Everything posted by DaveT
Emission test fail Nuts.
Today, so far.... Capped the small vacuum port on the passenger side that powers the egr, and the hvac controls. Capped the brake booster port. No changes. A couple of the short hoses were hard, so they will be replaced. Tried injecting propane into the intake boot - via the crank case port in back, and the one for the IAC, and into the AIC. Made no difference. Pulling / capping the IAC line caused rpm changes. Propane / no propane seemed to have little to no effect. Note, I turned the gas on & off a normal amount for a torch flame, not trying to flood the engine, etc. Unhooked the FAM sensor, pulled the intake boot. I can see gas traveling across the throttle plate to the edges at idle. evenly all around. Looks like it does on my other EA82, which I did the same on. The O2 sensor started off about 0.26V. Calmly dropped to about 0.2V until idle went down to normal after warming up. Moved between 0.25V and 0.5V from there. Kind of jumpy unsteady hard to get good readings on the digital meter due to slow updating. Analog meters are way better at dealing with varying voltages. After a while, it stopped the switching and stayed at 0.25V. Off to do the leakdown tests.
toxic effects in a Subaru Imprezza Sport (2016)
DaveT replied to Sarah Boardman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOh, CO problem. Yikes! Yes, check that out. Somehow exhaust may be getting in.
Both MAF codes, misfire codes, egr codes, but maf is good. Could be bad ecm?
DaveT replied to jake333's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd probably try an oem junkyard one. ECU failures are exceedingly rare.
99 Legacy GT overheating HELP
DaveT replied to Wildem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWater plumps are notoriously bad at moving air. Some Subaru engine / water pump designs end up trapping air in the pump due to the routing of the passages and hoses. Once enough air builds up, it stops pumping.
DaveT replied to Wildem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat Gary wrote.
Rough idle, cylinder 3 misfire code
DaveT replied to xyzb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIgnition timing has no effect on compression.
Help Please! Subaru Impreza 2012 wiring question
DaveT replied to john54's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSorry, Factory Service Manual.
Are the ball joints always hell to remove? is there a better way?!
DaveT replied to jmoss5723's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTorch wouldn't hurt. Once it's bust like that, a weld bead around the inside might just shrink it and heat stress it enough to get it loose. I've used that trick to get stuck outer bearing races out.
DaveT replied to Wildem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it runs for an hour, the coolant has to be circulating. If the headgaskets were blown bad enough to effect compression, or show wet coolant on the plugs. Or show with a coolant system pressuring check. You couldn't get more than a mile or 2 if they were that badly blown. My comments are based on what I have seen in my own cars, and many threads I've read on here. Hopefully a few others who have dealt with that specific engine will add ideas.
ea82 cam tower oil seal question.
The air passage from the TB to the head is one round tube. The head splits the airflow between the 2 valves. I could see a vacuum leak throwing off 2 cylinders on one side more than the other 2.
DaveT replied to Wildem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe gas test is notorious for false passing. I have yet to hear of any othe cause for coolant to be pushed out of the radiator. The water pump suction side pulls from the radiator. Thermostat has to be at around 190 degrees to open. If there is no flow because of an air pocket starving the pump so the heater loop and bypasses are not flowing, the thermostat won't open. Coolant eventually boils, pushing out the overflow. Sometimes the disturbance will get some water in the pump, and some circulation will then open the themostat, pulling coolant back in.
EA81 crank pulley bolt RH or LH
It is a standard thread. Right = tight.
Well that proves the wires are ok. Might be worth compression checking at least one other cylinder for comparison. It is odd that it is much worse with new plugs and wires. Having a hard time thinking of how that could have bothered the disty. Any chance you cross wired 2 cylinders? I did that once, it ran like crap, but it ran. Just want to rule out stuff before going on a wild goose chase.
Fog lights 2009 Forester? Help...
DaveT replied to mb4lunch's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe wires are in the harness. They go to a relay board near the fuse box. The oem switch is on the light control stick - I bought a new one from a dealer, and the lights and the relay. Plugged them in and fog lights. With no hack job installation, or huge project to do it nicely. The only thing I'll eventually change is the way the power is routed. The oem setup makes it so you cannot have the fogs on without the headlights. Stupid this is, since in really bad fog, the whole point is to shut off the headlights.
DaveT replied to john54's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere should be an online FSM for that, you can find every connector in those.
99 Legacy 2.2 missing when cold, OK when warm
DaveT replied to LeolaPA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCTS can fail in ways that mess up drivability without causing a code. There should be a chart in the FSM that shows temperatures vs ohms. If it's not steady, and in spec, it's bad.
DaveT replied to jmoss5723's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPut them back together with anti seize coating everything. Come apart no problem next time.
85 gl wagon lift questions
The adjustable front struts have a plate with 2 nuts under the pan that the bottom of the spring sits on.
MY04 Liberty 2.5i Auto Radiator Leak
DaveT replied to ALib's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX04 with original radiator? I'd replace it.
That's odd. Try using the old wire on that plug. Or the old #1 wire. The idea is to swap out the wire, to verify that the new one isn't bad. I only use NGK wires.
High Idle 1980 BRAT
try finding a factory service manual, or someone who has a link to one. There should be a step by step procedure in there. 1400 is really high, if it's all warmed up. I've never had an 80 with a carb, so I can't be much more specific.
overheating puzzler/ 2007 forester
DaveT replied to trebor's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, what happened before the new radiator and thermostats?
Good or bad Idea?
Look up the roadkill episode of this on youtube. They did it and dyno tested it. Waste of time.
- Emission test fail Nuts.
any arc like you describe is going to interfere with ignition. It is not normal, it's failed insulation.
