Everything posted by bheinen74
Weber air cleaner alternative?
bheinen74 replied to Idasho's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have had mine superglued there over 12k miles no issues. when i ditch this filter for new i will reglue the old foam and use it again. I am due for a new filter. I also wish i could put the stock aircleaner onto the weber, for a stock look. -
this is the fix -
I have the tall filter assembly and the filter would basically collapse inward deform shape and not sit tight. I trimmed up some packing foam stuff (like computers are shipped with) and then glued it to the inside of the filter so it is being pressed outward on the housing and no problems with it for 12k miles. -
This is sort of a catch22 scenario. 1.The cost of having someone cut a car up, 2. then the cost of shipping the part, 3.then the cost of a bodyshop to weld it in, 4. then the cost of repaint of the car to seal it up good, is going to be more than 5. buying an entire rust free west coast/southwest desert car. you can do the math but pretty sure its cheaper to buy one already rust free.
umm, that is all wrong. my blue arrow is pointing to what? a filter? that line needs to cross over and tie into the left head breather hose, and also t into the pcv. there is a diagram on here of pcv flow, and that head needs air being pulled out of it circulating to the left head....please look it up. if you dont do it rightm you will possibly blow the motor up as others have done when not doing this correctly.
went to look at a older GL wagon today
bheinen74 replied to bheinen74's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yes he had the front adjusted all the way low on the adjustabe strut perches. there are 2 nuts on the spring bottom, turn them the other way you will raise fronts. pb blast the nuts first for a few days -
nice update....post pics and keep it going. pretty sure the guys driveway contributed to the strut rod failure -
that highway to h##l had some steep hills involved. NICE right hand drive ...
to do it with riveting. place the patch metal behind the original cars metal drill holes thru both, pop rivet in place. Then you need to get the rivets recessed, so give them a whack down with a ballpeen hammer to smash the metal down some to allow for a topcoat of filler, bondo etc. - i do recommend a sealer between the seams to prevent moisture from occurring over time.
Introducing my new BRAT!!!!!
bheinen74 replied to 98ImprezaWA's topic in Old Gen.: 80's GL/DL/XT/Loyales...
it is pretty. -
Did any USMB members go?
bheinen74 replied to 2stroketurbo's topic in Historic Subaru Forum: 50's thru 70's
at least i can follow info on 360 on the usmb. the 360club won't allow me to join, even though i am interested in buying one and wanted solid advice. has anyone else tried to join recently? did you get the same message? -
best to get off of old washing machines/refrigerators/furnaces, it is a better grade and is coated well on one side already.
timing off perhaps. i am ready for pics, and if you ever get tired of this one, let me know i am ready.
Things you shouldnt have towed but did anyways
bheinen74 replied to brumby420's topic in Non Soob Cars and Bikes Discussion
I listen to cartalk, and last week a person called in was going to haul a huge chicken coupe like 100 miles on a snowmobile trailer......wonder how that turned out. -
86 Brat in Need of Rescue
bheinen74 replied to MaddCelt's topic in Old Gen.: 80's GL/DL/XT/Loyales...
sad way for a straight one to die.
