86
Everything posted by DaveT
Drilled through stuck intake bolt... and head bolt.
DaveT replied to Corvid's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm not sure about what to do with the head bolt as far as remove and replace. But if yo decide to try to remove it, get the block up to near normal operating temperature with heaters and a heat gun. Meat thermometer or something to monitor. I have removed many very stuck bolts intact with that method. It has not failed. Once a bolt is snapped, my next trick is weld a nut or washer to the stub, then unscrew. This I learned before the heating the block trick, but it works once the damage has been done. I mention these also to possibly save others trouble if they read this before snapping a bolt... The drilled through headbold may fail where it was drilled, so you may be removing the head.... -
They should.
Sounds like a bad / dirty connection.
I'd try to fix it. Get it apart. Probably need a radiator, I'm surprised it did break.
I'm pretty sure the green connectors didn't set the 35 code. A loose connection is likely to set a code. My Solenoid mod: http://www.dynahoedave.co.nf/solenoid.html My exhaust mod: http://www.dynahoedave.co.nf/exhaust.html
I had one fail for high nitrous. Bad Catalytic converter. You can test the cats. Run the car for a good drive at normal temps. Measure the temp of the exhaust pipes where it enters and exits the catalytics. The temp should be something like 100 degrees hotter on the outlet side of each cat. Find one the same or cooler, there's your problem.
Need Headlight help - 1993 Loyale
DaveT replied to ubtripn's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It has been my experience with the Hitachi alternators that the brushes last about 150,000 miles. The failure shows up gradually until the battery is so low on charge the car won't start. Alternator light didn't come on. Once I caught one when the light was glowing very dimly at night, before I switched on the lights. -
Just move the pressure sensor to the new pump.
There isn't a lot to the oil pump. Guessing you have an EA82 engine. A couple of o rings, on special, and a shaft seal. For EA82 engines, from at least 86 through 93, the pump is the same. So you can try looking under Loyale also. The only thing I ever needed to do was reseal the oil pumps.
My Compression Test Results..EA82
DaveT replied to Len Dawg's topic in Old Gen.: 80's GL/DL/XT/Loyales...
IF it has not been run hot with low coolant, it might be only a failing intake gasket. Get OEM intake gaskets, no sealant. They are made almost like headgaskets, reinforced so they don't fall apart. Are made to shift a little with expansion also. -
More specifically, how many miles on the timing belt? They are supposed to be changed at about 100,000miles. Over that, you're on borrowed time.
- 6 replies
- solenoid
- fuel filter
(and 4 more)
Tagged with:
Fuel issue~ Fuel pump or something else
DaveT replied to Bratmobile's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Usually (in my experience anyway) an engine with everything correct except no fuel will fire for a second or few on carb cleaner or starting fluid. -
Rear hatch door release from inside mod?
DaveT replied to cnc's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The plastic cover just pops off. It shouldn't be too tricky to figure out a lever or cord. The linkage is right there. -
thread repairs - your choice for our old girls
DaveT replied to jono's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've used Helicoils. Have not had any trouble. The fancier threadserts sound good too. -
The cone washer is thick, and has a split / slit. The spring washer goes on next, and the concave side toward the hub. The concave / convex is subtle, so look closely. If you really have a flat washer, that might be part of the problem.
It wouldn't surprise me if the splines were damaged on both parts during the original problem Check the cone washer, the spring washer were installed correctly, and in good condition. Also, not a bad idea to double check the tightness after a drive or 2 after you reassemble it.
Running hot with low coolant will cause headgasket failure. Repeating this will accelerate the failure. I've caught a mild blow early, and managed to drive for a few months, but I checked coolant every day. Eventually the consumption increases and you have to face it. The number of trips you can cheat it is not predictable.
EA81T, 3AT, ATF spews out the dipstick tube
DaveT replied to mikeshoup's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have never had a turbo. On spfi and carb ed engines, the vacuum modulator can fail and the manifold vacuum sucks the atf out until it runs low enough to slip, or you notice the cloud of smoke. But these engines can burn a lot of oil without smoke.. blown headgaskets typically is exhaust gasses pushing into coolant system. Which causes low coolant, which causes overheating which causes blown headgaskets. I have had only one badly overheated blow so bad that oil and coolant mixed. -
I've never heard of headgaskets causing that to happen, so that is unlikely -
That seems pretty weird to me. Mine are all EA82 with 3AT. Never had that happen. -
1986 GL carbureted to 1988 SPFI plug and play?
DaveT replied to firehawk618's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You definitely have to stay on top of it to keep them around.
