86
Everything posted by DaveT
Make sure all 4 tires are same make model inflation pressure and mileage / wear. In a straight line, even on dry pavement, it shouldn't make a large change, but I can usually feel / hear a small change - with 4 brand new tires.
I've only seen coolant in the oil once. Very blown headgaskets. Not the early initial stages when the coolant just keeps disappearing, or small bubbles in the recovery tank. I've been down this road a number of times. My experience with the coolant level you describe - it may have been drawn down by a slow leak anywhere - to the outside of the block, down the intake. But the level low in the radiator + over normal temperature [does not have to get into or even near the red] has always lead to failed head gaskets, it might be 6 days, might be 6 months. I never had one consuming coolant down the intake at a high enough rate to show smoke [steam] in the exhaust. To have a chance of saving it while troubleshooting, checking the coolant level before every drive is the only way. Do not open the radiator cap, check the bottle level. check the radiator by sharply squeezing the upper hose, and listen for gurgles and the jiggle pin. A tiny amount of air is ok, but a really tight system will have none. The important clue is does the amount of air increase each time you check? Does the level in the tank constantly get lower every time? When the leak is in the beginning stages, it will be very slow, takes a week of doing this to start to get an idea. I also found that running a zero pressure cap helps sort out whether this is air leaking in vs head gasket beginning to inject exhaust gas failure. At high altitude, it might not be a good idea to run zero pressure, but where I am, I never had a problem. When it's an intake or external leak, a pressurized system will force coolant out while hot. While cooling, air sucks back in through the leak. When it's a combustion chamber to coolant leak, the explosions force exhaust gas into the coolant long before coolant can leak into the cylinder. Think about the difference in the pressure involved on either side of the gasket... With zero pressure, there isn't suction while the engine cools, and you loose less while running, because it isn't being forced out. If it's an intake leak, the vacuum will still pull it out, but without the help of the 13PSI pushing it also. You could try just doing the throttle body and intake to head gaskets, but it would be good to do all the above monitoring first, to determine if the exhaust gasses are getting into the coolant, because that only means one thing. Regardless of how far you have to go - removing any of the engine bolts is best done with the engine [the mass of aluminum, not just heating the bolt head is the key] near 180degrees F. Unless you have previously disassembled it and used anti seize compound. I have been amazed at some of the bolts that I got out in one piece using this trick - they would have certainly twisted off if done at room temperature. The worse ones still took carefully rocking them to work them out, but none stripped or broke.
1985 Subaru Brat vibration at high speeds
DaveT replied to Zarengo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If it is a low hum, I usually found that to be the u joint bearings shot, throwing off the balance. Wheel bearings could do that sort of low note vibration also. If it's more of a shimmy like 1 pulse per revolution if the tires, that's more likely related to alignment, suspension and all that stuff. I did have a weird 1 ppr shimmy when a tire partially failed. The tread separated from the steel belts, forming a bubble. It would be obvious at some speeds, and dissappear at others. -
IF it is a EA82 engine, that looks different than any I have had. Do they claim it is for your car? Normally, they have the inlet and outlet pipes in line with each other - that is, you could put a straight piece of pipe in place of the housing without moving anything. The one in the picture in the link the outlet pipe is offset to one side. On all of the EA82 style cars, that "resonator" is not a resonator, it is a second catalytic converter. That may or may not matter to you, depending on the laws in your area.
Idea for 4 pin module turbo dizzy
DaveT replied to Steptoe's topic in Old Gen.: 80's GL/DL/XT/Loyales...
For drilling the stainless, or moderately hardened steel, I found there are bits for the purpose. They are solid carbide. Must be used in a drill press or milling machine, not a hand held drill. I drilled a hole in a hardened stainless steel part with one. The kind of stainless that instantly dulls even a cobalt steel drill. The drills aren't that bad price wise, but if you want to tap the hole..... -
I don't have 1st hand experience with this, but have read a number of threads - knocking in ea82T is quick death..
Yes, but this is typical of air in the system. If all is well, the amount of air will diminish over a few drive cycles. Re read my previous posts, they cover how to monitor what is going on, and determine the earliest beginning of headgasket failure or something else. If the air does not reduce over a few drive cycles, headgaskets are suspect. A small leak can cause this also. I run a zero pressure radiator cap to eliminate that possibility. As the number of over temperature events increases, the headgasket leak from combustion chamber to cooling system will get worse. Eventually there will be no question.
Rust free is rare around here also. CT. I have 2) 4WD 3 speed auto wagons. Start collecting parts. Many are NLA. Watch ebay for a FSM. Learn how to do your own repairs.
PROBLEM! 89 GL power surging???
DaveT replied to scrubaru12's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Avoid driving it with that going on. IF you must, turn on lights, blower, etc. to load it down. The times I have had over 14V have been caused by the voltage regulator, which is in the alternator, going bad. I have zero experience buying alternators, as I rebuild mine. Possibly a bad ground. Possibly a bad alternator. I have read more than a few threads on here where the new alternator was also bad. But if the problem is exactly the same, more likely something else. Check the connections between the alternator and the fusible link box and the battery. Just a guess, not sure if an intermittent connection there could cause this or not. If the battery cranks the engine ok, I tend to not blame it. -
changed the wheel bearings and seals on my 87
DaveT replied to subpoop's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If your original cv / front axels were damaged by the towing incident, look for used oem. Clean regrease and re boot. Lots of threads about this. For driveshafts - the one from the transmission to the rear differential, find a local driveshaft shop. A good one can get parts and rebuild them. -
These engines are made to spin fast. 4000 rpm is no big deal. Lugging them is a bigger problem.
