87
Posts posted by DaveT
What can I do to fix that? It's a Trashwagon, it's not really deserving of an expensive shop alignment.
I had alingment trouble a while back.
I found this worked pretty well:
4 pieces of 4x4 bocks.
2 pieces of unistrut (or other straight bar, with moderate weight).
2 tape measures.
Check air pressure in tires. Tires the same make / model / miles. Drive car straight forward to a gentle stop on flat smooth surface.
Put the blocks just ahead and behind each front wheel. Lift the bar / strut by the center, and place it on the blocks, center aligned with the center of the axle. Push on the center of the bar, against the tire. Do this a few times to make sure it is evenly against the front and back edge of the tire.
Place a bar on each side. Hook the tape measures on the bar on the far side, just touching the leading & trailing edge of the tire. Read the 2 measurements. They should be very close, like under 1/8". The FSM actually has specific ranges.
If you use long bars (Unistrut comes 10' long) you can check how the rear wheels align with the fronts also. I found using the 10' unistrut even for the front check handy, because the weight of them kept them from moving around unintensionally while fiddleing with the tape measures.
Before ripping apart the harness, look at this thread:
Test LED - for intermittant troubles
http://www.ultimatesubaru.org/forum/showthread.php?t=64831&highlight=test
I have used this technique to find this intermittant starting problem. On one car, it was a pin in a blue 3 conductor connector under the dash on the passenger side. Another was the contacts in the starter, and dirt on the disk in the starter contactor. I had more than one used starter with worn contacts and dirty disks, so they need to be checked.
But when I'm in 4WD I notice that when I am going slow, and turn the wheels into a turn, it feels like the brakes are being applied, or the axles don't want to turn.
Make sure all 4 tires are the same brand, size, and miles on them. If you start with 4 new tires and never rotate them, about half way through their usefull life, the front ones will be smaller enough to cause noticeable drag also.
Man, you got it stuck good!
How about a drill made for drilling bearing races? I forgot the exact name but I have seen them in the MSC catalog.
http://www1.mscdirect.com/CGI/NNSRHM
I think they were carbide. Maybe a diamond drill?
What if you had all the money you could ever want with one catch..u could only spend it on your current subaru.
Ok, rebuild the body with 316 stainless steel. (or maybe another alloy, if there is abetter one)
Rebuild all the steel suspension parts w/ stainless also.
Do something about the @#%$^@# timing belts - wider or replace w/chain. Or push rods. My EA81 NEVER broke down and stranded me on the road.
Or build a 6 cyl turbo Diesel boxer. Maybe make it about 150HP. And whatever changes to the transmission ratios to deal with the lower RPMs.
Also maybe electric would be fun - not a typical wimpy one - one like this:
http://www.wired.com/wired/archive/7.03/drag.html?pg=1&topic=&topic_set=
They all seem good. How do I check the struts?
On the rod that goes from the top of the strut to the mount in the top of the wheel well there is a hard plastic / rubber bumper. I found one had broken loose and was rattling. It can be hard to see, there is a plastic shield over the piston rod, and all this is inside the spring.
Yes, the resistor is the means of varying the speed. There are 3 resistors connected end to end. One end connects to the full speed position of the switch and the +12V. The far end is the lowest speed, the 2 taps in the string are the middle speeds.
To devide in between, you would have to add taps into the coils of the resistors.
A switch will always have steps for each speed. If you get a switch with lots of positions, it can get to the point of being very little difference between such a switch and a rheostat / infinitly variable controller. Of course, such a switch would not be cheap, and you need more resistors.
hate to tell you, but a failed cat code is 95% of the time a bad o2 sensor.
nipper
Just adding to make sure we are all on the same page:
The earlier bad cat code (I don't remeber the number any more) was like 2 years ago, and went away when I replaced the cat. The mechanic at the place I got the car did a bunch of checking and was in agreement to replace the cat.
I guess what you are saying, if you are referring to this earlier problem, is that the rear O2 sensor could be out of calibration, making the ECU think the cat was bad?
