Everything posted by Durania
BRAT automatic to manual conversion
Good job on the swap. Good gravy what a project!
Remanufactured Engines?
Durania replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWow, I had always heard lots of good things about CCR. Condolences.
Durania replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSeems like a gamble to me. I would get one here: http://www.ccrengines.com and not worry about the quality of the rebuild.
Subi #2
Durania replied to MaddCelt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXQuoted for greatness and I can relate.
My '95 Legacy: Trashwagon10
Thank you very much. -Kyle
Thanks. I am an utter noob when it comes to timing belt jobs. Do the cam gears move when tension is removed? Does the motor need to be retimed? Or do I just take the old belt off and throw the new one on?
1998 Subaru Legacy 5DR OUTBACK
Durania replied to MaddCelt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXProbably why it was traded in.
Good job on the timing belt, Tom. I really want to tackle the job myself on the Outback. Don't have a good picture writeup handy, do you?
Grandma's Subaru
Please post lots of pictures when you get it.
Which low beams are best for 2002 LEgacy GT
Durania replied to lhrocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI got a two year old silverstars in my Outback that I yanked them out of my RS before selling it, still doing fine.
Durania replied to lhrocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't see what the problem is, both low beams burned out, you replaced them, problem solved. Are you making sure to turn your headlights off during the day so that the daytime running lights are getting lower voltage and not wearing out the bulbs as fast? What do you mean regular style bulbs? It's a pretty common bulb used in those things.
Parts cost to replace HG in '98 2.5?
Durania replied to TheSubaruJunkie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX98 will have DOHC.
drivetrain vibration
Durania replied to crcorc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like you have the driveshaft in a different place. I remember having this issue on my brat when I did a u joint. I remember there being some markings to show where it needs to meet with the diff in the correct spot. My suggestion: take it loose and rotate it one spot and drive it. Use trial and error from that point.
VIN information (4 or 5)
I would tell them the VIN 5, you do have a 5 in your VIN after all.
Cluster mod - red needles
Durania replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe blue may be your problem. Every gauge cluster that I have saw that has been swapped over to blue was really hard to read and look at.
Durania replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHAHAHA, and here I am wanting the red ones. I did a double take when I first saw a 97+ speedo and compared it to mine. It's slightly different than looking at this one:
Durania replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGuess I should have refreshed the page.
Durania replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo, my 95 has white needles.
Rear Storage Compartment Question
Durania replied to ettev's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think he is talking about the thing that covers the spare in the trunk.
Has anyone ever modded the gauge cluster in the second gen Legacies to where the needles are red as seen in the JDM models? Example:
My '92 Loyale: Safariwagon
Watched it on youtube this morning. First words out of my mouth when I saw the hood was: "Oh wow!"
After cat to midpipe bolt size
Durania replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat is exactly why I said screw it and took it to a shop.
2003 wrx oil consumption
Bingo. Seems to happen when the miles > 100,000 as well.
Input needed - Air conditioning
Durania replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat I figured. Thanks man.
I am leaving the office this evening about to head on a weekend trip and I get to the car (05 STi) and it's close to 80 here. I attempt to turn the AC on and nothing happens. I immediately go into diagnostic mode in my brain trying to figure out this one out. I determine that the compressor is not kicking on, nor is the fans. I get home and use the last remnants of the 134a I had left from when I recharged the system on my RS last year. I put some in and manage to get the compressor to kick on along with the fans but still don't get cold air out of the vents. I talked to my buddy who had the same problem with his 03 WRX and he said it was a 0.30 o-ring that was causing his leak. Any thoughts?
