gavinl
Everything posted by gavinl
Thanks for the info! When the car was bought last Dec, the PO said he hit a pothole and the tranny fluid leaked badly. Then it stopped leaking, so my buddy bought it cheap but didn't drive it much. Maybe about 100 miles put into it since without tranny leaks till tonight. Will be draining the front diff tomorrow to see if there is ATF in it.
So buddy of mine with a 99 Leggy GT called me this evening with an emergency, tranny was literally pouring out of the tranny! He left a puddle in his driveway, a trail of ATF out of his cul-de-sac then another puddle while waiting to turn around to limp it back home. Gut feel is he lost 1 - 2 qts during this episode. He says that the front diff dipstick was blown loose and ATF was blowing out of there. My first thought is could it be a vent tube in that area? And the diff dipstick was just loose from a previous check? But what is the worst case? Could any seal between the tranny and front diff be blown such that ATF is pushed into the front diff? He sent me this picture:
How about Amazon? As far as reputed online sellers go, they can definitely be trusted. http://www.amazon.com/TYC-7430031-Passenger-Non-Heated-Replacement/dp/B002P8JWNG/ref=sr_1_7?ie=UTF8&qid=1324593741&sr=8-7 This mirror is not painted though so either live with a black mirror or have a body shop paint it before installation.
Previous owner claimed to have the headgasket replaced by a "friend", he left the headgasket kit packaging in the car. Anticipating a botched HG job I did a combustion gas test of the cooling system, stuck the gauge in the expansion bottle, pumped and the test fluid remained blue. Forgot to mention that the ATF levels have been dropping during two short (<5 miles) drives I had done since purchasing the car :-\ Will check both ATF and oil again for signs of moisture That being said, if it is indeed a botched HG job I'm not even going to wongleflute around with in, will just shoehorn a used EJ22 from a 95 into it
So last night I was looking into the coolant expansion tank of the recently acquired 98 Leggy GT. The coolant was bubbling and looks frothy (err....like the foamed milk on top of a latte?). Is that a sign of the ATF cooler leaking into the coolant passages? If so, what are the odds the coolant is leaking into the ATF (and tranny) as well? Thanks
I searched but could not find a definitive answer. The car in question is a 1999 Impreza OBS MT with a seized motor due to previous owner driving with oil filter fallen off after a quick lube job. So I'm pondering, in the interest of getting this car back on the road with last $$ spent, can a donor Phase 1 motor (long block, intake, injectors, etc.) be a direct swap for a 99 OBS (originally phase 2)? Is the wiring harness and ECU off the phase 1 motor required? Thanks
