter for 12 km, while regular costs 1.65 euro for about 14 kms. Ok the fuel tax difference are 194 per 3 months for propane against 112 for regular fuel. But the half price per liter is enough to drive on propane. Is it popular NO, idiots think you can only cook on gas. And most new cars can not run on propane because of the soft valve rings in the cylinder head. Subaru has no problems with it, but toyota no model can be converted and from most other brands only 1 engine type. That is why the new small turbo diesels are popular, however studies showed that these small motors ar not as durable as the old ones. Saving weight make the heads crack earlier (100k miles).
This always wondered me the AWD vs FWD, now in Holland you can get the impreza 1.5R with FWD only. It needs 6.1 liter/100km, which is 38.56 MPG for out of city. However, the 1.5R AWD is rated at 36.75 MPG (according to the same standards). These both are manuals. The 2.0 AWD manual is 34 MPG while the automatic is 35.6 MPG. So on the long go more efficient. The diesel version gets about 48 MPG. The STI only gets 28 MPG. I personally get with my 1.6 AWD impreza station about 28 MPG on propane and about 33 to 34 on regular fuel. The propane consumption is over 2 years and the fuel over about 2 months (5x refil). My old 1991 FWD legacy automatic got 28 MPG over 5 year average!!! Including city driving and alpine holidays.
I was thinking about the drain valve yesterday. I have to change the oil next week. I drive about 90% on the road. But I am afraid for those 10% also because if it goes off it is in the middle of nowhere. On the other hand my plastic underbody shield is still in between the ground and the plug. I have not decided yet!
Did you see the new BRZ boxer, no have a look here. http://www.autoblog.com/photos/2012-subaru-brz-live-reveal/med/#photo-4643870/ Compared to the new boxer the layout is completely different. The intake manifold is inverted. I do not see power steering pump so assume it is finally electric. Curious if there ever will be a AWD version comming
Since there are no unlockable axles you will always drag the whole drive train. Even if on the automatic the FWD fuse is placed the drive train drag is there. I am not sure if new cars actually have a lockable diff or just a ABS that stops the spinning wheel so the diff transfers the power to the other axle. In our toyata yaris MMT (manual computerised gearbox) this is called electronic diff lock. And is only there because you can not operate the dry clutch to play with the slip of the wheels as you can do with a full manual. I am not bothered with the AWD extra fuel consumption, subaru should introduce smaller displacement engines with turbos. Like 1.5 turbo, maybe 1.2 turbo. I love my low power 1.6 with hi-lo gearbox. Never got stuck in mud and snow/ice.
I just get the NGK ones BKR6E11 which cost here about 3 euros per piece. Although NGK says I should use LPG6E11 since i run on LPG but those cost a whopping 20 euros per piece. Good old fashion copper will do for me. I am always afraid of putting plugs in and over torque them so usually buy new ones and tighten them by hand and followed by the half turn to squeeze the ring (according to NGK instructions). My torque wrench goes from 20 to 200 and I thought spark plugs was 15 F/P
I was interested in the consumption of using the lamps all the time. Well for a 30,000 km (per year) it consumes about 8 liters of propane. Nothing compared to my 2,800 liters of propane I need to drive that distance. A/C is the word and so is your right food. I try to drive 55 and avoid to use the brakes as much as possible. On off-ramp coast as soon as you get on there. Shift when you reach 2,500 RPM.
Here In holland the already rare sight of a Subaru. But in the street where I park there is a exact copy of my Impreza, checking the registration number shows it got registered only 4 days after mine. The VIN is nearly the same. I have never tried the keys yet though, neither I have met the other owner but we tend to park close to each other in the street just for fun. Two identical cars with nearly same license plate (Plates here are on the date of selling). If I can open it, it would be hard to start with the immobiliser I assume.
