bheinen74
Everything posted by bheinen74
  1. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=260366639775
  2. like title of thread. I wanna see some Soob cars having fun in deep snow, and please describe how much fun it is when your Soob can go in the snow, and others can't
  3. all 10 year old cars in rust belt will have rust if they were always in that area. salt will rust a car no matter what. I would be more concerned with the next needed maintenance (T belt) check for the torque bind to rear wheels and check for any major leaks of oil. 2.2 is the engine of choice. does it knock or rattle would be worth looking at. check the CV axle boot on the fronts. they are maybe the age of failure of rubber boots, another expense to thing about what is the title status. if its a clean title the price would be ok. if its salvage, forget it and move on. bh
  4. hmm i like this idea. you should activate your rear wiper though.
  5. on my subies, i have had it be 4 different possibilities. I will rank them in order i have found most likely 1.bad battery, got them bad from the store a couple times 2. alternator, won't charge 3. cables on the battery weren't bolted on tight enough, or terminals werent quite right 4 left a door ajar running down battery from light being on
  6. yep to get rescued by good distributor. I think you should get a known good distributor, at least if the shaft wobbles, it won't creat spark to the plugs correctly, weak at best when the shaft or shaft bushings are toasted.
  7. power steering seal (at the rack hose) goes bad at 125k on all my subies. most other seals too i will say this: if it aint leaking dont mess with the seal, you will just cause a leak if its leaking, better fix the thing soon and leave all other alone my 2 cents
  8. ej22t. hmm, did you try to cook hotdogs on the chimney? :grin:that mfer gets hot enough to do so, i have yet to try
  9. *New Coolant Temp Sensor *New Fuel Filter *New Plugs and wires *New air filter of these, list the Manufacturer brands involved.
  10. http://desmoines.craigslist.org/sks/1045454681.html there ya go YOU will be SHOCKED at the size of the holes. They wll be scary.
  11. could you post an ad on craigslist under services wanted?) looking for a hour use of sandblaster?
  12. the minute after it gets blasted, need to spray on the acid etching neutralizer rust eater converter. IMMEDIATELY.
  13. by that 1 pic on this side, and hatch 20 holes at least. some size of bb, some like a silver dollar and more largest will eat a dollar bill.,
  14. Gee, thats a hi-tech Sqeegeeeeeeeeeee. nice find.
  15. wth is a main hoop? i am befoozled on what a main hooop is.
  16. once ground down, every brown cancer spot has a hole. anybody who has done body work on a midwest car knows the look of surface rust vs those with holes. This my friends, has holes, and they will open up nice once sanded on. sure, some places its not all the way thru, but the larger the circle of rustness, the bigger the hole is. I don't like big holes. Ben, I would suggest to find a amateur sandblaster, take it to him, mask off the area to be sanblasted, and let him blast away to the shiny metal. Then, take self etching rust neutralizer spray, and spray over, which will effectively eat any rust that remains and convert it to good stuff. Then prime it until you can finish it off, ASAP to a coat of paint whether it be just to seal it, or a profssional painter topcoat good news is white is the easiest color to match colors with. Bad news white is the one shows rust the most. give take.
  17. this could be due to the DTV conversion......and available frequencies dropping on power as a result. Next, will be converter boxes for radios, or else buy a new box.
  18. needs stickers along the lines of "JeepEater" officially BAD
  19. i once thought this happened on a friends 91 legacy. definitely had injector o-rings leaking down on the 1st cylinder. I change the o-ring/injector, and it seemed as the engine was hydro locked.
  20. speedometers are overrated. But I would not recommending telling that after getting pulled over.
  21. 82 loyale? let me see pics of this also, what color is your 86? I can source some maroon parts for front end in useable shape no major dents, just chipped hood and some fender rust.
  22. i will hijack this thread, need a BRAT shirt.
  23. for once, i blame the inconsistency in laws. willl determine something:horse: Bratman....probably i need to get a maine title somehow, from the NM. then the maine title, would be sent to me here in Iowa. problem is Jim is not around. I will pay the title fees wherever, they can't be too terrible.
