subaru girl
Everything posted by subaru girl
it is now leaking coolant. it's dripping and the bottom of the timing cover is wet. i'm sure it's the water pump thats leaking and making noise. i called the subie garage and they said over $200 labor and $200 for parts. advance auto price is $71 for pump and $29-55 for belt depending on brand. subaru genuine parts is $ 66 for pump and $43 for belt
if i took the crank pulley and the covers off. could i start the car without the alt. belt on? all i know right now is the noise is coming from the left side and the heat prob just started shortly after the noise started. if i put a breaker bar on the crank bolt and crank the car, where should i put the bar.
i thought the belt was not to old because all the writing on top still looked good (not worn off). the noise is on the left side close to the cam. one more thing but i don't know if it's related or not, the last 2 times i drove it, the car was warmed up and throwing good heat but when i stopped the air got cold until i started going again. but after a while this will stop and it will have good heat.
it doesn't have turbo or thw wing. but other than that it looks about the same except for it being red
i found a pic. it looks like this onehttp://www.ultimatesubaru.org/photos/showphoto.php?photo=6637&sort=1&cat=712&page=1
it has a tach. and it has auto trans with a button for 4wd on the side of the shifter.
