86
Everything posted by DaveT
+1 empty bolt hole on old pump idea.
Easy out will not likely work. They are left threaded tools that try to remove broken off bolts. From what I've seen they can work on new bolts snapped due to over tightening. On stuck bolts, the easy out breaks off, leaving you with a hardened piece of tool steel in the bolt. The best trick I found for removing a stuck & snapped off bolt is to weld a washer or nut to the end of the bolt. The heat likely has an effect, and the new "head" will then remove it. For future - and others - If you heat the block to normal operating temperature before trying to remove the stuck bolts, your luck is a LOT better. Either by driving, or a space heater and a heat gun with a meat thermometer to make sure you don't go over and damage seals. This takes a *lot* longer than running.
did it snap while tightening, or because it was stuck when trying to remove it?
1992 Loyale wont start after rebuild
DaveT replied to Nahixson's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sometimes it does take a while to get them going. -
Intermittent check engine light issue
DaveT replied to XHighOctanex's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The good news regarding the life span of the CTS is that I have only 1 fail since 1988. Only a handful I've seen fail on the message board. With a new oem one, you should be good for 20 years. -
1993 loyale fule pump gone bad?
DaveT replied to Jman1991's topic in Old Gen.: 80's GL/DL/XT/Loyales...
This should be in the older generation forum. The fuel pump won't run with the key in accessory position. It only runs in cranking position, or when the ecu is getting pulses from the engine running. In test mode, it cycles on and off. To test the pump, you can unplug it from the harness at the oump, and temporarily power it with wires. -
When cranking, does the RRRrrr sound nice and even 4 count, or uneven? -
This is the correct forum. Check the condition of the wiring, connectors. Check with ohmmmeter, voltmeter, wiggle them. Reading should stay steady. Otherwise, sensors do go bad. The CTS can cause weird varying idle problems, without a code. -
Any chance someone swapped a transmission or differential and miss matched the final drive ratios?
Check that all 4 tires are the same brand, size, etc.
There are adapters for power screwdriver / drills to squ are drive sockets. Get one of those, Chuck it in a drill. Snap a 12mm socket on it, turn clockwise. I'm in ct. Been running without the front timing covers for a good while now, no problems. I was initially resistant to the idea. Advantages - eas to check condition of belts when checking oil or anything else. Saves a bunch if time if one fails. I suspect that they run cooler, and may last longer, both bearings and belts. Good luck!
I've done the oil prime by turning the oil pump with a drill, obviously before the timing belt is on that side. If you do it by cranking, pull the plugs to remove the load of compression. I wouldn't let it run long without the cooling system. Not sure if it's worth doing, as iirc, you only had the carrier off. Using even moderate care while reassembling, the biggest unknown is getting the timing set correctly, but this can be corrected with everything reassembled except the covers and the fan. If you unplug the MAF wire, and leave the boot off the throttle body, the engine should run in limp mode. Maybe obvious, but if you don't put the rocker cover on, oil will get everywhere. It's good to see the end results post for threads.
Check the CTS. IT can get intermittent and not trigger a code. IAC valve can cause similar. Intermittent wire / contact to either. CTS has 2 wires, and is screwed into the manifold thermostat housing.
In my recent emissions test fail nuts thread, there is a section about checking the injector. Iirc, disconnect the MAF. Remove the boot from the throttle body. While cranking, there should be a burst of fuel sprayed. Also, it should run in limp mode, and you can see the fuel spray down onto the throttle plate. If no fuel, it's time to start checking the injector and wireing. Ohmmeter, voltmeter .
Hope you replaced the toothed idler or it's bearing also. That and the 2 tensioners have about the same life span.
Suabru EA81 engine / VW Conversion help
DaveT replied to tucka786's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Loop of hose for the heater, yes. Fan running on the radiator is a good idea.- 1 reply
- 1
Ohm meter from ground to each pin will find you gnd. To find the L R inputs, set the radio to aux or whatever it has. Use a music player / phone headset output for a signal. To be safe, put something like a 2000 ohm resistor and a 1uf capacitor in series with the signal from the player to the pin you are testing.
Try starting and running while holding the throttle slightly open. If it dies only when you let it go to idle, it may be in the iac circuit. I had one do that.
90% rubbing alcohol is usually safe for circuit boards. The other answers you have sound correct.
