86
Everything posted by DaveT
While trying to find the cause, check that coolant level and fill before each drive. Level in overflow, and check the radiator by sharply squeezing the upper hose. Listen for the giggle pin and gurgles. More air each time, bad, find the leak. Less air, ok, good. Run over normal temperature while low on coolant has always lead to needing headgaskets in my experience.
Need to test fuel pressure in the supply line. Without the clamp on the return line. Low points to regulator, even though its new. High with the clamp points to injector. I doubt it is normal.
Newbie fixing unknown problems...
DaveT replied to Shortaay's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That's where a fsm for your year can really help. Mostly, the wiring didn't change a lot, but some things did. -
I can use the example of my 86 wagon. It came with manual mirrors. I discovered that the harness was there for the Power mirrors. A trip to a scrapyard and I had power mirrors by plugging in the 2 mirrors and the switch in the dash. -
EA82 broken wheel hub (maybe)
DaveT replied to Letters909's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Maybe the bolts that hold the caliper on came out or broke? -
Could be the pressure regulator is stuck open. Fuel pressure is supposed to be 21PSI. A gauge would help. Not a whole lot in the FSM to help troubleshoot, which surprises me, as they usually have a lot of info. I think the regulator is the shiny thing the return line is connected to. I'd swap a spare one in place to test.
Lock cylinder interchangeability
DaveT replied to superooo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ah, I never had an ea81. That's why I don't know. -
You need the entire rear suspension and trailing arms. You need to fab a center bearing mount for the driveshaft, if it is the same as a wagon. You need the whole front wiring harness, probably the dash harness also. Might as well take the instrument cluster also. The turbo radiators were 2 rows of tubes, rated for higher heat transfer. I'd get the whole car.
New member new to owning a loyale
DaveT replied to Yellowbugeye03's topic in Meet n' Greet. Your USMB Welcome Center
Hi! Look though the older generation threads. Unless you know things were well taken care of - Typical things to consider. Radiator condition - fine fins still attached to the tubes. No leaks / cracks. Cooling system should be watched closely, at least until you are certain all is sound. All 7 coolant hoses should be replaced if they are unknown / or original. Coolant should have very little to no air [sharply squeeze the upper radiator hose, listen for the jiggle pin, and gurgles] Recovery tank should be at the full mark, and not change day to day - check cold. One of the alternator brushes typically wears out at about 150K miles. Timing belts and idlers - replace around 50K miles. Check the CVJ boots for split open, better to catch them before they are ruined, as the aftermarket ones are not so good. Check all the other typical wear things, like brakes, etc. -
parting out 86 gl sedan, mostly rust free
Ok, good. -
90 loyale is SPFI. 86 GL is most likely carburetor. Different fuel pump. So check. -
Not sure if there's might be something confused here? The tensioner sheaves are sheet metal, pull off fairly easy. Removing the riser from the flat bracket, drill the sage off. The originals the riser and the center race are 1 piece, which is why I turned my own on a lathe. The gear idler, just use the gear puller / splitter as needed.. I use an old bearing with the outer race ground down a few thou as a tool to get the new one pressed into the proper depth. Note all EA82 stuff. But the newer ones look like they should be handled similarly.
Please help. Fuel pump installation problems
DaveT replied to Rambo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Cap / clamp them off. I'd avoid hitting them. Make sure there isn't any fuel wetting the area. Otherwise, shouldn't be a problem. If one happened to be very close to a heat source, a piece of aluminum would work as a heat shield. The link below shows my fuel pump repair tricks. http://www.dynahoedave.co.nf/fuelpump.html -
Some of the idlers are rebuildable as they are. Just press off the old bearings and support bosses, and install new. For ones like the EA82 tensioners, I drilled out the swaged side of the riser. Turned a new riser on a lathe. There needs to be a shoulder so the new bearing presses on and sits .530" from the surface of the flat bracket part. Drill through the center while still chucked, tap the front end for a socket head cap screw to hold the bearing on. Turn the opposite end down to fit the hole in the flat bracket part, swage the riser onto the flat bracket. I'll try to get a webpage up in the next few days with a picture or 2. Before I made these, I tried re greasing a bearing or 2. OK for a short term fix, but I wouldn't trust them, especially on a 100K mile service interval. Back when I made them, there were no aftermarket idlers, Subaru wanted $90 each, and bearings were about $9.00. And I found they needed replacement around 50K miles, not the 60K interval in the fsm.
If they snapped off from being stuck from rust, do not even bother with an easy out. I'm not sure if I would try the weld a washer to the broken bolt trick for this, as they are so small, and upside down. It is amazingly effective on 8mm and up though. Drill them out is what I'd figure. The rusted screw / clamp thing, just grind off the head and the nut, replace with new. -
Technical service bulletin. It's a Subaru to dealer shop thing.
Anywhere I can read that tsb?
A few things - Has it always been this way? Did it recently begin? Check all the typical tune up stuff. Correct NGK regular spark plugs? Or 1 step cooler. NOT platinums or any other "high tech" ones. Correct operating temp / thermostat? PCV valve working correctly? Vacuum leaks making it run lean? As far as no codes goes - I had an O2 sensor fail years ago, in a way that burned out the catalytic converter - without generating a code. Also, a Coolant Temperature Sensor went bonkers, but never out of normal range, so never threw a code. Neither caused pinging I just mention these to demonstrate that no codes doesn't mean that everything is correct.
Worth a shot. I had trouble with pinging the whole time they were using MTBE in the fuel around here. When it was changed to ethanol, most of the pinging stopped. Only get it occasionally now. I run 87 now. I also ran some stale gas for a while, it didn't ping. I'm guessing, something may be a bit out of spec.
Do yourself a favor and get a factory service manual, or find online scans of one. The fuel pump will only be powered for about 3 seconds if the engine is not running, so it would be easier to out the meter or test light where you can see it from where you can turn the key. You need a pump that can supply around 25 psi iirc. -
86 gl10 with A/C & Fan motor issues
DaveT replied to scoobiedubie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Get a scan of the fsm schematics. Troubleshoot the heater fan with that and a voltmeter / test light. I never had a GL10 so no easy guesses for me. Also have not had many heater fan or ac problems, other than the lowest speed failinf, or a freon leak. -
I've always gone to Subaru for the timing parts on the interference engines. For a 100k mile parts, it's not worth the risk to "save" $. For my ea82s, I made rebuildable idlers and buy high temp contact seal bearings from industrial bearing supply shops. I've used gates belts until now. Not so sure about that now, going forward.
