86
Everything posted by DaveT
Loyale rear wheel bearing
DaveT replied to XHighOctanex's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have a thread with pictures, somewhere. No photo bucket involved. I'll have to look tonight. -
The clearances get looser when warm. Be careful about adjusting too tight also. You do want the valves to fully close...
For general cleaning, I use kerosene. Much safer than gas.
AS far as I can see from the pics, it looks like different batches of valves or something was used. Notice the small differences between them. I've never done much about cleaning everything, just get rid of loose stuff, wire wheel the valves if they have lots of crud on them. One engine I rebuilt had loads of crud stuck on the intake side of the intake valves, you can't see it until you remove them. You do need to resurface the face of the heads, either by machine shop, or the post apocalyptic method, to get rid of the marks made by the fire rings of the head gaskets..
EA82 - no compression in one cylinder
DaveT replied to jasonkaye's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've never seen that. Put it in the rare category. -
EA82 Cylinder Block O-Ring
DaveT replied to montermahan's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That's the one I was thinking it might be. I do have an extra one, but it sounds like you got it. I'd have to do some checking in the fsm, etc to be 100% on it. -
I might have a spare one, if it's what I think you are looking for. -
Brake Fuse Blows after 30 min
DaveT replied to rdweninger's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The point of using a moderate size bulb is to allow enough current to flow to help locate the problem. It will light up instead of blowing, saves $ on fuses. -
No, just find wires or test leads or something. MAybe a blown fuse, solder wires to it, so it will still clip in. This is a testing thing, not for driving with, etc. -
Replace the fuse with a brake light bulb for testing purposes. If / when it is lit, and how brightly, will show when you have a circuit vs short Circuit, etc. -
I pulled all 4 rods without splitting the block on an EA82. Checked the clearances with plastiguage. Probably easier with it split, but it wasn't that bad.
Car pulls left after making a left turn
DaveT replied to Nickoli's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have never experienced this problem, but iluvdrt sounds correct. -
Help: Identify SPI throttle body
DaveT replied to torpedo51's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I was thinking that also. It does not look like anything I have seen. -
There is a whole procedure to use the diagnostic connectors. Simply connecting them does not do much. It should be listed in a link somewhere, it's in the factory service manual. To read an active code, you don't need to connect any. The code is blinked on an LED visible through a hole on the ECU, which is covered by a plastic panel under the steering column. The CEL does not blink the codes.
The smallest fastener used by Fuji in the 80's
DaveT replied to jono's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Wow -
To get the torque correct, the threads are oiled, per FSM directions. Never had one get loose.
The timing belt install marks are 3 lines on the flywheel, not the zero TDC timing mark.
The thermostat must be installed with the sensor bulb and spring downward.
You have to run at idle until the thermostat opens. If the temp goes over normal shut it off. Then add a bunch of coolant. Do not drive before getting that air out of the water pump.
Do you have a new windshield?
Thread repair kits are available for spark plugs.