Some more electronics / heater blower details:
The electric motor that turns the blower is a 12Vold DC motor. What ever DC is applied to the 2 wires that connect to the motor will make it spin. 2 volts it spins real slow, 12 volts, it spins real fast. Anything in between, it will be in between.
The resistor block is the lowest cost way to make selectable speeds. A rheostat (power variable resistor) could be used, but they are big and expensive at the power level required for the blower. I looked up a quick guess one. 3" diameter behind the panel. Cost $40.00 if you buy 100. Probably would run hot enough to melt plastic at some settings. But that one can't handle the 10Amps max current. For that, you need the $360.00 per 100 pcs unit.
The heater core is fed water from the engine, bypassing the cooling system thermostat. The temperature lever on the dash moves a big flap that forces the air in the blower box through the heater core or around it.
A 555 with a BIG transistor would work, but not be much better than a linear regulator. My initial variable speed controller was similar to that.
A switched mode controller is much more efficent. (Smaller heat sink)
Go here, look up buck mode / simple switcher:
specifically:
http://www.national.com/pf/LM/LM2673.html
If the link doesn't work, search for LM2673. This chip is too small for the blower motor. It can draw 10 or 20 Amps at full speed. But it is a place to start if you want to see how a switcher works.
For anyone interested in electronics, from beginner to advanced:
If there is more interest in this, I can look for the schematics for the controller I built.
If I remeber correctly, many of the parts can be scavenged from PC power supplies.
I'm not sure, but I think this model has two oxygen sensors, one upstream of the cat, and one downstream.
Yes, it has the before and after. I learned about that a while (year or 2) back, when the CEL came on with the code that says the cat isn't working good enough. I got the new cat at cost since the car was just out of warranty (used, not new).
I replaced the front sensor for this new trouble code, as the FSM states.
So far, the CEL is still off, at least another 2 cycles on the car.
I initially thought this OBDII stuff would be an improvemnet over the basic system in my loyales, but I am beginning to think that this is not so. I am going to keep my EA82's running as long as possible.
[answering several question]
I didn't check the wiring - I figured that an open or short would have given me one of the other codes for those conditions.
I replaced the original with a Bosch from NAPA. It was around $80.00. It looks the same, but that doesn't mean much.
The engine has not been burning oil.
Not sure if I'm being paranoid, but maybe sometimes not as smooth as I remember. My wife drives the car 90% of the time, so I may have to "take it over" for a few days.
I reset the CEL the night I put up the original post, it isn't on yet today. At least 2 start / run /stop cycles.
what were the numbers of resistence? would voltage regulator work? a hak at it? if original is broken all the time, there must be something stronger...
The biggest one is 0.5 ohm. The second is 0.68 ohm. On the block I have handy, the third is broken.
The one I fixed, I just found a similar length of similar sized nichrome. Probably from an EA81 blower, because I had several of them before moving to the EA82 cars.
The mud condo is probably a mud wasp nest.
A linear voltage regulator would need a big heat sink. The nichrome resistors are all black and crusty because they run hot. That means a lot of power is dissapated in them. A linear regulator would need to dissapte the same amount of power, but has to be kept much cooler.
I did make an infinitly variable switched mode speed controller for one of these blowers I used for another application where high efficiency at lower speeds mattered.
How many miles on the car
nipper
96K
I added a significant detail to the 1st post - I replaced the sensor. Then the CEL came back on today.
A while back, I got the CEL, read the codes. Only the P0133 showed up. Whent through the FSM procedure, ends with "replace O2 sensor".
[edit] I replaced the sensor.
A week or so later, the CEL comes back on, same trouble code. Same result from the FSM..
Any ideas?
I forgot to mention: 2001 forrester
otherwise, some of us still dont understand.
I have a spare one here, pulled the cover off. A piece of plastic has 4 brass tabs molded into it. the 3 nichrome reistors are wired in a string from 1 tab, to the next, next....
2 tabs are at the extreme ends (highest & lowest speeds). 2 tabs are along the string. Each of them has 2 resistor ends connected to the tab.
My original post was refering to the rsistors themselves breaking. Not likely to loose only 1 speed (except the lowest) by 1 resistor failing. And also, from the perspective of repairing the block, or wire.
