86
Everything posted by DaveT
my newly acquired 1990 loyale 2wd
DaveT replied to ourdarksunn's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've made it to 200k miles with a few 3ATs. Keep the fluids clean, and full. Somewhere near 20k, check the pump input shaft, or any other time you have the engine / transmission separated. -
I got one very similar a while back. Added the 4wd parts. You want to find the 4wd driveline from a 1990 to 94. Swap the transmission, and add the stuff from there back. You need the diff, and the cross member it mounts to, or you have to fab and weld the mounts onto the 2WD one. You have to fab the center driveshaft support bearing mounts also. Add a wire or 2 for the 4wd switch and dash light if you want to make it complete like a stock 4wd, which is what I did. -
I found a local used Subaru specific dealer. I get a higher milage car, but specify body condition must be great. Thy know which models years etc have the various engines to avoide, etc. They go through the driveline, replace headgaskets, timing belts anything telse that's on the edge. End result is a car good for 100k miles with only minor regular service needed. For a better price than I can get the same year and model with low miles. For most subarus, miles don't matter. I go for whatever year etc I can get for around $10k. Taxes and insurance savings and the difference between 10k and a new car price would pay for a lot of repair work.
ea82 Maxima alternator conversion question
DaveT replied to Logan K's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Everything works fine.... Unless something goes wrong, and the existing wire gets shorted. I almost burned down my first car due to improper fuse placement. -
Picking up a 1986 gl-10 turbo wagon.
DaveT replied to Schnayke's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The turbo is supposed to have a 2 row radiator. I have used turbo radiators in my non turbos since 1988 to get a little extra capacity. But the turbo radiators are hard to find now. This reminds me, I have some old radiators I have to get re cored, probably custom.. -
The biggest thing o know of the turbo, is keeping the cooling system at 100 percent. It's barely adiquate for the nonturbo engines. -
2 diff rim widths on Loyale... bad idea?
DaveT replied to Pokey's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I may have done this a long time ago. I had a pair of rims that hit the front calipers. I made a 1/8" thick spacer disc, and they worked. Never noticed a problem. Eventually, I ended up with more gl/ loyale rims, and got rid of the old ones. -
The original wire and fusible link are too small. They should not be used. Add a new thicker wire, and proper size fuse. -
The safe thing to do is run a new wire of adiquate gauge, with a fuse, to the + battery terminal. -
ea82 cam tower oil seal question.
DaveT replied to darsdoug's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Test the cts. Ohmmeter is all you need. If the sensor reads correctly, check the wiring and connectors. The numbers are in the fsm, and a thread or 2 on this forum. -
The tensile spring isn't meant to set the tension. Tourque on the camshaft pulley is what sets the tension, when the timing belt marks are at the indicator on the flywheel / flex plate. (Not to be confused with the timing marks for degrees). Somewhere around 15 ft lbs iirc.
Ea82 radiator install, unused ports.
DaveT replied to Nickoli's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Those 2 tubes are for the automatic transmission cooler. I'd just put rubber caps on them. I've seen them in hardware stores. -
Welcome, Tally! You would get more info by posting this in the newer generation forum. Most of us here are working on older Subarus.
I'd look, but I am not home right now
Ah, ok. The harness wires often don't match the end device. The factory service manual may show them for both sides of the conector.
An 89 should have been SPFI. There may be diffences between a SPFI and a turbo distributor, aside from the wiring. But I'm not a turbo expert. These things are electronic, and may not survive incorrect connection.
I don't know if your car will work the same as mine - older loyales. I found that if I want to "downshift" the automatic earlier, I can move the lever down a gear. Then blip the throttle, the engine spins up, and it engauges. Don't try it the first time in extremes. See how it deals with a closer to normal shift first.
