Everything posted by bheinen74
okay the 82 Brat pics and name what you need or want
http://s405.photobucket.com/albums/pp132/bheinen74/82brat%20pics/ what is not available now: cyclops unit, power button T-tops rear hitch some bed chrome Everything else, we can talk.
Removing/replacing rear diff... need advice
bheinen74 replied to shortskoolbus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhy do you think your rear diff is bad, they rarely ever go bad, but rather a lot of times torque bind, etc, shutter, people think it the rear diff, but it is really the rear clutchpacks, center diff of the tranny..... you might be in a world of hurt with this " it was advertised as fitting 95-99 Impreza/Legacy 4EAT." yeah, it will fit, but might not have the correct drive ratio......you need to post more info on here, BEFORE you ruin a tranny or something else.
Looking for help on a new impreza
aggree, third that. outback sport, about 99 or so, or impreza TI wagn
What does this icon mean in the FSM?
bheinen74 replied to shortskoolbus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyep, the outer edge part of the seal a sealant, the inner part where the shaft rotates, a little bit of grease.
Photos From a Trip To Browns Camp
yeah, don't see too many people doing this to inspect CV boots out like this, thats a pretty good approach angle for the right side :grin::grin:
Oil Pan Drain Plug Washer
bheinen74 replied to axel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah, basically that is about what i do, I never really torque the plugs down that much, so they never really squish out of shape. I learned to not overtigthen them, I probably should put some more foot lbs on, but never had a problem in 20 years. usually one new washer for every 5 or 6 oil filters.....thru experience, and not over tightening, can reusue them a lot.
2005 Outback 2.5i, heated seat not working
bheinen74 replied to cheetah8799's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcheck the green plug under the drive seat. The ones on my Brat came loose at the connector. MMM toasty seats in a BRAT are nice (from a 04 Limited, side air bags not hooked up, but power and heat is).
replaced rear main and oil separator... now leaks in front and back!
bheinen74 replied to shortskoolbus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou probably drove the rear main in past being flush, installed it too far.. it may eventualy lessen the leaking, but probably not. It will need re-done. The first one I replaced because it was leaking, drove it in all the way, man it leaked for a while, but then the leaking pretty much ended after about 2000 miles. That car is still going and never used enough oil to ever go low (my old purple wagon) My BRAT, it was leaking so i replaced it, now its dry.....
Iowa Campout June 5-7, 2009
I have one 14" aluminum pug, i can bring just one, or all 5 Ben really wants them, but we have not completed the deal, so I am offering first one with oney to me gets em..
bheinen74 replied to axel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAm i the only one who just forever reuses the old ones.....?
My wagon with 14" pugs with 26" tires!
they look really good where did you get tires and how much>
you are not going to be able to turn so you will have to cut or lift or both
new brat.. new projects
bump for hope yo bring bumper to iowa campout.
Waterpump on an 82 EA81 Wagon
make sure the heat selector is cranked hottest when filling and burping, so it can fill the heater core and get the air out of there too.
California SMOG : from Sconnie to Cali
as long as its stock, i think it might pass. If is modded, or had a Weber, no.
exhaust leak results
bheinen74 replied to unibrook's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX75% of shops are scammers, the other 25% are good ones.
Oil leak was transmission leak?
bheinen74 replied to outdoor's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhy did they replace intake and exhaust gaskets for a oil leak, oh becuase they pulled the heads off. did they do a rear main seal? sorry you got taken for.
Group Buy Time?? SJR lift kits and EA to EJ engine adapter plates
i might as well get the EJ to 4spd D/R adapter, so i can begin the planning for a ej22t swap into my BRAT, since the Weber search is failed.
arent you going to get them before the campout, so i can get a weber....
did you invite the Mountain Grizzly to this, she is in Missouri i do believe. Yeah, lots of tools will be here, lets just hope they are a help lol
I think i am going to be bringing to the campout a big box of things to install on the BRAT......
Cannot find AC switch in 1994 Impreza automatic sedan
bheinen74 replied to abdilkr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdoes anyone really understand this post?
still Weberless on my Brat, oh well. CB radio and antenna on the way though
abs killswitch - advise against?
bheinen74 replied to greenleg88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsame could be said and argued about having a cell phone in the car.... I just don't think that will be an issue.
Affirmative Posts where are they?
bheinen74 replied to subaruplatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhats the status on this air, did you have success? btw, this thread is going nowhere
