86
Everything posted by DaveT
84 Brat Transmission rebuild...stuck!
DaveT replied to Britfire's topic in Old Gen.: 80's GL/DL/XT/Loyales...
There is a chance that an industrial seal / bearing supply shop might have parts, but you have to match by dimensions, some have online catalogs you can search through. -
91 EA82 wagon howl over 60kmh
DaveT replied to subieroo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That should be ok.... I had one that ran down so low, it didn't show anything. It was an automatic. It was my wife's car, I didn't drive it much, so never caught it early. Found out when the pinion bearing had failed bad enough to let the pinion screw forward into the differential carrier whenever engine braking happened. Ouch. I had another, that I bought used that had turned out to have an empty front diff. Flushed it with a couple fills of ATF / cheap gear lube, and then switched it to the Amsoil synthetic I run. The noise eventually faded away, and I drove it to 200K+ miles before the body rotted off. Never had another problem with that transmission, I still have it. -
Also, Check the gear lube in the front diff / transmission. Loose nut is not good for anything - bearings, axle, hub, cone washer. Sealed bearings, might not be good. Depends on what they were sold as. I once used electric motor sealed bearings for the idlers, and they did not hold up as well as the oem ones, or the proper ones I bought from a bearing supply shop next time. Different applications, but something similar regarding loading and or temperature may be similar. -
My old thread, with details on making exhaust gaskets. Lets see if this link will work.... -
I used to use gates. I've heard they are made in China now. With that cheap price, I would go with subaru. Lowest price is not always the best deal. Or it may be that RA is just trying to get rid of inventory.
I made up gaskets a while back. Posted on here. Layered fibreglass mesh with copper RTV. Details are in the other thread. They are still sealed up. They are reusable, made and cured off the car.
Special hose clamps? Coolant hose on block
DaveT replied to Steptoe's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Stainless and Aluminum don't get along well. Unless you use anti seize, if exposed to moisture, the corrosion that occurs expands and can clamp the bolts worse than rust. How long it takes depends on how wet and how long. -
1991 Loyale. front struts and brake line
DaveT replied to rickyhils's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Clean, re grease, reboot OEM axles. From everything I've seen on here, the aftermarket axles are junk. A long while back, I remember mention of one brand some had good luck with, but I never tried them. I've been rebooting them since 1988. -
Try a search on McMastercarr.com, they might have something. -
From 87 through 94 only minor changes, so I am not surprised it runs. Should be ok. The LED should always be blinking when the engine is running, regardless of the test connectors. Count the long and short blinks, they represent 2 digit numbers. No codes code is all short blinks. If there is more than 1 code, they are listed sequentially, and repeat.
I never had piston slap. Haven't seen many if any mentions of it regarding EA82s. Common is lifter tick . Rod knock if suffered oil starvation or severely overheated. That usually doesn't go away on warm up. Lifter tick may fade with temperature, can also be pretty random.
Also, use anti seize when reassembling.
Swapping an entire interior, 87 GL wagon
DaveT replied to adot's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Bigger differences if one is carb vs spfi vs turbo. -
They are very similar. From 1986 through 1994. There are some differences in the early 90s they went from a regular lap belt to the stupid power lap belt. Some controls changed location on the dash. Most wiring is the same. Also, I discovered things like my 86 came with manual mirrors, but the wiring harness was in the car - so I bought a set of power mirrors and the switch from a scrap yard, and plugged them in. There might be some small changes, but 86 to 87 should be pretty close. -
If you replace it, try to find a used oem axle, and reboot and regrease it. Aftermarket axles are junk. What I do is clean, regrease, reboot a spare one, then make the swap. The hard part depends.... you have to get the knuckle disconnected from the lower ball joint, or the strut disconnected from the knuckle to get enough movement to get the axle out. Some of them press out easily, almost just by hand, some need a big gear puller (or a soft face dead blow hammer ) to push out. Bearing don't like impact, so never hit anything in a way the transfers metal on metal impact to bearings. A big factor is how rusty are things underneath? Use liquid wrench or airokroil a day or so before on the suspension bolts, etc. Brake caliper mounting bolts. The first time or 2 this job can be a bit slow, but it doesn't bother me at all now. Road salt can make things pretty difficult. Anti seize everything when re assembling, and any future work will be noticably easier . Go on the light end of torque range when using anti seize. For the transmission end of the axle - get the correct size drift! The pins are hollow roll pins, if you use one a size too small, it will drive into the hole and jam incredibly tightly making a nightmare you don't want or need. When assembling, verify the holes line up , as the axle will slip on the splines, but there is only one orientation where the holes line up straight. If everything is normal roll pins don't need big blows to move.
I am pretty sure that an 88 should be an EA82 engine. Pretty likely throttle body / SPFI fuel system. How to put the nut on - Tighten. Add a 2 foot long handle to the wrench. The nut is supposed to be around 150 foot lbs of torque. Once it is tight enough you can't budge it without the add on handle, add the handle, and tighten a little, check the holes for the cotter pins. There should be 2 holes in the axle, 90 degrees apart. This give twice the number of positions the nut will line up with the notches on the nut. I do this final tightening with the wheel on, and on the ground, as the parking brake can't always stop you from turning the axle. You are only looking for a fraction of a turn before a set of holes / notches line up. Position the wrench so that you can use body weight to lean down on the handle, but also be set up to catch yourself if something slips. If the nut is not tight, you can get odd noises. And eventually worse, strip the splines out of the hub. Likewise, when disassembling, pull the cotter and back the nut off until it is normal wrench handle tight, then jack up the car and pull the tire off.
What el freddo wrote. Don't bother with anything that claims it will fix it with a bottle of additive, it won't. Headgaskets. Don't drive it any more, as you risk more fatal damage every time the gauge goes above normal while low on coolant. It does not need to get to red to cause trouble. These cars have some peculiarities with cooling systems, there are loads of threads about headgaskets on here. White smoke only happens in some of the possible failure modes, and only when they are very well blown. Mixed coolant in the oil I have had only one time with a very bad overheat, and no smoke of any kind.
- 4 replies
- loyale
- head gasket
(and 1 more)
Tagged with:
The piston screws in. Pressing won't move it until you bend the parking brake screw, ruining it. Bleeder screws do not seal when loose, so you will always have air visible if applying suction to the bleeder. The best / surest way to bleed is 2 people, one to pump brakes, the other open the bleeder, and close after each hold down of the pedal. Some systems the sudden flow helps drag the air out.
Distributor side timing belt snapped again
DaveT replied to montermahan's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The valves should slide freely. I have never had or heard of a lubrication problem due to the seals. -
Yeah, with the engine in back, and gravel, you probably need the covers. The cams get pretty tight feeling just pressing the valves open, I would not turn one by the 10mm hex head bolts, too close to the yield stenth of them. I made a too for turning the cams. Piece of bar stock with 2 bolts tapped and screwed through so that the ends stick into 2 of those 4 holes in the outer edge of the cam pulley. Similar thing to apply torque with a torque wrench, but with a hole in the center for the drive. -
I have been running without the too covers for years now, not sure if it's my imagination, but they seem to last longer. Also, I did catch a failing bearing noise from an idler a whole lot earlier a while back. -
I have only used oem or napa belts. The 3 idler bearings are a disaster waiting to happen after 50k miles, so change the accordingly. Belt tension is about 15 ft lbs torque on the cam pulley, when in the position with that pulley's mark aligned with the mark on th back cover.
