Everything posted by bheinen74
1986 ea82 weber conv. trouble
bheinen74 replied to Ron G "tinker"'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
is this a electronic choke? sounds like the way mine was. The choke coil mechanism was in backwards. as it heated up, the choke closed. I had to take the choke apart and reverse the way the spring coil is. just takes 3 screws and a needle nose to pull it out the slot. reverse, put together, done. -
trying to find the oil pump on my 83
bheinen74 replied to BusterH's topic in Old Gen.: 80's GL/DL/XT/Loyales...
probably the oil pressure switch leaking. Or perhaps leaking at the oil filter where it threads on. I would get a second opinion. If he saw oil leaking there, fine. But for it to burn on the exhaust, i say its yet another leak too. Or else you have a torn right side axle boot dripping/spraying grease onto your y pipe. -
Heater core hoses? those are alongside the firewall, kinda back by the starter. Sorry bud, you have joined the "HG Club". You most likely have classic headgasket failure. You should first check make sure the fans are connected, and they turn fine. You could try to replace the radiator cap with a new one. Add coolant to the correct level on the overflow tank. Make sure the radiator had been burped well. When the car is running, do you see bubbles in the overflow tank?
Wtf?
bheinen74 replied to Suba9792's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
most mechanics around here turn down work on a Subaru. It's JAP to them, they usually only know how to work on Grand Ams, Gand Prixs, Fords, and Chrysler. Just the way it is in the midwest. Even Subaru Dealer refused to work on SVX. -
Wagon rear window spoiler
bheinen74 replied to Matthewboerner's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My father did the opposite, since we couldn't locate a Forester spoiler anywhere in a 4 state radius, and with my posts n the boards asking to buy one. Lots (maybe 3 or 4 GL around here in the yards, so finally one of them had the rear spoiler. He mounted it on the Forester. I am not sure the Forester one would work on a GL. He didn't do it for looks, he did it for purpose. It helps blow the dirt, snow, dust off the back window when driving that would normally accumulate on the glass causing a view problem. -
Rust.... and work on Mtn Grizzly
bheinen74 replied to mcbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Wow Mick. The Grizz sure has been keeping you busy. Hope you still have time to do normal other things. What about a spring meetup near DM this March? Glad to hear Grizz is getting some maintenance, just worried about when you will be done with it. -
Great price. cheers. Is it fwd or 4wd model? The CVT trans is junk -better hope they were right that it needs a clutch, that means its a manual, dodged a bullet already
Wiring can be run from along the driver fender back to where the door/fender/windshield corner meet, then run the wire up along the A pillar seal from there to the top, wrap around and onto the roof rack. Hella 500 are good. Make sure you get Hella and not the fake "optilux hella" which Hella does not really mark there name on for a reason. Cheap approach to mount is use the stainless hose clamps to tighten the brackets they come with to the roof rack bars. Those stainless hose clamps will clamp it nicely, won't rust, and they can take the shape of most anything, and are quite secure.
brat body on toyota frame with 350 engine?
bheinen74 replied to nathan_baker's topic in Subaru Retrofitting
gen2 -
v8 BRAT done here is just one -
Another 81 Brat Bites the Dust
bheinen74 replied to MaddCelt's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Pretty sure has to be shock upper mount? or the mustache bar bushing to frame? Do you have a quick picture?
