86
Everything posted by DaveT
Hitachi Carberator to EFI Conversion
DaveT replied to 89GLWarWGN's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Oh yes, the fuel pump. The fuel pressure on SPFI is 21 PSI, so you need all the hoses & filter upgraded. IF you can, find a copy of at least the schematics from the FSM for both. The FSM also shows connector locations, etc. makes this kind of thing easier. -
I don't know about the links. IF the parts car runs, you just need to swap all the pieces, including the wiring. -
Gen 2, 1985 Brat manual transmission, rev limiter???
DaveT replied to mkoch's topic in Old Gen.: 80's GL/DL/XT/Loyales...
No. Not in the sense of an intentional controlled system. -
Most wipers have a contact in the drive mech. That opens when they are in the park position. When you switch them off, power continues through that switch until it opens.
best headgasket kit for ea82t
DaveT replied to turbodog's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've had good luck with fel pro for the non turbo EA82s. For the intake gaskets, and o rings for the oil passages, dealer only. -
Service Manual question?
DaveT replied to Checkerboard Comet's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Looks very much like my 86 GL wagon did. EA82 engine. Mine was a 4WD with a 3AT transmission. Same color. The mirrors were the newer type, integrated with the door, different glass, not separate posts. -
GD is usually right.... It has been a long time since I bought a FSM. Both I got at dealers, but the car's were in production at the time. I use my 86 and 90 manuals for all the years between 86 and 93, there are only some small differences. Any fsm from 90 to 93 would likely be very close. The bigest differences I found were in the late 80s, 86-88. -
Odd... Idle oil reading hot is always very low. On all of the several EA82 cars I have owned. It's only around 5psi. You have to connect a mechanical gauge if you really want to know what's going on. When you did the reseal, did you remove the oil pump? The only seals that could cause a change in oil pressure are the o rings and shaft seal on the oil pump.
To read the codes from an EA82, just count the blinks on the LED on the ECU. It's bolted under the steering column. You have to take the plastic kick panel off first. Any current code will be flashed there. Long flashes are 10s place, short are 1s place. 2 digit codes only. Everything ok is all short. 5 or 6, I forget. -
Yeah, that angle and stuff effecting the engine running sounds really suspicious. How does the pump get the fuel out of the tank on this version? Could the pickup tune have a crack or other failure that let's it suck air at certain angles / under heavy acceleration? Re the sheild - normal sheild practice is that only one end is grounded. You don't want current flowing in the sheild, it is only supposed to absorb the unwanted signal.
PWM of the fuel pump is highly unlikely. These cars are way simpler than that. My EA82s non turbo, the alternator output is low enough at idle to let the battery voltage drop to where it barely keeps up with running the engine. Especially with other things, like a fan or the ac on. The voltage goes up to charging level when you get above idle. The fuel pump obviously drifts up and down with the fluctuations. The wires to the pump are likely shielded to keep the noise generated by the commutator and brushes from getting into the AM radio, etc.
The problem with those older model engines is so many parts are NLA. If you have a car that needs that engine, and you want it more or less stock, get any you find for parts. But as a swap or something to try to make performance mods on, not a good choice.
If the back belt guide is detached from the oil pump pulley, don't leave it there. The belt should never be pushing hard against the sides, but they are there to help keep them tracking correctly. You won't be able to buy a new pulley, but a used one might be findable. Or try to repair it. The steel ring is staked onto the cenet part. I don't think the center is weldable. I might try brazing if I had to fix one.
If the tensioners and idler bearings are good, they will be quiet. Good idea, removeing all of the v belts for a quick check. Usually, the dead bearings I've had feel dry like no grease, or crunchy if really bad. They should feel a little dragging from the normal grease. Try using a pice of 1/2" to 1" ID flexible hose as a stethoscope. Be wary of getting the probe end near anything windy. That should help narrow down the noise source.
90-94 should be very similar. I have 86 and 90 FSM, and there are some differences, but between both, I use them for all of the EA82 powered wagons I've had, from 86 through 93.
I've not worked on a MPFI - just going by general stuff... Fast idle should only be able to make idle faster, not cut / limit fuel at driving speeds & loads.
T in a fuel pressure gauge. I don't know the MPFI, but I do know the SPFI is very sensitive to fuel pressure.
I have been running without the front covers for quite a few years now... no problems. In fact, I caught a failing idler bearing early once, because I could hear it.
1983 E81 Lock Washer for Rear Axle Nut
DaveT replied to Cincy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That's why I never saw one. 2WD. -
I'm not familiar with that part - but I skipped over the years that version was made. Went from a 78 to an 86. Maybe someone has an extra. Try ebay? It would be a pain in the neck part to cut by hand, but it can be done. -
I don't know the turbo details well. The black vacuum solenoid on the manifold could be part of the EGR, or the charcoal canister purge. The one screwed into the lower runner is a thermally activated valve.
When you replace the timing belts, replace the idlers.
