Everything posted by bheinen74
any SVX wheels? I need left and right and cheap
Brush guard head light loops for sale
bheinen74 replied to Aaron's Auto Wrecking's topic in Products for your Subaru
bump -
Do-It-Yourself Bedliner...
bheinen74 replied to TheSubaruJunkie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
if it rains on my herculiner, it turns it a grayish...when it dries goes back to black. -
save the sheetmetal that gets cut off, especially rear quarter panel. I am sure, someday, a cheap Brat will be for sale locally, with rusted qp arches, so they could be used as patches....keep them in the attic or something.
http://s405.photobucket.com/albums/pp132/bheinen74/?action=view¤t=IMGA3759.jpg i think it turned out pretty decent and 40 bucks. after over a year, no pealing cracking flaking etc. it stayed put. its rubbery, but durable. The big dogs have not scratched thru and they jump in. I don't think the Price can be matched. -
if that was around here, subie would win. most of the lifted 4x4 trucks around here don't have working 4wd.
I am looking for someone near Evansville, Indiana to look at a car for me for a parts car to my SVX... And even better, if someone there would be able to trailer the car into the east edge of iowa for a small fee.
get the matching diff and you will be set. nice.
yes, why didnt you go for a 91leg tranny? either way, there are PLENTY of 3.9 diffs around.
progress with the hatch
bheinen74 replied to mountaingoatgruff's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yes a tube flare tool. they are pretty cool. kind of like a c clamp, that holds the tube and flares out the end. -
91 Loyale 48Kmiles and a few ?'s from newbie
bheinen74 replied to dtrentr's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the low mileage original radiator is better quality than any replacement would be. As long as it is clean inside, and fresh antizreeze, don't change out to a made in China crappy radiator that will crack in a year. -
the leaks are the factory own rustproofing system. If you wash the gunk off, its likely to leak even more when you brake off the sealing gunk. welcome to the Subaru world. Sounds like a really good start getting something with low miles and such. Post your questions and someone will answer, this board is really beneficial -
one gallon, i did not go any higher on the back than the hook handles, did the entire inside of tailgate, and about a foot below the back window and below. I left everything higher as body color cause it was in great shape there. http://s405.photobucket.com/albums/pp132/bheinen74/?action=view¤t=IMGA3764.jpg http://s405.photobucket.com/albums/pp132/bheinen74/?action=view¤t=IMGA3759.jpg -
I did the BRAT with Herculiner, was on sale at Menards for 60 a gallon kit, then it had a 20.00 rebate. I first sprayed it out using some of that simple green cleaner degreaser, then rinsed with the hose. After drying for a long time in the sun, I used scotch brite pad to scuff the surface up, and the two little scratches i cleaned up and sprayed with a etching type rust converter. After the scoth brite, i used a rag with alcohol on it to get any of the sanding grit up. I have not had any peel up in the year plus. My dogs have not appeared to have scratched thru either. Herculiner recommends 2 coats, i think i ended up with about 2.5 coats, basically after 2 coats i was almost out and i re rerolled some of the areas that looks a little thin, or could still see some body color under. Key is to use a power drill with on eof those stirrers at the end, you have to constantly stir the product, as it has pieces of ground up rubber that will sink to the bottom unless you keep stirring it. -
Already Made Them Mad
bheinen74 replied to The Dude Abides's topic in Old Gen.: 80's GL/DL/XT/Loyales...
my most trouble free cars have been Hondas,but since going to AWD via Subaru, i would rather have maintenance and safety/traction over no maintenance -
Ask Subiemech to post a picture of his. I like what he has done to keep the power steering. so it can be taken back to original fairly easily.