A wire that goes from the block to the connector could cause only 1 middle speed to fail.
Probably best to remove it and take a look.
You could test it with an ohm meter without removing the block, just pull the 4 pin plug. Expect the resistances to be pretty low.
Here is what you need:
1) T-1 3/4 super bright LED
1) 1200 ohm 1/2 Watt resistor
A few feet of 22 AWG wire
some heat shrink tubing
Solder about 3' of wire onto the Cathode of the LED. This is the ground wire.
Solder 4-6' of wire to the Anode of the LED.
Solder the resistor to the end of the long wire.
Leave the other lead of the resistor about an inch long.
To use the tester:
Tape the LED on the dashboard where you can see it.
Run & tape the wires so they don't get in the way of operating the car.
Connect the ground wire to any convienient grounded fastener.
The resistor lead is a good size to sneak into most of the connetors on an EA82 & older Subaru. It works on the ECU connectors and the ones with 1/4" flat tabs.
I have used this to figure out numerous electrical problems over the years.
Intermitant no crank - Start by slipping the resistor into the signal connector on the back of the starter. If the LED lights when you turn the key, you know that everything from the connector back is good. If it doesn't move it to another of the 3 or so in the harnes back towords the key switch.
I used it to monitor the EGR valve computer signal a while back. If I remeber correctly, the EGR solinoid is activated until the engine reaches normal operating temperature. This disables the EGR valve while the engine is cold.
The LED is great for these intermittant troubles, because you can leave it connected, and check the function every time you use the car.
are you saying that if only #2 is dead then it's probably something else? like the switch?
Yes, the switch, a wire from the switch to the resistors, one of the connectors.
No - it's a coil of "resistor wire", soldering it will destroy it easily, and even if you got a "glob" of solder on the wire you would just create a hot spot that would burn through virtually instantly.
The resistor wire is nichrome. Solder won't stick to it, and the normal operating temperature will likely melt it. Easy Flow brazing alloy, however, will flow on nichrome, and won't melt until it is glowing orange.
I repaired one years ago with a small torch tip.
wait you guys do know that im talking about only the first speed on the 4 speed switch right?? Just wanted to make sure if you are the other speeds are working fine
The resistors are in a string. The slowest speed & highest resistance is at the end of the string, so if it breaks, it is the only speed effected.
Gas DOES need some head room to expand. It comes out of the ground at about 50 deg. F, and then sits in a gas tank at temperatures up to 100 deg. F. It is going to expand. If there is no head room, it will dribble out the fuel filler nozzle.
+1
And it can also get backed up into the evaporative emmissions system. One of the manuals stated that this was not a good thing to do. (I came across it years ago)
]Why did you make your comment re: the driveline than do body work?
Durania717 got it right. It was a partial explanation of the high price for a 19 year old car in CT.
I don't like the idea of the additive leak fix. But I am assuming that I am going to be using a car for a long time. Also, all you need is a few minutes with less than full coolant, and you're looking at headgaskets or worse.
So what are the questions and answers?
So far sounds normal.
I paid $1K for an 87 with NO rust last year. (in CT) I'd rather replace the driveline than do body work.
Some things to look at / check / fix:
Timing belts
Cooling system hoses
CVJ boots
Radiator fins
the EGR solenoid and fuel injector needs replacing.
Here is how to fix the solenoid for <$20.00:
http://users.adelphia.net/~davidtief/solenoid.html
I have not had an injector problem yet (over 16 years w/SPFI subarus)..
It takes about 5 screws on top of the engine, to get the injector out of a SPFI / non turbo, so I don't see why they want $900.00+
There are fuel additives etc. that are supposed to clean out carbon.
So I got tagged by a hit and run and my front bumper got bashed.
I guess I'd start buy removing the bumper to look at the wiring to the L & R lights in the bumper.
If wires are damaged, fix, then go after fuses, blinker
good idea for oil cooler or not?
Posted
Here's a variant on the original:
Would it be better to:
Add a seperate oil cooler.
Find a bigger radiator to make the cooling not so marginal.
Find a way to modify the front / grill / etc to let more air flow throught the existing rad?
