Everything posted by DaveT
thread repairs - your choice for our old girls
I've used Helicoils. Have not had any trouble. The fancier threadserts sound good too.
stripped hub?
The cone washer is thick, and has a split / slit. The spring washer goes on next, and the concave side toward the hub. The concave / convex is subtle, so look closely. If you really have a flat washer, that might be part of the problem.
stripped hub?
It wouldn't surprise me if the splines were damaged on both parts during the original problem Check the cone washer, the spring washer were installed correctly, and in good condition. Also, not a bad idea to double check the tightness after a drive or 2 after you reassemble it.
Bad head gasket(s) in ej22, still coping with it
DaveT replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRunning hot with low coolant will cause headgasket failure. Repeating this will accelerate the failure. I've caught a mild blow early, and managed to drive for a few months, but I checked coolant every day. Eventually the consumption increases and you have to face it. The number of trips you can cheat it is not predictable.
EA81T, 3AT, ATF spews out the dipstick tube
I have never had a turbo. On spfi and carb ed engines, the vacuum modulator can fail and the manifold vacuum sucks the atf out until it runs low enough to slip, or you notice the cloud of smoke. But these engines can burn a lot of oil without smoke.. blown headgaskets typically is exhaust gasses pushing into coolant system. Which causes low coolant, which causes overheating which causes blown headgaskets. I have had only one badly overheated blow so bad that oil and coolant mixed.
I've never heard of headgaskets causing that to happen, so that is unlikely
That seems pretty weird to me. Mine are all EA82 with 3AT. Never had that happen.
1986 GL carbureted to 1988 SPFI plug and play?
You definitely have to stay on top of it to keep them around.
head gasket replacement, questions as I go...
EA81 don't have cam towers or o rings.
3AT Problems in 86 Leone Turbo
Checking the governor sounds good. I have not had that combination of trouble. There are a couple of servo tubes that can fall out and loose functions. Drop the pan to check those. I had one fall out, lost 3rd and reverse. A factory service manual has a very detailed description and diagrams explaining the workings.
They are supposed to log more than 1 code at a time. I may have had 2 at the same time once or twice since 1988. Supposed to blink them out sequentially. I have not seen a failure of that speedometer sensor. EGR & Evap mods: http://www.dynahoedave.co.nf/solenoid.html
- Fuel issue~ Fuel pump or something else
87 GL Retire
Start by just pulling the rocker cover.
Help tell me what i found in oil pan!?
Looks like one of the pins they put to align halves of the block, or heads, or engine to bell housing. Kind of odd to find one in the pan I guess . ..
The oem solenoids are notorious for failing open. I replace them with ones from toyota. I came up with that mod around 1989 +-. Still using the same ones that I bought at a junkyard back then.
Ea82 high idle
where do you get one of those for only $20.00?
87 GL Retire
That low pressure could be something as simple / stupid as a broken valve retainer. I had that happen to my 78 once, ran it home on 3 cylinders. I am running an 87 GL and a 93 Loyale. For as long as I can, just because I can. I prefer the size shape, etc. Been doing repairs on them since 1988, have all the special tools, tricks, FSMs, spare parts from others that rusted away from me. Don't want OBD II or airbags. More power / speed would just make it more likely to get in trouble. If the body is good on yours, find a parts car with the stuff that's shot. Or if someone on here parts one out.
Oh, nuts. Missed the EA81. Sorry.
Loyale door replacement.
I've taken a couple of doors apart. As I recall, all of the window mech unbolts from the door, so it should be possible to swap everything.
My 86 had crank wondows. Also had manual mirrors, but I discovered that the wiring was there for the Power mirrors. I got a pair of power mirrors and the switch, plugged them in. One of the simplest upgrades ever.
2005 outback with 97k miles. Do timing belt now or wait till 105k? Is there a write up of the job?
DaveT replied to vtwinjunkie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI agree, might as well do it.
Head Gasket Problems Still?
DaveT replied to Mary32's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like headgaskets. Re using a headgasket. .. asking for trouble. From what I have seen on this new generation forum, it is very similar to my experience with EA82 engines- if the coolant gets low, for any reason, and the temp Guage goes above normal, head gaskets are damaged. A bunch of variables effect how badly. But the point is, it is too late. You can't use the temp Guage to monitor the cooling system for level, or leaks. You have to check the level in the overflow, air in the upper hose, and that the tiny fins are attached to the tubes in the radiator core regularly. The 1st 2 a lot more frequently than the 3rd.
O ring
The original is between the head and cam tower.
Test drove Outback- What is this sound?
DaveT replied to Stevo F's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXVery likely it needs headgaskets. With the noise, assume you will do a full rebuild or swap a known good engine in. Adjust the price accordingly. The gurgling water got my attention - that's a sign of low coolant. VERY bad for headgaskets. The rest of the description regarding the cooling system is a huge red flag.
