87
Everything posted by DaveT
SPFI don't have asv. None of several I have owned. In CT, there is emissions. Even the CA car I have doesn't have the ASV.
I don't know. But I did take a carbed engine, swap the spfi manifold onto it, and ran it for many years without trouble. Made plates to cover the asv ports.
That low after only a few hours isn't good. Overnight is usually long enough for batteries to settle to their resting voltage after a charge (any time the engine is run) any loads will also disrupt the accuracy of this check, except for things like the clock and radio keep alive currents. I always install the largest battery that will fit into the area.
- 18 replies
Ea82 carbs for sale in my area.
DaveT replied to Seasillmaggee's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've been nabbing parts for years, when deals drop in my lap. Stuff is going to continue to get harder to find for these old models. If you intend to keep running a carbed stock car, I'd get them. I only do spfi, sold /traded my only ea82 cab with it's intake a while back . -
Gas pedal to floor while cranking is clear flood mode. The coolant temperature sensor / engine temperature sensor could fail intermittently and cause weird hard starting. Usually causes other problems, like high Idle when hot though. Like mentioned in the previous post, if fuel is leaking from the injector, that would cause a flooded condition. 5 months sitting is plenty long enough to destroy a battery. And sitting also accelerates corrosion, due to moisture condensing on everything, and staying around since no engine heat periodically to dry it.
I'm looking for a few part numbers for the axle boots, inner and outer. These are oem axles, 23 spline. They made the outer cups bigger for turbo automatics and 4wd. At least for the 1986GLs. I'm looking for the bigger ones.
You don't just swap the carb engine in place of spfi. You can swap the intake manifolds and everything above from the spfi onto the heads and block from the carbed one. May hAve to deal with egr differences.
12.3v on the battery, at rest (sitting overnight) is low. That indicates about 1/2 of a full charge on a good battery. Full charge resting voltage should be 12.6v. This probably has nothing to do with the no start, but it's something to look into before it gets worse.
- 18 replies
Adding air conditioning? In addition to the compressor, you need an evaporator, condenser, filter dryer, expansion valve, some electric and electronic parts. You may have to remove the dashboard to get at the ducting to install the evaporator. Might need the piece of duct where it mounts also. Best way would be to get an entire similar model that has air conditioning as you may need harness and controls also. And a factory service manual.
weight oil for summer in Texas for 86 Brat
DaveT replied to stinkydogfilms's topic in Old Gen.: 80's GL/DL/XT/Loyales...
+1 Sapper -
The good, the bad, and the ugly.
DaveT replied to Jes1991's topic in Meet n' Greet. Your USMB Welcome Center
Try using the view as desktop option? -
I'm thinking it's older ones. I think I remember my 76 and 78 wagons having a screw. GLs and Loyales that I have are D shaft push on. I never had a screw fall out.
Stuck roll pin and punch tool
DaveT replied to Cedro289's topic in Old Gen.: 80's GL/DL/XT/Loyales...
+1 what GD wrote. -
Hose size is determined by airflow required by the tool. And length of run if it's unusually long. Fittings should match hose size.
The cts an fail in a lot of ways that won't cause a code, but screw up drivability and or idle and or starting.
- 15 replies
