86
Everything posted by DaveT
I am not inclined to cheat it, I'd rather fix it. I'll have exhaust temps when I get home tonight, and I'll start checking for leaks etc. I have 60 days to get the free retest, so not a panic situation. The idle didn't seem odd on the drive to work today, but Ill have to put my real tach on it also, as I know the dash one may not be accurate at the bottom of it's scale.
Would a wideband O2 sensor give me a reading I could use even if only in a relative way to tell when I've got things working right? I could install one along side the stock one. Not actually use it for engin control for the testing. also use my 2nd car as a reference to get good numbers.
1999 Legacy
DaveT replied to scoobes182's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I'll add that using the temperature gauge as an indication that the coolant system needs attention is how to guarantee that you will be doing a headgasket job. If the temperature guage goes above normal, (not even into red) while the system is low on coolant, the headgaskets get damaged. Routinely checking the coolant levels and condition of all of the several hoses and the radiator is what needs to be done. Check for air bubbles in the upper radiator hose by sharply squeezing it and listen for gurgles and the giggle pin. Check the level in the recovery tank. Monitor changes closely. Don't routinely open the radiator cap, as you let more air in. If you begin to see a trend of coolant dissappearing, start looking for a sneaky leak. -
Mine is SPFI. I think it has maybe one more time before no more testing. My 87 had its last time already.
Yes, but I don't remember running into this one before. IT should have been up to temp. 30 minute drive, but then had to make a couple quick stops before going to the emission place. rich and high idle... I should check the CTS.... Would a miss not be felt in rough running / idling? I know the O2 sensor can be off spec and not cause a code, so probably wouldn't hurt to replace the old one. Haven't replaced one of those due to known failure in quite a while. Vacuum leak, ok, I know how to check for that.
My 1993 Loyale w/3AT 4WD. California version Resealed engine installed, by me. Custom stainless exhaust, by me. Running a 180 degree Stant thermostat, the good ones. . It's been running normally. Not burning oil at a crazy rate. Heck, I had an engine that burned a quart per fill up, and it would pass. More than once! Any ideas on what is a typical cause / first things to look at for high hydrocarbons emissions? Has anyone heard of any method of testing for HC? My biggest annoyance of the whole emissions thing is that I have to troubleshoot blind. I'm going to attach my temp probes to check the catalytic converter tomorrow while driving. Test from 2 years ago - PASS: Hydrocarbons = 20ppm Limit 167 ppm CO = .16% Limit .89% HP = 12.1 RPM = 1985 Temp = 167 F Test from today - FAIL: Cruise Hydrocarbons = 102ppm Limit = 220ppm CO = .78% Limit = 1.2% RPM = 2441 Idle Hydrocarbons = 577ppm Limit = 220ppm CO = .54% Limit = 1.2% RPM = 923 Of course, just to "help", they changed the test form. grrr. But the main data seems similar.
Another alternator swap... From a Ford.
DaveT replied to Tims Toy 500's topic in Old Gen.: 80's GL/DL/XT/Loyales...
What ANIM wrote sounds good. -
A few things cross my mind: Isn't it possible that they guy the got that engine from mislead them about the mileage? I know that oil is for the lubrication, but I also have some recollection of it aiding sealing/seating the rings, thus helping with compression - so is it possible that for whatever reason [storage position not level?] that 1 cylinder has less oil? It probably would take a fair amount of cranking to be sure oil is distributed everywhere. Unless it's only been a short time since it was run? Popping the caps out, yeah, not impressed. Ok, it's more or less functioning, but far from any kind of accurate evaluation. I never did a low speed compression test by hand, so I can't say what's normal for that. I'd think the mileage discrepancy would / should qualify you for a 2nd try or reduced price. The legality of the recording may vary by state, so check locally.
You will need a new heavier output wire, the stock one is too thin, and the fusible link will blow out. Those pictures look like some sort of aftermarket high output add on. To even try to figure out the control wiring, I'd need the Spec sheets with schematics and or schematics of the original vehicle it came stock in. -
What I do is find a car with a rust free / low rust body. Add some Waxoyl . repair anything else. High milage generally doesn't matter. I found a local dealer guy that buys high milage subarus fron the auctions and dies the typical stuff like headgaskets, and other mechanical wear issues. For newer models, like in the 2000s.
The water pump circulates the coolant through the engine, and though the radiator when the thermostat opens. It does nothing to draw water from the tank. The coolantern is drawn into the radiator from the tank during the cooldown from normal operating temperature to ambient temperature, if the system has no leaks.
- 14 replies
- Thermostat
- muffler
(and 3 more)
Tagged with:
Well yeah, it's worth checking anything you can see without removing it. But we know that some wiring has been mucked with underived the dash. I have had a few wagons that got very rusty before I retired them due to the rust. Never had one gas gauge fail.
Agree. I've seen nothing that makes me think that sender failure is common.
I class got an 01 Forester from a local small dealer that does essentially what you describe. New headgaskets, idlers, waterpump. By default, that is a reseal of most potential leaks. Had it for a long time, had over 200k miles on it when it began to get to rusty for my wife, and she wanted a newer one. Normal timing belt and idlers change interval is 100k miles. During the years we had it I did brakes, coolany system hoses - if them, there are several. Front wheel bearings, axles, catalytic converter. And the timing belts. And all the things that are just typical wear and maintenance older cars. Get in the habit of checking the coolant regularly, by sharply squeezing the upper hose, and the level in the recovery tank. Don't open the radiator cap just to check unless the hose test shows signs of a lot of air.
- 3 replies
- head gaskets
- used
(and 6 more)
Tagged with:
Yes this is pretty odd. I've never used stop leak, and have never seen a heater core clogged. Even my 87 is still fine. I had one engine that was leaking coolant and I kept it going by just adding water all the time, and it built up a little coating of minerals from the water, but nothing like that.
Newbie fixing unknown problems...
DaveT replied to Shortaay's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes, that's what I'd do, just take it a step at a time. 1 wire sensors seem to be gauge only, at least in these cars, except the O2 sensor. -
Coolant temperature sensor has 2 wires. Spfi has them, not sure about carbed. The temp gauge sensor only has 1 wire, no effect on running. Likewise oil pressure gauge. If it has a CTS and ecu, I've had those mess up drivability. -
Let us know what happens. I have harnesses I can compare and FSM I can look stuff up in. It's be easier for you if you can find a full FSM as all of the harness details are in there. Sometimes we get bit by these sort of weird things, and the silly fuse is the problem. Frustrating as it can be, I figure at least it wasn't something worse / weirder.
