Durania
Everything posted by Durania
  1. Title sums it up. If I want to change the fan direction in my Outback, I have to give the dash a smack and the direction will change. How can I fix this?
  2. I thought you were drunk taking a leak.
  3. I'm with Wally. I would gladly pay someone who is experienced to replace my windshield. Being my luck, first rain storm I get the floor board would be full of water.
  4. Would be really tough for me to go to an 05 Legacy with the EJ25. You could always find a set of low mileage heads for that thing.
  5. When you see water coming out of the other hose and not coolant. I will do about 2 or 3 minutes per hose.
  6. I learned something. I got on my RSD wholesale account and read the description of their clutch. http://www.rallysportdirect.com/Exedy-OEM-Replacement-Clutch-Subaru-Models-inc-2006-2011-WRX-2005-2009-Legacy-GT Says: " 2005-2009 Legacy GT requires the use of a 2006-2007 WRX flywheel for proper fitment."
  7. My RS hated the AC too. Luckily, it had a sunroof that when you crack it open an inch pulled a ton of air straight in.
  8. I had luck replacing a faulty radiator cap after flushing heater core. Used a tappered fitting used to repair a garden hose. Fits right in a heater core line.
  9. I got faith you can get this straightened out man. Lot of good guys on here with valuable knowledge and experience.
  10. I have one on my 95 Outback. You probably cant even get one from the dealer. You gotta do what you need to.
  11. I had some weird stuff like that happen with my Brat alternator would go out.
  12. Fusible links are in a gray box behind the battery on the left side of the engine bay. It will have 3 fusible links inside of it.
  13. The problem I had was the clamp that attaches the neck to the hose going into the tank was at a an angle that only allowed for partial contact with my screw driver and nut drivers. It made the job annoyingly longer to complete.