- 6 replies
- gen 1
- torsion bar
(and 1 more)
Tagged with:
Yes, the first couple times many years ago I let one get low on coolant. Learned the hard way. I've owned several EA82 powered wagons now. Some came with existing issues. Been there done that as far as not wanting to give in and do the headgasket job. The limp mode has been used to buy time while resealing a spare engine. That good engine eventually is moved to a body in better condition when the original gets too far gone from rust.
It all depends on how bad the damage is. I had tried the air spark plug thing, long time ago. Nothing conclusive. Same with the pressurising the radiator. The pressure of the fuel exploding is far higher than an air compressor. Thats why the first sign is bubbles in the coolant . my leaks were just beginning at that time. Yes, eventually when the failures are bad enough, you will get a detectable result. By the time one spot has failed to that point, it would not suprise me for other failures to have begun. You can try lot of things. The risk is loosing all the time and have to do it all again. I have limped one along for as much as 6 months by using a zero pressure radiator cap, and adding water before every drive. And no long dtives. The leaks slowly got worse. In the end, they have needed new headgaskets.
pesky coolant hose - block>thermostat
DaveT replied to jono's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Beware of using fuel line for coolant! I did that once, many years ago. It failed in a fairly short time. Chemical properties are different for fuel vs coolant. -
Yes, the typical beginning of head gasket failure is small amount of exhaust gas injected into the cooling system. When it first starts it is so small that the tests don't detect it, but you can by monitoring the coolant level before every drive. Once you have experienced this a couple times, you know.. BTDT. It slowly gets worse, until coolant is spewing out and you can't go anywhere before it's overheating. More over normal temp excursions while low on coolant accelerates the failure. By this age and likely mileage, it is due for new head gaskets & up reseal anyway. No way I know of to determine which cylinder is leaking first. No evidence of coolant into the cylinders until much more blown, and you won't be able to drive by then anyway. Only once did I have a head gasket fail so bad as to leak coolant into the crank case, and that was a bad overheat, and likely a few mild ones before. Replace them both, they have been compromised already. Resurface the head is a must. Be sure the radiator is in top condition - especially that all of the fine fins are connected to the tubes, and not blocked by dirt on the outside, or good for nothing [causes more trouble than it fixes on these engines] stop leak on the inside. Make sure all 7 cooling system hoses are not close to 30 years old.... Yes, 7 hoses.
I'm pretty sure that the threads are cut into a stamped nut that was welded to the sheet metal. I would not try to weld then drill and tap... Unless you are an expert welder and know what alloys to use. There are solid thread repair kits similar to helicoils that I would be inclined to look at. Try a search on McMastercarr.com . If there is space, maybe sneak a regular nut in behind the stripped one?
Possibly just didn't get all the air out . Also, this is symptoms of headgasket beginning to fail. Over heating, or even over normal temperature , while low on coolant is very bad for headgaskets. There are a lot of threads about this on this forum.
To check the coolant in the radiator without opening the cap - squeeze the upper radiator hose sharply, and listen for the giggle pin and air gurgles. Once you do this a few times, you can begin to determine by the sounds the amount of air in the system. There should be very little to none. When you open the cap, it intruders a small amount of air, so it can make it difficult to determine if there is a problem developing when the leak or damage is very small.
Be sure to watch the coolant level like a hawk. Like before every drive. Water sound in the dash means very low on coolant. My experience has been that after such an event as you describe, low coolant + over normal temperature, is that the head gaskets are damaged. It is a matter of time and cycles until the leak gets big enough to be noticable if you only check weekly. And each low coolant overheat accelerates the failing. Doesn't hurt to be certain before resealing, but be watchful to avoid worse overheat damage.
Who needs keys? or locks re-keyed?
DaveT replied to robmillion's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Mine are working. But this just made me think of getting copies made, since I've worn out keys in the past. Not sure if anyplace local would still have blanks. Don't need OEM, just want them to work. -
are key blanks available for the loyale models? -
There is a small port for each of the far side vents - the ones near the roller wheel on either side. When those are set to the vent position, air flows if the car is moving. The other setting connects the vent to the HVAC system. The main one is where the blower intake meets the firewall. There is also a door there that closes the port and opens the blower intake to the cabin for the AC max setting.
It is difficult, as you have to pull the rocker covers and the towers first. Main idea is loosen the (any and all) bolts while it's hot. In reality, the head bolts and even the tower bolts, I'd wait to get it out first, the use the heater and heat gun. Near normal operating temp is what you want. And heat deep enough to get to the aluminum where the threads are. That's why long time with the electric heat vs torch. I have saved myself a lot of grief dissasembling these old ones with this trick.
Oem or Fel Pro head gaskets Oem only intake gaskets and the o rings for the oil channel to the cam towers. I have always re used the head bolts. If any were really rusty, swapped them for better ones from a spare engine. Heads must be resurfaced to remove the marks from the fire rings. Search for post apocalyptic resurfacing. New water pump and thermostat. Verify that your radiator is in top shape. Fins still attached to the tubes, etc. Other most important thing.... Idle it up to normal operating temperature. Shut down and go to work carefully loosening the intake manifold bolts and head bolts. This deep heating really lowers the chances of breaking them off or stripping the threads. Use a space heater and heat gun to reheat it or keep it hot until you get to the head bolts. Work them back and forth gradually if any are sticky. If you are careful, you can feel the difference between springy and yeilding.
http://www.dynahoedave.co.nf/solenoid.html Solenoid upgrade
