2
Everything posted by rverdoold
The cold start fuel mixture is also based on water temperature. This is a second sensor which is not the one for the dial. You can measure it via OBD2 probably. I have a similar problem with an 1.6 from 1999. It starts fine after 3 to 5 cranks but if freezing it nearly always stalls. If I restart immediately it runs fine and stays on, if I wait it floods. This is only with a cold engine, when warm there is no problem at all. I live with it since I know what to do with it, and it starts from just a few cranks, in contrast with yours. Also if I open the throttle it prevents from stalling. I was thinking at the IAC valve but not sure.
Came along this video on youtube: It is a 50 min video where different cars drive over rollers, this time it is not a commercial but just normal people in Lithuania. It surprises me that most Subarus are not able to dive off the rollers with two side wheels on the ground. This most likely because most EU models have an open diff at the back. Actually most AWD cars have open rear diffs. However, at 4.25 an old audi quatro (Torsen awd system) also shows slip but then suddenly jumps over. I assume the driver uses the handbrake to send more power to the front. Question: With an open rear and front diff does using the handbrake to lock the rear and thus sending more power to the front help. And can it damage the brake system or center diff?
Yes until now (40 k miles) It did not gave any problems. Probably when I will replace my brake pads and discs next time I will order a refurbish kit and try them again but that will be at least an other 60k away. Until then I drive it like it is now. What I do at every interval (7.5k) is taking the brake pads off the car, and check if they can move freely, additionally I clean and regrease the slide pins too (slidepin grease from european brake vendor) and apply copper paste on the brake pads and guide plates.
Could be indeed the lower slide-pin sleeve. Here there is an exploded view: http://opposedforces.com/parts/forester/us_s12/type_6/brake_system/front_brake/ I assume it is part a4 (under label 12) I have removed these on both sides because it caused my slide pin to be jammed and took me 2 hours with a hammer to carefully get it out.
Though glass expands very little under heating it does expand. I think there is a sharp spot of metal where the glass expands against and breaks. I assume your window does not shatter into pieces but just a single or double crack. The location where this is on the windowframe might be the source of the breaking. When they replaced my windscreen they had put ducktape from the roof onto the windscreen. This stayed on for 1 day. It was to prevent the window sinking down (downwards to the end of the frame at the wipers), when the glue hardens. Maybe your windscreen sunk to the lowest place of the frame. At the moment you switch on the heater it wants to expand there the most but there is no space. It probably can not push the rest of the windscreen upwards and it cracks to release the mechanical stress.
Sorry to bump this old thread up, but I have a similar problem. The car drives fine all the time and very efficient as always. However if it was freezing overnight the next morning it starts very hard. It goes on on the 3rd cranck (not more then normal) but only runs at 200 or 300 rpm. If I engage gear and clutch the car tries to move. Then it suddenly jumps to 1200 rpm and runs fine. Except this morning. I gave some gas in the hope it would jump up but it flooded and was nearly unable to start for the next 10 / 15 attempts. Could this be related to the temperature senders. As far as I know there are two. 1 for the ECU and 1 for the meter in the dash. If I read from the ECU I assume I read the temp from the 1 only giving signal to the ECU and not to the dash meter. The motor is a ej16 from 1999 (impreza)
Lately the IIHS introduced a small overlap frontal crash test mimicking a crash with a tree, car at only 25% of the front end of the car. Subarus 'survived' this new type of testing but it made me think. A few years ago I have seen a similar study in Germany, here they introduced a rather big fender brace which reflects the colliding object. Unfortunately the video is in German for those who not understand the images will say enough. Maybe a good idea to construct a somewhat bigger fender brace. (and yeah today I drove the BRZ )
Curious what systems they use in Australia. In holland it is direct injected LPG right above the intake valve. It is extremely unlikely that you get manifold backfires with this system. I now own a ej161 on LPG and before a EJ20 and we have had a EJ25 as well. Subarus run great on LPG because they hard valve seats. If your EJ22 has HLAs it is even better. No valve worries. Ah and my car starts on normal gasoline and after 500m to 1 km (depending on temperature) it automatically goes to LPG. I can force start on LPG but it is not advised. I would advice to get an injected system like mine or turboguzzi.
Very simple, I just buy fully synthetic 5w40 in the API SM class (or SJ and above) from a German manufacturer (Liqui Moli / Megium) in a can of 20 liters. This because I drive in summer at 30 degrees C, and at -25 C in winter. I change oil every 12500 km with a new filter and never had to add any oil in these 12500 km. The car uses about 300 to 500 ml over this distance interval. Best indications of car problems are oil consumptiion and fuel consumption, if these are low and there are no weird noises or shaking then it is fine. (gearbox is Valvoline synpower TLD 75w90 just for the record)
